tdawson-townsend(at)auror Guest
Posted: Wed Oct 06, 2010 7:47 pm Post subject: Ballast? |
What have folks used for ballast to do max gross weight and other c.g. testing during their Phase I period?
TDT
Tim Dawson-Townsend
RV-10 N52KS
APRS KB1URG
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
57.07 KB |
10827 Time(s) |
Posted: Wed Oct 06, 2010 8:05 pm Post subject: Ballast? |
We keep a bunch of 50# bags of water softener salt in the shop. We use it for ballast and for weighting down wing skins, etc. Plus I have a water softener at home...
Salt is pretty cheap, about $5/bag. The plastic bags are more durable than the paper sacks.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Wed, Oct 6, 2010 at 8:44 PM, Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)> wrote:
Â
TDT
Â
Â
Tim Dawson-Townsend
RV-10Â N52KS
APRS KB1URG
[img][/img]
Â
AirMike
Posted: Wed Oct 06, 2010 8:19 pm Post subject: Ballast? |
I bought 75# of lead shot at Cabellas and put it in a plastic bag to keep the lead dust away from inside the plane, but I found that I only needed 50# - I keep it in a plastic bucket shock corded to the rear of the baggage area. That way it is easy to remove when I need to load baggage
_________________ See you OSH '18
Q/B - sold. |
tsts4
Posted: Thu Oct 07, 2010 3:32 am Post subject: Re: Ballast? |
I'm not at that point yet, but my plan is to use 5 gal water jugs (at) 40/lbs a piece when full. About as cheap as it gets and I can quickly configure different weights.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
bkbrown(at)minetfiber.com Guest
Posted: Thu Oct 07, 2010 4:35 am Post subject: Ballast? |
When you use something as ballast, you should assume you'll spill it. In
that context, water or dirt or sand=good. salt=not so much
Bob Brown
Independence,OR
RV-10 - wiring/FWF
rene(at)felker.com Guest
Posted: Thu Oct 07, 2010 5:28 am Post subject: Ballast? |
Whatever you choose, you will need a lot….
I used 80# sand bags. I placed them in garbage bags to prevent spills. When I was done….the sand went into my kids sand box.
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Wednesday, October 06, 2010 9:44 PM
Subject: Ballast?
TDT
Tim Dawson-Townsend
RV-10 N52KS
APRS KB1URG
57.07 KB |
10806 Time(s) |
davidsoutpost(at)comcast. Guest
Posted: Thu Oct 07, 2010 7:26 am Post subject: Ballast? |
40# water softener salt bags work great, especially if you have a use for them afterward.
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Thu Oct 07, 2010 8:34 am Post subject: Ballast? |
Put the lead shot in a PVC Pipe segment sized for the desired weight and glue on caps. Easy to manage and doesn't spill.
Jim C N312F - Flying
On Thu, Oct 7, 2010 at 12:19 AM, AirMike <Mikeabel(at)pacbell.net (Mikeabel(at)pacbell.net)> wrote:
[quote]--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
OSH '10 or Bust
Q/B - finally done
http://forums.matronics.com/viewtopic.php?p=315004#315004
le, List Admin.
_________________ RV-10 -> N312F - Flying as of 12/2008 |
Jim Combs
Posted: Thu Oct 07, 2010 8:37 am Post subject: Ballast? |
I bought 150 lbs of shot from a local sporting goods store and used that. It's easily moved around and can be secured.
Jim Combs - N312F
On Wed, Oct 6, 2010 at 11:44 PM, Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)> wrote:
TDT
Tim Dawson-Townsend
RV-10 N52KS
APRS KB1URG
[img][/img]
Posted: Thu Oct 07, 2010 8:57 am Post subject: Ballast? |
I think might have answered the wrong question. I thought he was looking for what he used for Max GW testing. Need a lot more than 150lbs for that.
So my new answer is……I pack a survival kit with water in it. Weights about 20 lbs and is all the ballast I need to day to day flying…..
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs
Sent: Thursday, October 07, 2010 10:28 AM
Subject: Re: Ballast?
Jim Combs - N312F
TDT
Tim Dawson-Townsend
RV-10 N52KS
APRS KB1URG
Error! Filename not specified.
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
fixitauto(at)aol.com Guest
Posted: Thu Oct 07, 2010 9:25 am Post subject: Ballast? |
WHY NOT JUST USE THOSE GOLD BARS YOU GOT BARRIED IN THE BACK YARD.
57.07 KB |
10793 Time(s) |
dlm46007(at)cox.net Guest
Posted: Thu Oct 07, 2010 10:38 am Post subject: Ballast? |
why do all this testing at all? If one builds to the plans and uses the hardware provided, why so much testing? A unique design "homebuilt" would require complete testing. An RV kit built to Vans plans and rigged to Vans plans should perform very closely with the numbers as provided by the kit manufacturer. At least as closely as Cessna did with their marketing driven operating handbooks in times past..
57.07 KB |
10791 Time(s) |
tsts4
Posted: Thu Oct 07, 2010 11:16 am Post subject: Re: Ballast? |
Hmmm. Color me ignorant but I thought due diligence dictated that you are supposed to test the aircraft in a variety of weight/CG configurations in actual flight to verify performance. The only way to effectively do that in phase one is with ballast. Regardless of any one else's opinion, I still plan to explore multiple configs because I want to know what the no kidding flight characteristics are before I plop pax and bags in the plane.
Posted: Thu Oct 07, 2010 11:30 am Post subject: Ballast? |
I do it because I want to understand how my plane flies at all ends of the spectrum. Knowledge is king......
On Oct 7, 2010, at 2:20 PM, "DLM" <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote] why do all this testing at all? If one builds to the plans and uses the hardware provided, why so much testing? A unique design "homebuilt" would require complete testing. An RV kit built to Vans plans and rigged to Vans plans should perform very closely with the numbers as provided by the kit manufacturer. At least as closely as Cessna did with their marketing driven operating handbooks in times past..
pilotmelch(at)omnav.com Guest
Posted: Thu Oct 07, 2010 1:28 pm Post subject: Ballast? |
By definition, we test to verify everything was built to spec. I.e. you can’t know you built it to spec unless you test.
Â
Besides, do you really want to find out how it behaves at gross with your family as the ballast?
John Melchert
Jim Combs
Posted: Thu Oct 07, 2010 4:49 pm Post subject: Ballast? |
Rene,
You are correct, 150 lbs won't take it to full gross weight, but having it back in the baggage area will move the cg considerably aft. Fly it for a while and get used to the different handling. Takeoffs and landings are different with aft CG in the -10. Take the time to learn to fly it with the aft CG. The flair for landing and takeoffs with aft CG are different. I have learned to fly the airplane differently based on where the CG is. Use the 40 hours to evaluate your flying skills. Its fun and there is no pressure from passengers or other pilots. You can do touch and goes all day long without ever touching the nose wheel to the ground with aft CG. With forward CG, the nose wheel is coming down. Not abruptly but very soon after the mains are down. The -10 is a wonderful aircraft and I have really enjoyed flying it.
Jim C N312F
On Thu, Oct 7, 2010 at 12:54 PM, Rene Felker <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene' Felker
N423CF
801-721-6080
gengrumpy(at)aol.com Guest
Posted: Thu Oct 07, 2010 6:21 pm Post subject: Ballast? |
Don't forget to do these with light fuel loads!!
grumpy
On Oct 7, 2010, at 7:46 PM, Jim Combs wrote:
[quote]Rene,
Jim C N312F
Rene' Felker
N423CF
801-721-6080
| [b]
fdombroski
Posted: Fri Oct 08, 2010 4:21 am Post subject: Re: Ballast? |
I used my in-laws :-}
_________________ Frank Dombroski
Multiple Offender RV-8, 7A, 10 x 2
RV-10 2.0 N46VT 2015
KSMQ Somerset Airport NJ |
