mjpienaar(at)shaw.ca Guest
Posted: Tue Oct 05, 2010 9:52 pm Post subject: Landing gear on TR4 |
Hi All
Started to mount the front landing gear to-day but it seems to result in a very high "nose up" attitude. Is there a spec for the angle that the fuselage should be while on the gear?
Mike
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Wed Oct 06, 2010 6:25 am Post subject: Landing gear on TR4 |
Mike,
Is that with or without the engine? The gear will compress some when the engine is mounted but I have noticed that several of the TR-4's seem to have a slight nose high attitude. Check out the various completions photos on my site along with some photos of the planes before and after engine mount.
Bob Reed
To: KISBUILDERS <kis-list(at)matronics.com>
Sent: Wed, October 6, 2010 12:52:19 AM
Subject: Landing gear on TR4
Hi All
Mike
[quote][b][b]
mantafs(at)earthlink.net Guest
Posted: Wed Oct 06, 2010 7:39 am Post subject: Landing gear on TR4 |
Mike,
Rich is a fan of the nose high, tail low look. Kind of like how a Mooney sits.
I adjusted both my main gear and nose gear to provide a more level stance but keep the prop clearance the same.
Mark
fredorosa(at)gmail.com Guest
Posted: Wed Oct 06, 2010 9:46 am Post subject: Landing gear on TR4 |
If you can get the plane to sit level when fitted with the engine and loaded with half fuel and yourself, it would be fine. If it sits nose high in that configuration I would try and correct it. Reason is, the nose wheel will touch down sooner and the braking will be longer and less effective in the roll-out due to some lift from the wing's angle of attack. Also, rotation can occur too soon for the same reason.
My kit was supplied with a GROVE landing gear by request and the gear makes the plane sit higher off the ground than a typical TR-4. I attached the nose gear higher to get a level stance with simulated engine weight. When fully loaded, it will sit a bit nose low which is what I prefer.
Al
On Wed, Oct 6, 2010 at 10:21 AM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
[quote] Mike,
Bob Reed
From: Mike Pienaar <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)>
To: KISBUILDERS <kis-list(at)matronics.com (kis-list(at)matronics.com)>
Subject: KIS-List: Landing gear on TR4
Hi All
Mike
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
Posted: Fri Oct 08, 2010 7:22 am Post subject: Landing gear on TR4 |
I am so embarrassed, I never took into account the fact that the nose gear
will compress under load. So guess I will have to wait and see what it looks
like when I have got the motor on.
Will let you know what transpires and thanks again for the help
Mike
ftyoder(at)yoderbuilt.com Guest
Posted: Fri Oct 08, 2010 10:39 am Post subject: Landing gear on TR4 |
Mike,
If you wanted to check it out now you could hang some sand bags, anvils, boat anchors, etc. that equal the weight of the engine you are going to use. That will let you see where you are going to end up.
