Posted: Mon Oct 04, 2010 9:33 pm Post subject: Enderes screwdriver redux - the perfect screwdriver |
Previously I posted this:
Match: #4 Message: #28437 Date: Aug 28, 2010 From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> Subject: Tool question - anyone familiar with Enderes tools? | Quote: | | I have this one long shaft phillips head screwdriver that keeps falling into my hands. It seems to be a #1 phillips but actually works better than both my #1 and #2 Craftsman drivers. Probably inherited it from my Dad's shop. It's rusty and looks like hell so I'm never drawn to it... until I'm struggling with some screw. I always end up with this one in my hand and the problem is solved. I've looked Enderes up on the Web and see they forge tools and blah blah. Any tool knowledgeable people out there know anything about Enderes? I think I want to try some more. | So I've gone to the company web site with the intent of buying a few shorter models than the 10" one I have. Their pricing makes it clear that the best way to get one or two is to find an old school hardware store that carries them. I found one 2 miles down the road but they only had regular Enderes drivers in stock, no Phillips.
Then a Google search turned up this little gem of a story from the year 2000 on an old school Web site called "Everything2". I was amazed!
http://everything2.com/index.pl?node=the+perfect+screwdriver&lastnode_id=1797151&searchy=search
This is the exact screwdriver I've been lusting after!
I will be a very happy camper if I can get a set of Enderes Phillips drivers in the shorter sizes. Maybe I'll just pay the $30 including $10 of shipping for a set of 3 from the factory.
With all the screws on our planes, it's nice to have the 'perfect screwdriver' even if there is no such thing. But I'm telling you, this one works MUCH better than my Craftsman drivers.
Bill "enjoying the paint" Watson
AirMike
Posted: Tue Oct 05, 2010 3:26 am Post subject: Enderes screwdriver - the perfect screwdriver = "X" |
The biggest problem is the head of the Phillips driver - rolling out of the screw head and buggering the screw.
A few years ago my former plane partner showed me something called the "X" head screwdriver. They are hard to find, but I located some at Snap-on at OSH a few years back. (just driver tips) They have 2 or 3 tiny but distinctive ridges or cuts on the side of the tip that seem to really grip the Phillips head channels. I did a few hundred screws yesterday - doing my annual and buggered only 2 screws.
_________________ See you OSH '18
Q/B - sold. |
Posted: Tue Oct 05, 2010 6:03 am Post subject: Enderes screwdriver redux - the perfect screwdriver |
Yep, that's it. Rolling out of the head is the problem and it's what
this driver tends not to do. Even at an angle. I don't know if this
driver has that feature but I'm going to check.
If the "x" thing is the trick, I'll have to get some for my little
powered drivers. As mentioned before, Costco has one at $20 which
seems to be 50% of what it costs everywhere else. Nice unit.
I just ordered 3 drivers and they are on their way.....one small step
for this project, one giant leap for my tool box. And I'm happy.
Enderes was reselling a 15 in 1 ratcheting driver that I'd like to get
but it seems to be out of stock in all channels. Will keep an eye out
for it.
On 10/5/2010 7:26 AM, AirMike wrote:
Tim Olson
Posted: Tue Oct 05, 2010 6:47 am Post subject: Enderes screwdriver redux - the perfect screwdriver |
I was interested to hear that you found the Enderes screwdriver
so nice. It's funny, around here at the local farm store
"Farm and Fleet", and also "Mills Fleet Farm" these things are
super common. They've been on sale with the multi-driver where
you get a large/small philips on one end and large/small flat
on the other, and the hex shank is sized to do the size of
nutdriver that worm clamps use. I just used mine to winterize
the boat. It was interesting because I've always been amazed by
the screwdrivers. I have tons of screwdrivers, but many phillips
drivers just wear out and eventually you get a stub tip poking
in the center of the driver and the thing starts to skip
as it turns....but these seem to have some really good hardened
steel on the tips, along with those grooves, and they just
rarely skip and rarely wear out. I have had good luck with
a particular stanley driver too, but for many years now these
enderes drivers have been what I use on the plane, because
I hate stripping screw heads. Whenever they're on sale for
under $3 I buy a couple. The metal tip is as-described...not
chromed at all, just a dull grey on the tip. I did find a
small version of it, I'm guessing made by Enderes, but it's
relabeled under a local store name, that seems to hold up
just as well, but is for small phillips screws and has a
flat on the other end. I use that under the panel a lot.
I think it was .59 or .79 when I got one a couple weeks ago
for my laptop bag.
Whatever they do at Enderes, they do it right. Hopefully
they won't start offshoring it from China like everyone
else seems to do.
Tim Olson - RV-10 N104CD
On 10/5/2010 9:00 AM, Bill Watson wrote:
powered drivers. As mentioned before, Costco has one at $20 which seems
for it.
aerosport1
Posted: Tue Oct 05, 2010 7:33 am Post subject: Enderes screwdriver redux - the perfect screwdriver |
I have a Ryobi like this one that I love. I used it thru out my entire
build.
FWIW
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
266.1 KB |
6633 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
rv10(at)colohan.com Guest
Posted: Tue Oct 05, 2010 9:50 am Post subject: Enderes screwdriver redux - the perfect screwdriver |
In Canada (where I'm originally from) Robertson screws have pretty much dominated over Phillips. IMHO, they are superior in every way. I've always wondered why they are so hard to find in the US...
Chris
On Tue, Oct 5, 2010 at 4:26 AM, AirMike <Mikeabel(at)pacbell.net (Mikeabel(at)pacbell.net)> wrote:
[quote] --> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
OSH '10 or Bust
Q/B - finally done
http://forums.matronics.com/viewtopic.php?p=314760#314760
le, List Admin.
drfred(at)suddenlinkmail. Guest
Posted: Tue Oct 05, 2010 2:25 pm Post subject: Enderes screwdriver redux - the perfect screwdriver |
Chris:
Couple of years ago I got this book for my Dad (former machinist). I
found it quite interesting. It tells about the history of the screws and
the different heads. If I remember correctly, the reason the US has the
Phillips drive type head and not the Robertson's is because of Henry
Ford. Even then, they knew the square drive worked better, but Phillips
had a cheaper screw, and therefore Henry Ford went with it.
This book is worth the $10. Get one for some one for xmas and pass it
around.
Dr Fred
One Good Turn: A Natural History of the Screwdriver and the Screw
[Paperback]
Witold Rybczynski
<http://www.amazon.com/Witold-Rybczynski/e/B000AQ1U8A/ref=ntt_athr_dp_pel_1>
<http://www.amazon.com/One-Good-Turn-Natural-Screwdriver/dp/0684867303/ref=sr_1_2?s=books&ie=UTF8&qid=1286317043&sr=1-2#>
*Witold Rybczynski* (Author)
*›* Visit Amazon's Witold Rybczynski Page
<http://www.amazon.com/Witold-Rybczynski/e/B000AQ1U8A/ref=ntt_athr_dp_pel_pop_1>
Find all the books, read about the author, and more.
See search results
<http://www.amazon.com/s/ref=ntt_athr_dp_sr_pop_1?_encoding=UTF8&sort=relevancerank&search-alias=books&field-author=Witold%20Rybczynski>
for this author
Are you an author? Learn about Author Central
<http://authorcentral.amazon.com/gp/landing/ref=ntt_atc_dp_pel_1>
(Author)
dlm46007(at)cox.net Guest
Posted: Tue Oct 05, 2010 2:55 pm Post subject: Enderes screwdriver redux - the perfect screwdriver |
Just one more reason to use the CS screw with the internal hex head for the
forward most 3-4 places on each side of the tunnel cover. Removing/inserting
those with an Allen wrench beats Phillips head there anytime.
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Wed Oct 06, 2010 4:40 am Post subject: Re: Enderes screwdriver redux - the perfect screwdriver |
Another tip for getting out tough screws. Put a little valve lapping compound on the tip of the screwdriver. This has saved me countless times.
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
