amekler(at)metrocast.net Guest
Posted: Mon Oct 04, 2010 4:46 pm Post subject: TMXIO-540 and GAMI injectors |
Kelly,
My flow divider went out to Mattituck and was cleaned and sent back and I
was told it was all set. I flew the plane with the GAMIs cylinder 5 with the
J(richest injector) and cylinder 3 with the A (leanest injector).
My results are as follows. Cylinder 1 peaked at 11.4 gal cylinder 2 at
11.4 cylinder 3 at 10.5 cylinder 4 at 11.1 cylinder 5 at 12.2 and
cylinder 6 at 11.4.
As you can see this is similar to what I had before the fuel divider was
serviced. Any thoughts on what is going on?
Alan
Kelly McMullen
Posted: Mon Oct 04, 2010 5:04 pm Post subject: TMXIO-540 and GAMI injectors |
Obviously #3 and #5 are your outliers. The question is why. I'd see what GAMI has to say on the data. Somehow, either the injector on 5 isn't what it says it is, or the cylinder is getting significantly more air some how. Is the engine rough when you get all the way to #3 peaking?
On Mon, Oct 4, 2010 at 8:42 PM, Alan Mekler <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
[quote] --> RV10-List message posted by: "Alan Mekler" <amekler(at)metrocast.net (amekler(at)metrocast.net)>
Kelly,
cylinder 6 at 11.4.
Alan
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Mon Oct 04, 2010 5:20 pm Post subject: TMXIO-540 and GAMI injectors |
Kelly,
Everything pointed to the fuel flow divider and this was sent out and serviced but despite trying to get cylinder 3 to run leaner and cylinder 5 to run richer the GAMIs have failed. The only other thought I had was that maybe the EGT probes were swapped on cylinder 3 and 5???
Alan
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Monday, October 04, 2010 8:58 PM
Subject: Re: TMXIO-540 and GAMI injectors
Kelly,
cylinder 6 at 11.4.
Alan
Kellym
Posted: Mon Oct 04, 2010 6:31 pm Post subject: TMXIO-540 and GAMI injectors |
Certainly a possibility, since they are adjacent cylinders. Does the
engine behave like it has a lot of imbalance between cylinders or no?
I'd certainly try swapping those two probes. It will tell you if they
are reading correctly or are swapped. Something is swapped, because your
results are the reverse of what you would expect with those nozzles.
Other option, if easier, would be to swap injector nozzles between those
two cylinders. It will either get a lot better or a lot worse.
On 10/4/2010 9:16 PM, Alan Mekler wrote:
Kelly,
Alan
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly
McMullen
*Sent:* Monday, October 04, 2010 8:58 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: TMXIO-540 and GAMI injectors
peaking?
Kelly,
with the
cylinder 6 at 11.4.
Alan
KCHD |
Posted: Tue Oct 05, 2010 1:38 am Post subject: TMXIO-540 and GAMI injectors |
Kelly,
Thanks for the advice. I'll keep you posted. Here is an excel spread sheet
of that last flight.
Alan
| Description: |
 Download |
| Filename: |
oct_4_flight_data.xls |
| Filesize: |
153 KB |
| Downloaded: |
308 Time(s) |
Posted: Tue Oct 05, 2010 3:07 pm Post subject: TMXIO-540 and GAMI injectors |
Kelly,
Tested the EGT probes with a heat gun. All are reading correctly. Spoke to
GAMI. They can't figure out what's going on but will try an even richer
injector for 5 and an even leaner injector for 3. To be continued.
Alan
