sstearns2(at)yahoo.com Guest
Posted: Sun Oct 03, 2010 9:05 pm Post subject: landing gear |
Hello all,
Does anyone remember who made the landing gear? Was is Grove down in San Diego?
My landing gear was not bent correctly originally and I'm probably going to pull it off and have it adjusted. Right now the camber is off vertical by about 7 degrees and its wearing the inner part of the tire really fast.
Scott
bakerocb
Posted: Mon Oct 04, 2010 3:28 am Post subject: landing gear |
10/4/2010
Hello Scott, I am pretty sure that it was not Grove. When I converted my KIS
TR-1 from Matco to Grove wheels and brakes I had to make extensive grinding
changes to the bottom end of the gear to make the Grove brake assembly fit.
Both Grove and Aircraft Spruce will sell you axle shims that will permit you
to change the camber. See here:
http://www.aircraftspruce.com/catalog/lgpages/axleShims.php
http://www.groveaircraft.com/accessories.html
Seven degrees sounds like a lot to change all at once, but you can stack the
shims to get varying results. Playing around with the shims would be a bit
less drastic than pulling and bending the gear.
Why don't you call Robbie Grove at 1-619-562-1268 and discuss the situation
with him -- he has always been very helpful.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
richard_trickel(at)yahoo. Guest
Posted: Mon Oct 04, 2010 4:24 am Post subject: landing gear |
Scott
The gear were made by several suppliers untill Lyle started doing them. He did the most amount. Possibly you could just find someone to bend it on a press for adjustment or use some shims like OC suggested.
Rich
--- On Mon, 10/4/10, Scott Stearns <sstearns2(at)yahoo.com> wrote:
Subject: landing gear
To: kis-list(at)matronics.com
Date: Monday, October 4, 2010, 4:58 AM
Hello all,
Scott
=nofollow target=_blank>http://www.matronics.com/Navigator?KIS-List
et=_blank>http://forums.matronics.com
galinhdz(at)gmail.com Guest
Posted: Mon Oct 04, 2010 5:39 am Post subject: landing gear |
Shims will probably be cheaper than a new gear. Even with a new gear, you may still need a shim or two to get the alignment right in both toe and camber.
Galin
On Mon, Oct 4, 2010 at 7:18 AM, Richard Trickel <richard_trickel(at)yahoo.com (richard_trickel(at)yahoo.com)> wrote:
[quote] Scott
Rich
--- On Mon, 10/4/10, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
From: Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)>
Hello all,
Scott
et="_blank">http://www.matronics.com/Navigator?KIS-List
mantafs(at)earthlink.net Guest
Posted: Mon Oct 04, 2010 6:00 am Post subject: landing gear |
Hello Scott,
When I bought my TR1 with the bent gear, Vance straightened it using a press. The gear yields at under 4 Gs so can be bent with about 3 tons depending on geometry. You should be able to find one around to use. If not Harbor Freight will have their 12 ton press for $89.99 with a coupon from 28 to 31 Oct.
Mark
Posted: Mon Oct 04, 2010 6:37 am Post subject: landing gear |
Hi OC,
The problem with shims is that that the bolt holes will not align. It would work with 1/2 a degree or one, but not seven. They are way off. I have some 5 degree shims I got from summit racing, but the bolt holes will never be right.
I've gone round and round with this in my head and I think just pulling the gear and bending it to the correct angle is the cleanest thing to do.
Scott
--- On Mon, 10/4/10, bakerocb(at)cox.net <bakerocb(at)cox.net> wrote:
Subject: Re: landing gear
To: kis-list(at)matronics.com, sstearns2(at)yahoo.com
Date: Monday, October 4, 2010, 4:26 AM
--> KIS-List message posted by: <bakerocb(at)cox.net (bakerocb(at)cox.net)>
10/4/2010
Hello Scott, I am pretty sure that it was not Grove. When I converted my KIS TR-1 from Matco to Grove wheels and brakes I had to make extensive grinding changes to the bottom end of the gear to make the Grove brake assembly fit.
Both Grove and Aircraft Spruce will sell you axle shims that will permit you to change the camber. See here:
Seven degrees sounds like a lot to change all at once, but you can stack the shims to get varying results. Playing around with the shims would be a bit less drastic than pulling and bending the gear.
Why don't you call Robbie Grove at 1-619-562-1268 and discuss the situation with him -- he has always been very helpful.
'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge."
Posted: Mon Oct 04, 2010 6:39 am Post subject: landing gear |
Hey Mark,
I've been thinking about trying to do it myself, but what do you bolt the gear down to? I don't want to bend the center section.
Does it need to be heat treated after bending?
Scott
Date: Monday, October 4, 2010, 6:59 AM
--> KIS-List message posted by: Mark Kettering <mantafs(at)earthlink.net (mantafs(at)earthlink.net)>
Hello Scott,
Mark
Posted: Mon Oct 04, 2010 6:42 am Post subject: landing gear |
Hi Galin,
I'm not looking at getter a whole new gear, just increasing the bends in the one I have. I agree it's normal to have to shim the gear a little, but 7 degrees is way too much to shim.
Scott
--- On Mon, 10/4/10, Galin Hernandez <galinhdz(at)gmail.com> wrote:
Date: Monday, October 4, 2010, 6:30 AM
Galin
| Quote: | Scott
Rich
Hello all,
Scott
Posted: Mon Oct 04, 2010 7:02 am Post subject: landing gear |
Hey Scott,
Vance did not anneal before bending or reheat treat after bending. I do not think the aluminum will need to be reheat treated.
I am not sure how Vance rebent my gear. I kind of assume he used a big V block of sorts and then pressed the corner he wanted sharper into the V. If I recall correctly his press was maybe 20 tons but he said it did not take much. The larger the V block the less the force required. Have you seen the large hydraulic pipe benders at Harbor Freight? They use rollers instead of a V block but the idea is the same.
Mark
Posted: Mon Oct 04, 2010 7:20 am Post subject: landing gear |
Hey Mark,
Wouldn't it be nice if Vance were still around.
So I would press the bend of the gear down into the V block? Were could I get a V block or would I have to make one?
Scott
Date: Monday, October 4, 2010, 8:00 AM
Hey Scott,
Mark
bakerocb
Posted: Mon Oct 04, 2010 8:01 am Post subject: landing gear |
10/4/2010
Hello Scott, If you are determined to bend your own I bet you could rig this
to do the bending:
http://www.harborfreight.com/12-ton-hydraulic-pipe-bender-32888.html
I still think that it is worth a phone call to Robbie Grove to get his
input. He may even be able to provide you some undrilled, one piece shims
that could solve your problems. Why not pick his brain -- even if you decide
to bend the gear yourself he may have some pertinent advice.
Please read again what 'OC' Baker Says.
Posted: Mon Oct 04, 2010 9:34 am Post subject: landing gear |
Hi OC,
I don't think shims will work with this large of an angle since the bolt holes will not line up. What I would need is new axles machined with 7 degrees of negative camber, but I think the best thing to do is just to get the gear bent correctly.
I should give the grove guy a call and see what options he comes up with. I did email grove to ask how much it would be to adjust the camber and they want $300 which seems insane for what would probably be 30 minutes of work for them at most. That was just from a sales drone though, maybe Robbie wouuld be more reasonable.
Scott
Date: Monday, October 4, 2010, 9:00 AM
10/4/2010
Hello Scott, If you are determined to bend your own I bet you could rig this to do the bending:
I still think that it is worth a phone call to Robbie Grove to get his input. He may even be able to provide you some undrilled, one piece shims that could solve your problems. Why not pick his brain -- even if you decide to bend the gear yourself he may have some pertinent advice.
lgdavid(at)roadrunner.com Guest
Posted: Mon Oct 04, 2010 10:10 am Post subject: landing gear |
Hi Scott, why not send it up to Lyle. While he is no longer just over the hill, he is only up in Idaho now. Larry
On 10/4/2010 5:18:32 AM, Richard Trickel (richard_trickel(at)yahoo.com (richard_trickel(at)yahoo.com)) wrote:
[quote] Scott
Rich
Scott, I think the Chapter 723 hanger has Vance's old press. Come take a look. It is back in the tool crib in the back corner. Larry
On 10/4/2010 6:59:47 AM, Mark Kettering (mantafs(at)earthlink.net (mantafs(at)earthlink.net)) wrote:
[quote] --> KIS-List message posted by: Mark Kettering <mantafs(at)earthlink.net (mantafs(at)earthlink.net)>
Hello Scott,
from 28 to 31 Oct.
Mark
Posted: Mon Oct 04, 2010 10:51 am Post subject: landing gear |
Hi Scott,
If the gear leg will fit between the plates then the pipe bender may be the best way to go. The V block does not need to be an actual V. Only the top corners of the V are actually used. So any two parallel supports 8 inches apart would work. But keep in mind they are forced apart when pressing. You can search around for some sort of scrap that would work. You could also get two plates, drill two holes in each and put in two pins to support the gear similar to the pipe bender. Or you can cut and weld some metal together. Depending, you may also want to put a plate along the gear so you do not scratch the gear.
You could also search around your area for a iron or metal working shop that is set up to bend things. I know of a good one in Zhuhai that would do it for 10 yuan. If you brought it here I could also help you out.
Another idea is bolt the gear to the floor. Then get or make a strong and long lever arm with fork at the end. Put the fork over the end of the gear and give it a careful yank. A quick rough calculation makes me think that you only need about 1500 ft-lbs to bend it. So given your 200 lbs of weight you would need about an 8 foot lever arm.
Or if you were a real hacker like me, find some guard rail or other closely spaced posts and put the gear between them to hold it. Then get a section of thick wall box section tube and put it over the end of the gear and pull it into the right angle. Use scraps of metal and wood to pad and force the bend where you want it.
I also miss having Vance around. I really enjoyed taking shop or anything with him. The best part of the day at High Tec was when Vance would stop by for some engineering bsing and bring donut holes. I am sure Rich also misses his help, insight and company.
Mark
Posted: Tue Oct 05, 2010 3:41 am Post subject: landing gear |
Gang
Ahh yes the donut holes and coffee. I really do miss Vance and his ideas and help. Not only inovative but the best of friends
Rich
Date: Monday, October 4, 2010, 6:31 PM
Hi Scott,
Mark
