new owner of an older kolb x kit
Goto page 1, 2  Next
awcbs
PostPosted: Tue Sep 28, 2010 11:25 am    Post subject: new owner of an older kolb x kit Reply with quote
just got a mark 3 x kit from around 1999. quick build option, not much done on it. I live in eastern Pa. north of pittsburgh. prob be askin alot of questions. just warning everyone. anyway looking forward to the build. any tips before I get started are always welcome. thanks AJ
The BaronVonEvil
PostPosted: Tue Sep 28, 2010 11:55 am    Post subject: new owner of an older kolb x kit Reply with quote
Hi AJ,
Welcome to the World of Kolbs. You might want to give Travis at Kolb a call
to see if there are any updates to your Kolb that you should consider. Keep
us posted about your progress of your build!
Carlos G.
AKA
BaronVonEvil
Eugene Zimmerman
PostPosted: Tue Sep 28, 2010 5:14 pm    Post subject: new owner of an older kolb x kit Reply with quote
LOL
Good luck,
I hope your building abilities surpass your grasp of Pennsylvania's
geography.
Gene Z
welcome. thanks AJ
http://forums.matronics.com/viewtopic.php?p=314014#314014
Thom Riddle
PostPosted: Wed Sep 29, 2010 3:26 am    Post subject: Re: new owner of an older kolb x kit Reply with quote
AJ,
Can you be a little more specific about your location, like nearest town name or airport from which you will fly your Xtra when it is ready. Sort of hard to find you in eastern PA north of Pittsburgh Smile.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
awcbs
PostPosted: Wed Sep 29, 2010 6:52 am    Post subject: Re: new owner of an older kolb x kit Reply with quote
I was in allentown working yesterday when I posted, so I was in eastern Pa but that was mistake. know Pa. pretty well as I travel all over fixin roads. been from allentown to erie, williamsport to mt.morris. sorry, 1 little mistake. I live in whitesburgh Pa, which is right next to kittanning Pa. 1 hr north of pittsburgh. my neighbor has a 2000' grass strip. out my driveway and up his to the strip. my parents also have a farm where I flew an old mirage ultralight out of years ago. would also be interested in checking out other kolbs in the area, thanks and sorry for the typo. AJ
Thom Riddle
PostPosted: Wed Sep 29, 2010 7:23 am    Post subject: Re: new owner of an older kolb x kit Reply with quote
AJ,
Thanks for refining your location. No reason to apologize, we just kid each other to keep us all on our toes.
Welcome to the large Kolb flyers and builders family. I am only about two hours driving north of you which is about one hour Slingshot flying.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
slyck(at)frontiernet.net
PostPosted: Wed Sep 29, 2010 7:37 am    Post subject: new owner of an older kolb x kit Reply with quote
That's good, be humble or us good ole boys might shun ye.
BB
(an enthusiast of western PA where I did a lot of tent camping. You're not really camping in those
fancy-scmantzy mobile living rooms)
http://forums.matronics.com/viewtopic.php?p=314103#314103
williamtsullivan(at)att.n
PostPosted: Wed Sep 29, 2010 7:42 am    Post subject: new owner of an older Kolb X kit Reply with quote
You will get used to the guys kidding around. They just don't want you to get lost before you leave the ground.
Any questions you have about assembly, tricks, or legal requirements (builder's log, photos, etc.) just post to the List and somebody will have an answer. Good people here.
Good luck, and have fun. Let us know on progress.
      Bill Sullivan
      Windsor Locks, Ct.
      FS 447
Richard Pike
PostPosted: Wed Sep 29, 2010 1:30 pm    Post subject: Re: new owner of an older kolb x kit Reply with quote
If you would like a totally biased opinion at how one particular curmudgeon thinks MKIII's ought to be built, check out dis heah:
http://www.bcchapel.org/pages/0003/kolb.htm
Then when you are totally confused, ask questions on this list. We have many opinions... and are not shy to express them.
Richard Pike
MKIII N420P (420ldPoops)
zeprep251(at)aol.com
PostPosted: Wed Sep 29, 2010 1:44 pm    Post subject: new owner of an older kolb x kit Reply with quote
Welcome AJ,
There is a MK3 at a private strip on Rt14 near Columbiana called Morris, just inside the Mode C ring of Pittsburgh.Joe Saval flies there. I fly over there once in a while to visit But about 15 miles west of Morris is Salem (38D) A great restaurant for breakfast .We visit there a lot.We get a nice Saturday,we'll pick you up there and take you to breakfast!
Gary Aman MK3 C Jabiru 2200a 595 hrs.
racerjerry
PostPosted: Thu Sep 30, 2010 4:55 am    Post subject: Re: new owner of an older kolb x kit Reply with quote
"any tips before I get started are always welcome."
YES - Inventory all your parts and find what is missing.
Jerry King
rickofudall
PostPosted: Thu Sep 30, 2010 6:28 am    Post subject: new owner of an older kolb x kit Reply with quote
While you're doing the inventory, keep an eye out for the elevator bell crank that installs in the cockpit and is connected to the stick with a push pull tube. There was a running change made at some time in the 90's that added a hole on the left forward corner of the bell crank for the cable from the trim lever. Previous to this the trim lever connected to the elevator with a cable that ran from the trim lever all the way back to the bell crank in the tail and back again to the cockpit bell crank. When the trim lever is moved from whatever the builder selects as the neutral point one part of the cable goes slack and bangs around in the tail tube. While the noise by itself is worrisome, when the trim cable is taut and the elevator control cable is slack the elevator becomes kind of loosy goosy in turbulence. There are two ways to fix the problem, call Travis and order the current iteration of the cockpit bell crank, or use a longer bolt to attach the rod end of the push pull tube and add a tang to provide the second hole for the trim cable.
Another thing in the control circuits. I don't know if this is covered in the instruction manual, it isn't on the Mk IIIC plans. Add AN 970 large area washers to the outside of the rod end attachment bolt of the bell crank described above and the two on the aileron bell crank for the ailerons. This will keep the controls from becoming separated should the rod end come apart.
Rick Girard
On Thu, Sep 30, 2010 at 7:55 AM, racerjerry <gki(at)suffolk.lib.ny.us (gki(at)suffolk.lib.ny.us)> wrote:
--> Kolb-List message posted by: "racerjerry" <gki(at)suffolk.lib.ny.us (gki(at)suffolk.lib.ny.us)>
Jerry King
http://forums.matronics.com/viewtopic.php?p=314207#314207
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
 - G.K. Chesterton
mdnanwelch7(at)hotmail.co
PostPosted: Thu Sep 30, 2010 7:02 am    Post subject: new owner of an older kolb x kit Reply with quote
There was a running change made at some time in the 90's that added a hole on the left forward corner of the bell crank for the cable from the trim lever. Rick Girard
Rick,
  I purchased my brand new MkIIIC kit from "the Old Kolb Co" in November 1998.  I DO have the updated bellcrank that
you refer to.  Since AJ claims to have a kit from 1999, AND it is evidently an early model Xtra, one would assume Kolb
Co. didn't reverse their bellcrank revision and send out an older style.
  However, it is an excellent point that you mention it, just in case anyone else hasn't updated their own forward elevator
bellcrank.
Mike Welch
MkIII
rickofudall
PostPosted: Thu Sep 30, 2010 7:27 am    Post subject: new owner of an older kolb x kit Reply with quote
The change must have been cut in very early on in the Mk III production. I had a conversation with Travis about it when I first found it on my aircraft. As I recall he had no record of it which would seem to indicate the cut in was done before TNK took over from Homer. The serial number stamped at the end of the engine mount tube on my aircraft is 043. Truthfully, for all I know this may have been a builder mod. It doesn't look like it, but it could be.
Rick
On Thu, Sep 30, 2010 at 9:58 AM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
Rick Girard
Rick,
bellcrank.
Mike Welch
MkIII
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
 - G.K. Chesterton
PostPosted: Thu Sep 30, 2010 9:55 am    Post subject: new owner of an older kolb x kit Reply with quote
I have MKIII sn: M3-011.
Bro Jim and I were working at Homer's Dec 1990 to Mar 1991. Jim welded up MKIII fuselages and I inspected them from the very first, M3-001. We also built and modified my MKIII at night while there. Each morning, when Homer Kolb came to work, he would inspect and approve what Jim and I had done the night before.
My MKIII has the current forward aileron bell crank. I believe they all do.
BTW: I don't add fender washers to my rod end bearings. Haven't figured out how they could wear enough to separate. My MKIII rod end bearings have over 3,000.00 flight hours on them and they are quite serviceable. During my time flying Army helicopters, I do not remember fender washers being added to rod end bearings.
I wanted to refresh my memory, so I walked over to the hanger and took a close look at Larry Cottrell's FSII rod end bearings on his aileron push/pull tubes. Looks like it would be pretty difficult to get the small AN 1/4 inch washer through the hole if the bronze bearing totally disintegrated.
7 miles south of Burns Junction, OR
you refer to
Mike Welch
MkIII
awcbs
PostPosted: Thu Sep 30, 2010 3:12 pm    Post subject: Re: new owner of an older kolb x kit Reply with quote
zeprep, might take you up on the offer, but if your flyin I'm buyin. let me know when your goin and if I'm not workin I'll be there. thanks everyone for the replies and tips. I'll post a couple pics and serial # later 2night, maybe it'll shed a little more light on the year? goto finish making room for it, then inventory. know it's missing lexan and aluminum floor. thanks AJ
awcbs
PostPosted: Thu Sep 30, 2010 4:57 pm    Post subject: Re: new owner of an older kolb x kit Reply with quote
original bill of sale dated 12-10-1999
 Filesize:  1.99 MB
 Viewed:  23347 Time(s)
 Filesize:  2.01 MB
awcbs
PostPosted: Thu Sep 30, 2010 5:00 pm    Post subject: Re: new owner of an older kolb x kit Reply with quote
whoops, kinda big, have to resize next time
PostPosted: Thu Sep 30, 2010 6:19 pm    Post subject: new owner of an older kolb x kit Reply with quote
That photo format worked just fine. One of the guys should be able to date it from this.
      Bill Sullivan
      Windsor Locks, Ct.
      FS 447
http://forums.matronics.com//files/054_150.jpg
http://forums.matronics.com//files/052_508.jpg
--> http://f= - List Contributionsp; &bsp;-->
rickofudall
PostPosted: Thu Sep 30, 2010 6:26 pm    Post subject: new owner of an older kolb x kit Reply with quote
John,  I must assume, then, that my aircraft had an ill considered modification to the elevator trim linkage. As for the rod ends, "Rod ends have been known to literally come apart after the peening retaining the ball races somehow failed allowing the bearings to become disconnected. It is the wise builder who takes the precaution of installing a large diameter washer between the nut and bearing to prevent its total failure. To be successful in preventing this type of failure, the washer must have a diameter somewhat larger than the hole in the bearing flange.".....Tony Bingelis, "Sportplane Construction Techniques"
Tony made this recommendation about carburetor linkages, but I've found the same recommendation for control surface linkages in plans for the Long EZ and Varieze, among others.
If you like videos, EAA has this.  http://www.eaavideo.org/video.aspx?v=1618638582
Did you not recount awhile back how, before adding aileron counterweights you had to replace rod ends on a yearly basis as they wore?   60 cents worth of washers seems like awfully cheap insurance to me.
"For want of a nail....a kingdom was lost."
Rick
On Thu, Sep 30, 2010 at 12:13 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
you refer to
Mike Welch
MkIII
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
 - G.K. Chesterton
Goto page 1, 2  Next
Page 1 of 2
