Aileron flutter and Tail-wag
beauford
PostPosted: Fri Sep 24, 2010 12:37 pm    Post subject: Aileron flutter and Tail-wag Reply with quote
Brother Pike:
The Kolb rudder oscillation- tail wag phenomenon has been mentioned on the
list several times in the past... True to form, take my tootsies off the
pedals for five seconds or so, and the Kleenex Machine will invariably
launch into an increasing amplitude snake dance.
Since Beauford is not into self abuse (beyond matrimony) and I have a strong
recollection of how few lil' ol pop-rivets are holding the arse end of the
thing in association with the front end, I never let it go more than three
or four seconds before putting the feet back on the pedals to stop it before
it gets really wild.
In my aerodynamic ignorance, have always assumed this to be some combination
of rudder mass balance issue and interaction with the propwash vortex.
Since it is easily arrested and Kolbs have no history of shedding tails or
boom failure, have never been overly concerned about it...but am curious as
to whether any of the learned brethren on the List know exactly why this
happens to Kolbs and what practical fix might solve it without a redesign of
the vertical tail surfaces...
Anybody?
Or from another angle... Does anyone have a Kolb that does NOT exhibit this
behavior...?
Curious Beauford
FF-076, N173BW
Brandon, FL
Then there was the matter of the rudder flutter, take your feet off the
rudder pedals and they would start to shuffle and the tail would start to
wig-wag..
Richard Pike
MKIII N420P (420ldPoops)
donaho1(at)verizon.net
PostPosted: Fri Sep 24, 2010 1:01 pm    Post subject: Aileron flutter and tail-wag Reply with quote
My FSII kit came with the aileron counter weights, so I have never
experienced that flutter problem. I don`t fly with my feet completely
off the rudder peddles, but I do fly with very little pressure on
them. I have never felt them start to flutter. I fly around 60 mph
according to the GPS. Perhaps that isn`t fast enough to induce
flutter. Flutterless is good, so I`ll leave everything as it is. Lanny N598LF
PostPosted: Fri Sep 24, 2010 1:27 pm    Post subject: Aileron flutter and Tail-wag Reply with quote
combination
this
behavior...?
Curious Beauford
Beauford/Gang:
That is also my assumption.
My initial fix was heavy feet.
I finally came up with a bright idea, double rudder pedal springs applied
about the same pressure as heavy feet. Works great, can fly with feet on
the deck and no tail wag.
I have flown a couple Kolbs that did not tail wag, however, I think it is a
Kolb characteristic that no one, that I know of, has died of.
Anybody know of a Kolb that crashed because of tail wag???
7 miles south of Burns Junction, OR
zeprep251(at)aol.com
Beauford,
My MK-3 will do the wag in it's normal configuration,but adding a second set of springs to the rudder cables has all but eliminated it.Brother Pike is the only Kolbster, ( that I know of), that has treated his aircraft with a counter balance and solved the issue.But he now has to deal with birds perching on the balance rod and crapping on the boom tube.A small price to pay for aerodynamic bliss.
G.Aman Mk-3 C Jabiru 2200A 590 hrs.
Ralph B
PostPosted: Fri Sep 24, 2010 1:59 pm    Post subject: Re: Aileron flutter and Tail-wag Reply with quote
My Firestar will do the tail wag with the feet off the rudder pedals only if hit by a strong thermal, otherwise there is none. I can make it quit by bringing it up into a stall. The Kolbra does not have this problem.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
beauford
PostPosted: Fri Sep 24, 2010 4:10 pm    Post subject: Aileron flutter and Tail-wag Reply with quote
John:
Already have the double springs installed, Sir.... not for the wag, but just
because of a general distrust
of springs in general...tail wags anyway...
Most things I mess with either suffer from abrupt unanticipated drop or
directional instability...
So this is no big deal... But would still like to see a picture of the
Reverend Mr. Pike's counterweight
contrivance fer rudders... Are ye out there, Richard?
Beauford
FF-076
Brandon, FL
Thom Riddle
PostPosted: Sat Sep 25, 2010 2:34 am    Post subject: Re: Aileron flutter and Tail-wag Reply with quote
Re: ... Does anyone have a Kolb that does NOT exhibit this
behavior...?
Strangely enough, my Slingshot does not wag its tail without feet on rudder pedals, at least at my normal 65% power cruise of 80mph. Never tried lifting the feet at higher speeds nor lower speeds. I have only a single spring on each rudder pedal. BTW, my ailerons do have the counterbalances and I have never experienced flutter at any speed up to 100 mph, which is as fast as I've flown it.
Not directly related but may be of interest to some:
Funny thing happened since I straightened my gear legs after a bending incident early this summer. Before I unbent my gear legs, the SS would not hold a course for more than a few seconds with my feet off the pedals. After the unbending, in calm air my SS will track straight and true in calm air for quite a while with my feet off the pedals. I'm guessing my unbending job left them a little different aerodynamically than before they were bent. Can't complain about this unintended consequence.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
dsmald(at)aol.com
PostPosted: Sat Sep 25, 2010 5:40 am    Post subject: Aileron flutter and Tail-wag Reply with quote
Curious Beauford,
I have never had any flutter on any surfaces on my FS1 even at VNE. (other than my fabric gap seal which needs new strips of loop velcro..!)
No counter weights, extra springs, trim tabs, etc on any control surfaces. I have long ailerons with 5 rib wings and I can fly without my feet on the pedals. I can actually control the plane to a degree at 50 mph by weight shift by shifting my 190# side to side and also climb / descend by pulling my feet back and stretching them forward.
I guess I got lucky building it?? Sweet flying plane.
Fly safe!
Darren, FS1, 40hp Hirth, Central MI.
>>Time: 01:37:44 PM PST US
From: "Beauford " <beauford173(at)verizon.net (beauford173(at)verizon.net)>
Subject: Re: Aileron flutter and Tail-wag
>Brother Pike:
Anybody?
behavior...?
Curious Beauford
FF-076, N173BW
Brandon, FL
frank.goodnight(at)att.ne
PostPosted: Sat Sep 25, 2010 5:53 am    Post subject: Aileron flutter and Tail-wag Reply with quote
Beauford,
I sometimes fly my firestar 2 for 10 or 15 min at a time with my feet off the ruder -sometimes with them ( my feet)
hanging over the side, no cover on the cage. I really can't tell any difference --feet on or feet off-except
I'll drift off heading after a min or so .
Frank Goodnight
Firestar 2 HKS
Brownsville , TX
Sent: Fri, September 24, 2010 3:29:25 PM
--> Kolb-List message posted by: "Beauford " <beauford173(at)verizon.net (beauford173(at)verizon.net)>
Brother Pike:
Anybody?
behavior...?
Curious Beauford
FF-076, N173BW
Brandon, FL
--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
wig-wag..
Richard Pike
PostPosted: Sat Sep 25, 2010 7:27 am    Post subject: Aileron flutter and Tail-wag Reply with quote
Darren/Gang:
Be aware there are other triggers for flutter than high air speeds. Certain turbulence will set it off at much lower airspeeds in a flash.
Richard Pike
PostPosted: Sat Sep 25, 2010 8:35 am    Post subject: Re: Aileron flutter and Tail-wag Reply with quote
[quote="beauford"]John:
Beauford
FF-076
Brandon, FL
Here's the bird poop perch - what's odd is that I don't get much bird poop below it, but the left side of the horizontal stab constantly gets littered with some sort of little black droppings. Never have figured out exactly what sort of poop it is (I am trying not to get too proficient in that sort of thing) or why it is only at that one place. At least it doesn't stick, the prop blows it away.
http://www.bcchapel.org/pages/0003/pg6.htm
Richard Pike
mdnanwelch7(at)hotmail.co
PostPosted: Sat Sep 25, 2010 10:06 am    Post subject: Aileron flutter and Tail-wag Reply with quote
> Here's the bird poop perch - what's odd is that I don't get much bird poop below it, but the left side of the horizontal stab constantly gets littered with some sort of little black droppings. > Richard Pike
Bro. Richard,
  If you don't want any flying creatures landing on your rudder counterbalance arm, you
might consider building a little contraption I saw once.
  If you make a little device that suspends a couple of loose strings above the length of the
balance arm, birds can't quite land on it, so they pass it up.  Either loose wire or string
will do, maybe one or two strands is all you need.
  With a floppy string in the way, it interferes with the bird being able to get a grip on the
counterbalance arm.  Keep the string sort of close, maybe about 1/4 to 1/2" and the birds
can't wrap their feet around the string and the arm.
  You could probably throw something together in about 10 minutes.  You might consider
a clothes pins or weak finger clamps.  (see attached drawing for an idea of what
I'm getting at)
  Just a thought...
Mike Welch
 Filesize:  19.66 KB
 Viewed:  17921 Time(s)
cedavis
PostPosted: Mon Sep 27, 2010 4:41 am    Post subject: Aileron flutter and Tail-wag Reply with quote
Been offline for a few days, but my Firefly does not exhibit "tail wagging",  In fact, I have flown it "sans-feet" for 20 minutes at a time, just to change leg position on a cross country.    Only needed to put the feet back on the pedals to change position again...the plane is quite happy with out them.
Chuck Davis
Firelfy
N7057K
Smoketown, PA
Brother Pike:
Anybody?
behavior...?
Curious Beauford
FF-076, N173BW
Brandon, FL
wig-wag..
Richard Pike
#avg_ls_inline_popup { position:absolute; z-index:9999; padding: 0px 0px; margin-left: 0px; margin-top: 0px; width: 240px; overflow: hidden; word-wrap: break-word; color: black; font-size: 10px; text-align: left; line-height: 13px;} [quote][b]
JetPilot
PostPosted: Mon Sep 27, 2010 10:06 am    Post subject: Re: Aileron flutter and Tail-wag Reply with quote
My Kolb MK-III Xtra does not have any type of rudder flutter, or tendency to tail wag. When my wife is flying, she keeps her feet on the floor most of the time, my Kolb cruises along happily for an hour without anyone ever touching the rudder pedals. Even in turbulence my wife uses the ailerons only, she never touches the rudder on a cross country because there is no need to.
I have a counterweight on my rudder,, just like the ailerons have. Kolb also put an extra bell crank on the rudder cables of the MK III Xtra, which keeps the rudder cables tensioned just like the elevator. Ever wondered why the elevator never flutters on a Kolb and the rudder does ??? Its those tensioned cables on the elevator that adds mass and resistance to quick movement and flutter. If you do not believe this, just loosen your elevator cables so that they jsut hang there loose, and go fly and see how long it takes for that elevator to flutter Wink Joking aside, NEVER try this, because you probably would not live long enough to get on the ground and report your findings !!!
So the easiest and best solution would seem to be a counterweight on the rudder, just like your ailerons have.
Kolb MK-III Xtra, 912-S
pj.ladd(at)btinternet.com
PostPosted: Mon Sep 27, 2010 11:01 am    Post subject: Aileron flutter and Tail-wag Reply with quote
tail wag. >>
Neither does mine. I have the counterweights fitted AS PER THE PLANS. They
are ON THE PLANS FOR A PURPOSE.
Why do builders try to second guess Homer who quite obviously knew what he
was doing? If he specified counterweights then for crying out loud Fit
counterweights.
On another point. Not using the rudder.Although I agree that you can fly
happily in a straight line without the rudder, changing course or using the
ailerons necessitates using rudder properly.
I learned to fly in gliders where it is important always to present the
minimum frontal area to the airflow because drag represents loss of height
so I never move the stick with automatically applying some rudder. But
beyong that. Applying bank WITHOUT rudder just makes it very, very hard to
get your wing down. With rudder its a doddle. Try appling bank and then
reversing it without rudder. It takes forever and needs muscles like Popeye.
With rudder she slips around easily, as she was designed to do. Use the
rudder.Its there for a reason. Why fight it.?
There are no points for not flying properly.
Pat
PostPosted: Mon Sep 27, 2010 3:25 pm    Post subject: Aileron flutter and Tail-wag Reply with quote
Mike B/Gang:
I don't think your solution is the easiest or the best.
Took me a couple minutes to add two additional rudder pedal springs that
fixed my problem.
Rock House, OR
Jimmy Young
PostPosted: Mon Sep 27, 2010 5:37 pm    Post subject: Re: Aileron flutter and Tail-wag Reply with quote
My FS II has no tail wag issues. I flew over 3 hrs yesterday, mid-day, with lots of thermals & gusty conditions. Looked back at the tail numerous times and it just sits there doing it's job, no wagging around. I dropped in to visit with Robert Laird and we discussed the issue, he said his MK III has no tail wag going on either. I do have very tight tailwires, and have seen some Kolbs with wires that are fairly loose. Maybe that could be a contributing cause.
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
