Richard Pike
Posted: Tue Sep 21, 2010 7:38 pm Post subject: 3 transponder wires |
Finishing up the wiring, hooking up the transponder, and I have to confess that whoever took the transponder out of the wreck (probably me) failed to note down enough information about how to hook it back up.
Coming off the tray is a wire that is obviously the ground, no problem. Another 16 gauge wire is obviously the power supply, once again no problem. But there is one wire left over, it is about 20 gauge, and I have no idea if it goes to hot or ground. Probably hot, but...
The transponder is an RT359A 300, probably out of a Cessna.
Will go around to the local avionics shops tomorrow and ask dumb questions unless someone on here already has an answer.
Richard Pike
MKIII N420P (420ldPoops)
rickofudall
Posted: Tue Sep 21, 2010 8:56 pm Post subject: 3 transponder wires |
Richard, Don't you have to have an input from the sensitive altimeter (the sealed box type, not the Kohlsman type)?
Rick Girard
On Tue, Sep 21, 2010 at 10:38 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
| Quote: | --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
http://forums.matronics.com/viewtopic.php?p=313323#313323
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
by0ung(at)brigham.net Guest
Posted: Wed Sep 22, 2010 6:12 am Post subject: 3 transponder wires |
Coming off the tray is a wire that is obviously the ground, no problem. Another 16 gauge wire is obviously the power supply, once again no problem. But there is one wire left over, it is about 20 gauge, and I have no idea if it goes to hot or ground.Richard Pike
three wires..
power
ground
back light???????
boyd young
Richard Pike
Posted: Wed Sep 22, 2010 7:20 am Post subject: Re: 3 transponder wires |
Back light is possible. I just don't want to apply power to it and have any of the smoke leak out. I don't think Lucas was involved in this unit, and I don't want him getting involved.
And this airplane doesn't have a sensitive altimeter, it just uses the one in the Grand Rapids E I S.
145.08 KB |
4269 Time(s) |
Eugene Zimmerman
Posted: Wed Sep 22, 2010 9:22 am Post subject: 3 transponder wires |
Richard,
Could it be an antenna wire?
Gene
On Sep 21, 2010, at 11:38 PM, Richard Pike wrote:
up.
but...
Richard Pike
