Brake line clips
Z601c(at)anemicaardvark.c
PostPosted: Mon Sep 13, 2010 11:50 am    Post subject: Brake line clips Reply with quote
I'm building a 601XLB. Zenith calls out a brake line clip to hold the brake
lines to the gear. They suggest part # 024-0030. Has anyone located a source
for these, or perhaps a better alternative?
I considered using Adel clamps, or something similar, but that seems a little
kludgey.
Jim B. Belcher
BS,MS Physics, Math, Computer Science
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
DaveG601XL
PostPosted: Mon Sep 13, 2010 12:11 pm    Post subject: Re: Brake line clips Reply with quote
Jim,
Adel clamps may be kludgey, but they stay. I have pictures of the ZAC demo 601XL from both 2006 and 2008 where it is obvious the self-adhesive clips come off with regularity and new ones were re-applied.
An archive search should find where someone made a trailing edge sleeve out of aluminum that encased almost all the brake line run. I remember where someone just used 600 MPH tape and basically did the same thing.
I am currently flying with the adel clamps and am happy with them.
Good luck,
 Filesize:  77.29 KB
 Viewed:  6229 Time(s)
David Gallagher
Cincinnati, OH area
jaybannist(at)cs.com
PostPosted: Mon Sep 13, 2010 1:24 pm    Post subject: Brake line clips Reply with quote
Jim,
I used "home made" clips from .016" 6061-T6. I made a female form in a 2 x 4 and pounded the aluminum strip into the form with a long bolt shaft into the brake line bead, then with a larger pipe for the gear leg part. The photo is a crude one I just made to give you an idea what I am talking about. I used three per gear leg. I originally applied them with JBWeld, but that didn't last long. I re-applied them with a regular epoxy and they stayed on.
Jay Bannister
 Filesize:  161.58 KB
 Viewed:  6225 Time(s)
 Filesize:  1.21 MB
Juan Vega Jr
PostPosted: Mon Sep 20, 2010 9:20 am    Post subject: Brake line clips Reply with quote
zipp ties baby!
Juan
Ron Lendon
PostPosted: Mon Sep 20, 2010 6:52 pm    Post subject: Re: Brake line clips Reply with quote
Hers a link to Gary Rays photo site.
http://picasaweb.google.com/Papawobo/Variations#5139918343502343650
The brake line fairing is made from a piece of Vinyl Gutter Guard from Home Depo. Attach with Gorrilla Glue. (URETHANE GLUE)
Looked like a good idea to me.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
