rnewman(at)tcwtech.com Guest
Posted: Sun Sep 19, 2010 5:09 pm Post subject: Doors and body work |
Fellow builders,
There's been a lot of talk lately regarding doors and seals so I thought I'd offer up my progress ( and photos) . Two albums on the subject listed below.
Some observations along the way:
1) Regarding the door seals: I went the McMaster route, however, when I got done trimming the door jambs back to the proper depth to allow for the bulb on the seal, I went one step further. The door jamb profile doesn't naturally match the U shaped profile of the seal, so the seal would be prone to slipping off without some type of adhesive. I decided to use a scrap piece of the seal profile as a mould to add a filler/epoxy profile back to the door jamb that exactly matches the door seal. I took a 2 foot section of door seal and injected a mix of west system epoxy and structural filler, (used the cake decorator bag trick to fill the U shaped profile) then installed the seal section on the door jamb and let it set- up. Remove the seal and repeat 6 more times around the door jamb until the whole thing has the exact mating profile to the seal. Now the little retaining tang inside the U shaped seal channel has something to grab hold of and the door seals hold onto the door jamb very well.
2) Regarding filling and sanding around the windows: The electrical tape technique for masking off the windows works great, however I found with black electrical tape it was very hard during the sanding process to distinguish between the tape and the filler. I switched to orange electrical tape, a huge improvement!. As I'd sand the filler down to the tape the color of the tape line would really stand out providing much better guidance in terms of sanding depth onto to the tape.
3) Regarding vacuuming up the filler dust: Whilst all this sanding and filling is going on I found that when I would clean up the plane with the shop vac I'd develop an enormous static charge on the plane, then when I touched it, wham! the mother of static shocks would almost knock me down. Solution, I grounded the plane!. Problem solved. I just took an extension cord with a metal box on the end and laid it in the tail of the plane. All better.
http://picasaweb.google.com/rcnewman64/BodyWork#
http://picasaweb.google.com/rcnewman64/DoorsLatchesSeals#
Bob Newman
TCW Technologies, LLC
www.tcwtech.com
builder #40176
Posted: Sun Sep 19, 2010 8:06 pm Post subject: Doors and body work |
One thing I will caution is don’t use the vacuum when brooming will work. The fiberglass will literally destroy the shop vac. In my case the dust was fine enough to clog the filter and cause the vac to overheat or something, it literally started to spark and smoked and that was the end of a very reliable vac I had for years.
If one is going to vacuum, and I do when needed, clean the filter often
Take it for whatever it's worth.
Pascal
Sent: Sunday, September 19, 2010 6:01 PM
Subject: Doors and body work
Fellow builders,
Bob Newman
www.tcwtech.com
builder #40176
Posted: Mon Sep 20, 2010 3:57 am Post subject: Doors and body work |
Sorry to hear of the loss of family friend ....
Best advice is clean often. I have three vacs .... a Sears shop vac that converts into a leaf (and hangar) blower and two smaller ones. The Sears has a pleated paper filter and the smaller ones use a foam filter. I bought a kit that uses a microfiber cloth to cover the foam filters ....... because the foam filters still let a lot of 'dust' through. I can wash these and re-use or just blow them off after each use. I haven't found anything to cover the large paper filter, but shop air cleans it really well if done often.
The reason I've gone this route is because of a friends surfboard shop ..... and his central vac ..... that got clogged with foam dust and burnt like Pascal's. Any light material coats the filter reducing airflow .... and that motor really needs it for cooling. Sand, however, seems to fall into the bottom of of the vac without clinging to the filters.
Pascal's advice to clean often is spot on!!!
Linn
BTW, I use my leaf blowers to clean the shop (I have a big door on the shop) and hangars because it gets underneath stuff where a broom won't go .......
On 9/20/2010 12:04 AM, Pascal wrote: [quote] 3) Regarding vacuuming up the filler dust:
Pascal
Neal.George(at)hurlburt.a Guest
Posted: Mon Sep 20, 2010 4:38 am Post subject: Doors and body work |
Check your local hardware store for shop vac filter bags designed for
drywall dust. Much better than the pleated filter alone.
neal
One thing I will caution is don't use the vacuum when brooming will
Pascal
MauleDriver(at)nc.rr.com Guest
Posted: Mon Sep 20, 2010 6:14 am Post subject: Doors and body work |
The secret weapon for my Shop Vac is to use the optional filter bag. I have a "shop-vac" from Lowes or HomeDepot. It comes with a foam filter covering the fan input but disposable filter bags are sold as an option. The bag captures virtually all dust keeping not only the exhaust dust free, but also the inside of the vacuum. It has a lot of surface area so it doesn't immediately clog. Very effective. I figured this one out when doing some concrete grinding in the house.... there are things worse than fiberglass.
If you are using a standard wet/dry shop vac - get and use a filter bag for better results. Change it with reasonable frequency.
Fiberglass, sandpaper, and a bagged shop vac - we're attached at the hip. Now if I just had a remote control for the thing.
Will try to attach pic...
Bill "taking a last pass on the doors" Watson
On 9/20/2010 7:49 AM, Linn Walters wrote: | Quote: | Sorry to hear of the loss of family friend ....
Linn
On 9/20/2010 12:04 AM, Pascal wrote: | Quote: | 3) Regarding vacuuming up the filler dust:
Pascal
841.04 KB |
6894 Time(s) |
partner14
Posted: Mon Sep 20, 2010 6:15 am Post subject: Doors and body work |
One last little piece of advise... buy an extension for the vacuum so you can put it outside while vacuuming. We also did this when removing a tile floor in the house. Keeps the fine dust OUT.
Don
--- On Mon, 9/20/10, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Subject: Re: Doors and body work
Date: Monday, September 20, 2010, 4:49 AM
Linn
Pascal
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
40636 |
Posted: Mon Sep 20, 2010 7:41 am Post subject: Doors and body work |
I have a HF air nozzle that I use to blow the excess off the ground etc. I also use it to blow dust off the foam filter- amazing how much come out of the filters even after I "think" it was cleaned.
Sent: Monday, September 20, 2010 4:49 AM
Linn
Pascal
kearney
Posted: Mon Sep 20, 2010 7:43 am Post subject: Doors and body work |
Your trick for making a profile on the door edge is positively brilliant. Given that I really don't want to ever finish my doors, I may try that as well.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw
Sent: September-19-10 7:02 PM
Fellow builders,
Bob Newman
www.tcwtech.com
builder #40176
jchang10
Posted: Mon Sep 20, 2010 8:11 am Post subject: Doors and body work |
Hahaha, I absolutely agree with both Les and Bob.
Bob, you forgot to put up a warning, "This post could cause you countless more hours of work."
I am on a parallel track and glad to see similar things from someone else. My door frame looked similar to yours after trimming for mcmaster seals. Especially along the forward edge, near that elbow bend, I was worried about making it too thin, but I see you had the same experience.
I wish I had known about the wonderful qualities of using electrical tape for masking work earlier. It easily bends around corners and won't tear, which both masking tape and blue painters tape will not do easily.
Still on the fence about doing the door edge work. Wish I had bought some extra door seal material.
Jae
40533
On 9/20/2010 8:41 AM, Les Kearney wrote: [quote] Bob
Cheers
Les
#40643
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Posted: Mon Sep 20, 2010 9:52 am Post subject: Doors and body work |
Jae, I too used electrical tape for some window masking. Not sure what you refer to as "Blue painters" and "masking" tapes but if you mean the paper type tapes, yes, agreed that the electrical tape works great for corners and stuff.
What I subsequently found out was that 1/2" blue 3M plastic tape #471 is better than plain electrical tape. One difference is that the #471 doesn't stretch like electrical tape (a desirable characteristic for electrical work). It stretches just enough to go around corners but not enough to distort and subsequently pull away. By not stretching so much, I found that lays down a straighter line and that it won't pull off from the corners as the electrical tape tends to do if you stretch around corners. 1/2" works much better than 3/4" when going around corners and is the only size I'm using.
For gross masking, I'd suggest the product 1-up from seems to be sold as blue painters tape. I've been using Scotch 233+ with 1.5" having the most utility. It's a light green. The adhesive is better and it's just clearly better stuff. They seem to have a blue and some other line 1 up from the green too. I'll probably learn the hard way when and where the 1-up from green is needed. At this point, I"m just up to high fill primer on the glass and interior paint.
For you first time painters, the best thing you can do is find a local paint distributor and ask a lot of questions and buy all your stuff there. Prices are better than Home Depot and they sell key stuff in large sizes like rolls of adhesive sandpaper and big cheap rolls of cheap-good-excellent quality masking papers. Somebody in there is probably real knowledgeable and might get a kick out of your project.
On 9/20/2010 12:09 PM, Jae Chang wrote: [quote] Hahaha, I absolutely agree with both Les and Bob.
Jae
40533
Posted: Mon Sep 20, 2010 6:24 pm Post subject: doors and body work |
The idea of grounding the plane is great, but wasteful. I hooked my wiring to the vacuum and used the electricity to power it. Kind of like perpetual motion. Maybe I can store up the charge from all the work, including sanding and I will forget the gas for the first flight.
speckter(at)comcast.net Guest
Posted: Tue Sep 21, 2010 5:03 am Post subject: doors and body work |
Is John the recipient of some of that government money for wind generators?
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Monday, September 20, 2010 10:22 PM
To: RV 10 group
Subject: doors and body work
daveleikam(at)wi.rr.com Guest
Posted: Tue Sep 21, 2010 5:41 am Post subject: doors and body work |
Sounds like good, "Green" technology.
Dave Leikam
