		sprocket(at)vx-aviation.c Guest
				 Posted: Wed Sep 15, 2010 3:52 pm    Post subject: toe-in/toe-out |
				What's the group feeling for the amount of  toe-in/toe-out required for an HR-II?  I have specs for the F1, but nothing  for the HR-II.  I've lurked on the F1 forum and there's some debate on  this.
  Thanks, Vern
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		hr2pilot(at)aol.com Guest
				 Posted: Wed Sep 15, 2010 4:09 pm    Post subject: toe-in/toe-out |
				Set it at 0
 On Sep 15, 2010, at 4:49 PM, "Vern Little" <sprocket(at)vx-aviation.com (sprocket(at)vx-aviation.com)> wrote:
 [quote]  What's the group feeling for the amount of  toe-in/toe-out required for an HR-II?  I have specs for the F1, but nothing  for the HR-II.  I've lurked on the F1 forum and there's some debate on  this.
  Thanks, Vern
		lschneider39(at)cox.net Guest
				 Posted: Wed Sep 15, 2010 6:26 pm    Post subject: toe-in/toe-out |
				Yep
 On Sep 15, 2010, at 6:07 PM, "Larry Schneider" <lschneider39(at)cox.net (lschneider39(at)cox.net)> wrote:
 [quote]  And would that be set in a level flying attitude  John? like I would do.
				 Posted: Wed Sep 15, 2010 8:58 pm    Post subject: toe-in/toe-out |
				Thanks for the quick reply.  I will set it to  zero in the unloaded condition.  I also presume that the flats on the gear  legs should be set at 90 degrees to the firewall.
  Vern
  Sent: Wednesday, September 15, 2010 7:21 PM
  To: rocket-list(at)matronics.com (rocket-list(at)matronics.com)
  Subject: Re: toe-in/toe-out
  Yep
				 Posted: Wed Sep 15, 2010 9:21 pm    Post subject: toe-in/toe-out |
				Yep
 On Sep 15, 2010, at 9:54 PM, "Vern Little" <sprocket(at)vx-aviation.com (sprocket(at)vx-aviation.com)> wrote:
 [quote]  Thanks for the quick reply.  I will set it to  zero in the unloaded condition.  I also presume that the flats on the gear  legs should be set at 90 degrees to the firewall.
  Vern
  To: [url=mailto:rocket-list(at)matronics.com]rocket-list(at)matronics.com (rocket-list(at)matronics.com)[/url]
  Yep
 On Sep 15, 2010, at 6:07 PM, "Larry Schneider" <[url=mailto:lschneider39(at)cox.net]lschneider39(at)cox.net (lschneider39(at)cox.net)[/url]>  wrote:
		vwbugin(at)sbcglobal.net Guest
				 Posted: Thu Sep 16, 2010 7:40 am    Post subject: toe-in/toe-out |
				Hey John,
 I thought you wanted to set it to zero with the plane in a level flying attitude and weight on the gear. Not in an un-loaded condition as in the previous post.
 I got 4 steel plates approximately 12" square 2 for the left an two for the right. Put grease between them, rolled the mains up on them, leveled the airplane then set the toe in.
 We have done this on several airplanes and none of them have tire where issues.
 Steve
  Vern
  Yep
				 Posted: Thu Sep 16, 2010 6:28 pm    Post subject: toe-in/toe-out |
				Hmmm.  John is the design authority, but I've  read Vince's posts on the F1 Forum that uses the greasy-plate technique.   However, it's my recollection that the geometry of the gear is different on the  HR-II and the F1, so I'm reluctant to blindly follow along the F1  recommendations.  Until this is resolved, I'm not drilling the  feet!
  Vern
  Sent: Thursday, September 16, 2010 8:36 AM
  Hey John,
  Steve
    Vern
    Yep
				 Posted: Thu Sep 16, 2010 7:35 pm    Post subject: toe-in/toe-out |
				Vern,
 I guess I miss understood. I thought you had already drilled the feet and were doing a final alignment. The un-loaded condition is correct for the mounting of the feet, that will get you close. Usually the gear will require an adjustment once the plane is complete. That's where the greased plates come in. That process will help you take final measurements and shim the axles to achieve the zero toe in.
 Steve
 Date: Thursday, September 16, 2010, 6:33 PM
  Vern
   From: [url=/mc/compose?to=vwbugin(at)sbcglobal.net]Steve[/url]
  To: [url=/mc/compose?to=rocket-list(at)matronics.com]rocket-list(at)matronics.com[/url]
  Hey John,
  Steve
 On Sep 15, 2010, at 9:54 PM, "Vern Little" <[url=/mc/compose?to=sprocket(at)vx-aviation.com]sprocket(at)vx-aviation.com[/url]>  wrote:
    Vern
       From: [url=/mc/compose?to=hr2pilot(at)aol.com]John Harmon[/url]
    Subject: Re: Rocket-List: toe-in/toe-out
    Yep
				 Posted: Thu Sep 16, 2010 9:27 pm    Post subject: toe-in/toe-out |
				OK, I get it.  zero toe-in when drilling the  feet (I'm leveling the engine mount on the bench and will mount the feet at 90  degrees to this).  Adjusting loaded toe-in comes later.
  Thanks guys!
  Sent: Thursday, September 16, 2010 8:26 PM
             Vern,
 Steve
 From:          Vern Little <sprocket(at)vx-aviation.com>
          Vern
          Hey John,
          Steve
            Vern
            To:  (rocket-list(at)matronics.com)rocket-list(at)matronics.com (rocket-list(at)matronics.com)
            Yep
 On Sep 15, 2010, at 6:07 PM, "Larry Schneider" < (lschneider39(at)cox.net)lschneider39(at)cox.net (lschneider39(at)cox.net)>            wrote:
