MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Thu Sep 16, 2010 5:44 am Post subject: Turnbuckle Location |
Is there any reason I can't reverse the location of the turnbuckle on my upper elevator control cable. The drawings show it located at the bottom of my y control stick. I'd like to put it under my removable fiberglass saddle attaching directly to the upper horn to make it much easier to adjust. Doesn't sound like fun trying to safety wire in that tight space.
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
Z601c(at)anemicaardvark.c Guest
Posted: Thu Sep 16, 2010 6:01 am Post subject: Turnbuckle Location |
On Thursday 16 September 2010 08:44:50 you wrote:
<michaelherder(at)beckgroup.com>
I don't have the "Y" stick, but the turnbuckles are just as awkward for the
dual stick design.
I did pretty much what you're suggesting, and also moved some of the other
turnbuckles. It seems to me that the turnbuckles, and perhaps a few other
things, are not located where they can be adjusted as easily as is desirable.
Jim B. Belcher
BS,MS Physics, Math, Computer Science
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
jaybannist(at)cs.com Guest
Posted: Thu Sep 16, 2010 6:25 am Post subject: Turnbuckle Location |
Mike,
That is where I put mine. It only makes good sense, for the reasons you point out. . I forgot to cotter the castle nut at the bottom connection in the arm rest tunnel. It was impossible for me to install it and I planned to put an access panel in the floor panel. Doug Eady came to my rescue and installed the cotter from above. It still seemed impossible for me. I also made the rudder fairing saddle removable.
Jay
flyboy3847(at)onecommail. Guest
That's the way we did it. We've got 100 hours on our 601HD without a hint
of trouble.
Leroy Wheeler
trainnut01(at)aol.com Guest
Posted: Thu Sep 16, 2010 6:49 am Post subject: Turnbuckle Location |
I put mine in the rear fuselage,as close to the fairleads as possible without interfering with anything. They are all accessible through the bottom hatch.
Carroll
steerr(at)bellsouth.net Guest
Posted: Thu Sep 16, 2010 7:41 am Post subject: Turnbuckle Location |
That's what I did and I'm glad I did it since I've had to adjust the elevator control twice now. I used a clip-locking turnbuckle there - much easier than the ones that use safety wire.
Bill
On 9/16/2010 9:44 AM, MHerder wrote: [quote] | Quote: | --> Zenith601-List message posted by: "MHerder" <michaelherder(at)beckgroup.com> (michaelherder(at)beckgroup.com)
| [b]
don.honabach(at)pcperfect Guest
Posted: Thu Sep 16, 2010 10:22 am Post subject: Turnbuckle Location |
| Quote: | | >> Doesn't sound like fun trying to safety wire in that tight space. |
I’ve got some turnbuckles installed that would be difficult to impossible to use the safety wire on – for instance at the front of rudder pedals and in the center console area for the elevator that you mentioned. I’d highly recommend going with the clip locking turnbuckles over the safety wire ones – easy to adjust no matter what the location sort of thing and far quicker/easier to deal with in general.
I personally don’t like the adjustable bits of the plane on the “outside”, but I can’t see any reason not to – just make sure if the cable shakes or the distance it will be traveling doesn’t cause it to run/catch on anything.
Don
601HDS – 150 Hours – Jabiru 3300A
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Bill Steer
Sent: Thursday, September 16, 2010 8:36 AM
Subject: Re: Zenith601-List: Turnbuckle Location
Bill
On 9/16/2010 9:44 AM, MHerder wrote: | Quote: | | --> Zenith601-List message posted by: "MHerder" <michaelherder(at)beckgroup.com> (michaelherder(at)beckgroup.com) Is there any reason I can't reverse the location of the turnbuckle on my upper elevator control cable. The drawings show it located at the bottom of my y control stick. I'd like to put it under my removable fiberglass saddle attaching directly to the upper horn to make it much easier to adjust. Doesn't sound like fun trying to safety wire in that tight space. &nbs===================== the many List utilities such as List Un/Subscription,[/b]http://www.m=====================<; - MATRONICS WEB FORUMS -[/b]http://forums.matronics.com<; - List Contributionp; -Ma http://www.matronics.com=[/b] | 0
jlatimer1(at)cox.net Guest
Posted: Thu Sep 16, 2010 11:38 am Post subject: Turnbuckle Location |
Mike,
I had the same concerns. I installed my upper elevator turnbuckle where you proposed. 30 hours on the plane and no problems.
Jerry
601HDS 912 N316JL
---- MHerder <michaelherder(at)beckgroup.com> wrote:
[quote] --> Zenith601-List message posted by: "MHerder" <michaelherder(at)beckgroup.com>
