dickbutz
Posted: Sun Sep 12, 2010 10:20 am Post subject: Props? |
I know that this has most likely been beaten to death but I need help in choosing a prop...
I had a big ding in my original (63 pitch) Sensenich prop so I bought a new one (a 62 pitch), however I now have the original one at Sensenich being serviced as they said that there was plenty of metal in the prop to cut away and straighten the bad edge (it was only a 1/32 ding and the tip was not touched)...What I need to know is which is the prefered prop for speed the 62 or the 63 pitch or is there not much in it either way as I will change to the fastest one and sell the other.
The interesting thing is that there actually was more metal in the older prop than the newer one, both wider and longer???...Dick
_________________ Dick Butz
1979 Tiger N4532P |
flyadive(at)gmail.com Guest
Posted: Sun Sep 12, 2010 11:46 am Post subject: Props? |
Dick:
Go with the 63"
I have a 62" on my O-320 HC and I have no problem with climb on the east coast.
You have an O-360 so 63" should be NO PROBLEM.
Barry
On Sun, Sep 12, 2010 at 2:20 PM, dickbutz <dickbutz(at)therock.bm (dickbutz(at)therock.bm)> wrote:
[quote] --> TeamGrumman-List message posted by: "dickbutz" <dickbutz(at)therock.bm (dickbutz(at)therock.bm)>
Dick Butz
1979 Tiger N4532P
http://forums.matronics.com/viewtopic.php?p=312217#312217
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
le, List Admin.
teamgrumman(at)YAHOO.COM Guest
Posted: Sun Sep 12, 2010 1:55 pm Post subject: Props? |
Which prop is better depends on a whole slew of things.
(1) is the engine strong? or is it tired?
(2) Any drag reduction items? Wheel pants? or does it have a bunch of antennas sticking out?
(3) Ported and polished cylinders?
(4) Is your plane fat? i.e., what is it's empty weight (the real one, not the one you carry on the weight and balance)
(5) Do you normally fly by yourself?
I've tried everything up to a 69 inch pitch on my plane. It likes a 65.
A 62 prop is pretty good all around. A 63 is a pretty good prop if you have a strong engine and your plane isn't fat.
Sent: Sun, September 12, 2010 11:20:11 AM
Subject: Props?
Dick Butz
1979 Tiger N4532P
Read
dickbutz
Posted: Sun Sep 12, 2010 3:02 pm Post subject: Re: Props? |
The engine is mid time and the lowest compression is 72 (the rest above 75)
The usual antennas and wheel pants ...New paint and glass
No, stock
Book weights not excessively heavy
Mostly by myself but 1/2 the time with a co-pilot
Looks like I will put the 63 back on but will this make much difference in ground speed?...Dick
| New Paint N4532P, 1979 Tiger |
1.67 MB |
7777 Time(s) |
1979 Tiger N4532P |
flyv35b(at)minetfiber.com Guest
Posted: Sun Sep 12, 2010 3:34 pm Post subject: Props? |
If you want more speed at the same rpm I'd go with the 63" pitch as that was
the standard cruise prop. Most typical Tigers can turn 2700 rpm full
throttle down low and even higher up. The 62" pitch will turn 30-40 rpm
more at full throttle but be 2-3 knots slower or thereabouts. And if you
ever take you steps off and go to the flush beacon cap or add a PF exhaust
you will want the higher pitch prop for sure.
Cliff A&P/IA
n2_narcosis(at)YAHOO.COM Guest
Posted: Mon Sep 13, 2010 7:09 pm Post subject: Props? |
So Cliff,
Is it legal to take your steps off? What paperwork is involved if any, 337 etc? "Steps I don't need no stinking steps." When I am old enough to need steps I'll do what the old timers do in their Yankees. Carry around a stool with a rope tied to it.
Brock
76 Tiger
--- On Sun, 9/12/10, flyv35b <flyv35b(at)minetfiber.com> wrote:
[quote] From: flyv35b <flyv35b(at)minetfiber.com>
Subject: Re: Props?
Date: Sunday, September 12, 2010, 6:31 PM
posted by: "flyv35b" <flyv35b(at)minetfiber.com>
pitch as that was the standard cruise prop. Most
typical Tigers can turn 2700 rpm full throttle down low and
even higher up. The 62" pitch will turn 30-40 rpm more
thereabouts. And if you ever take you steps off and go
to the flush beacon cap or add a PF exhaust you will want
Cliff A&P/IA
garnerrice(at)hotmail.com Guest
Posted: Tue Sep 14, 2010 4:39 am Post subject: Props? |
The steps were optional equipment on the Grummans as well as many other items. If the part number starts with 580xxxx,l then typically it was an option for the aircraft.
Garner
> Date: Mon, 13 Sep 2010 20:07:03 -0700
[quote] From: n2_narcosis(at)YAHOO.COM
Subject: Re: Props?
--> TeamGrumman-List message posted by: Brock Windsor <n2_narcosis(at)yahoo.com>
So Cliff,
Brock
76 Tiger
> Subject: Re: Props?
> To: teamgrumman-list(at)matronics.com
> Cliff A&P/IA
Posted: Tue Sep 14, 2010 4:40 am Post subject: Props? |
Absolutely. Look at your equipment list. The steps are shown as an
optional item and can be removed with a log book entry and weight and
balance change.
Cliff
dickbutz
Posted: Tue Sep 14, 2010 6:55 am Post subject: Re: Props? |
How much speed can you pickup by removing the steps and light?...I have been down this road before and found very little result for the money invested...Seriously the steps produce that much drag?...Dick
Cliff A&P/IA
1979 Tiger N4532P |
Posted: Tue Sep 14, 2010 9:10 am Post subject: Props? |
It might be worth a knot or two to remove the steps. Is it worth it? Probably (k)not.
Sent: Tue, September 14, 2010 7:55:51 AM
Subject: Re: Props?
Cliff A&P/IA
Dick Butz
1979 Tiger N4532P
Posted: Wed Sep 15, 2010 4:39 am Post subject: Props? |
Combined, probably about 2 kts as I recall and it doesn't cost much to do.
The flush beacon cap is primarily a cosmetic mod and you have decide if you
are happy without having a step to get up on the wing. All of these "small"
drag reduction things are cumulative and can add up to significant gains.
Cliff
