olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Sun Sep 12, 2010 11:46 am Post subject: Need advice for brake brackets |
I have decided to replace the drum brakes on my Firestar with mountain bike mechanical discs. I was flying with an Aerolite yesterday and it looked like his brakes would work well for me. I need to create the bracket to hold the caliper as well as a bracket to attach the disc to the hub. I'm looking for recommendation as to the type of metal to use. I attached a picture so you can see the Aerolite setup.
It looks like aluminum will work. Not sure of the thickness or alloy I would need. What do you guys think?
198.7 KB |
3920 Time(s) |
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
rickofudall
Posted: Sun Sep 12, 2010 12:04 pm Post subject: Need advice for brake brackets |
Scott, I think 1/8" 2024-T3 or 6061-T6 would be fine for the plates. If it were me, I'd go with the 2024-T3 and alodine for corrosion protection. If you don't want to do the alodine, the 6061-T6 will do better even though it is a bit weaker (about 20%) than the 2024-T3.
Rick Girard
On Sun, Sep 12, 2010 at 2:46 PM, olendorf <olendorf(at)gmail.com (olendorf(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "olendorf" <olendorf(at)gmail.com (olendorf(at)gmail.com)>
Scott Olendorf
Schenectady, NY
http://forums.matronics.com/viewtopic.php?p=312221#312221
http://forums.matronics.com//files/bracket1_100.jpg
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
herbgh(at)nctc.com Guest
Posted: Sun Sep 12, 2010 1:37 pm Post subject: Need advice for brake brackets |
I built my mtn bike brakes attachments pretty much as in the picture
that you sent...I used 6061 t6 .062 to mount the caliper... I used
bushing stock as spacers with through bolts to locate the disk ...Herb
At 02:46 PM 9/12/2010, you wrote:
Aerolite setup.
Scott Olendorf
Schenectady, NY
olendorf
Posted: Sun Sep 12, 2010 2:44 pm Post subject: Re: Need advice for brake brackets |
Great, I went ahead and ordered the 6061-T6 in the .125
Thanks guys.
Schenectady, NY
