Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Sat Sep 11, 2010 11:12 am Post subject: GTX 330 screen |
(Also posted on VAF, but I seem to get a larger response here)
After powering up my panel the only issue I have not been able to resolve easily is my transponder. It is receiving power and turns on and off as evidenced by the screen going turning on. However, the entire screen is a field of green. Every pixel is illuminated so there is no text or anything to read on the screen. I haven't found anything in the operator or maintenance manual to help me with this. Anyone have an idea what may be going on, or seen this before?
Eric Kallio
Putting the little pieces of an RV-10 into on big piece.
Tim Olson
Posted: Sat Sep 11, 2010 2:48 pm Post subject: GTX 330 screen |
My guess is that either the backlight setting has some issue,
or the backlight sensor...or the contrast is set way off.
Not sure which it would be, but it sounds like it may be one
of those issues. Might need a call to garmin on that one,
if the dealer can't help you.
Tim Olson - RV-10 N104CD
On 9/11/2010 2:12 PM, Eric_Kallio wrote:
Eric Kallio
http://forums.matronics.com/viewtopic.php?p=312157#312157
