K Dilks
Posted: Wed Sep 08, 2010 6:22 am Post subject: Dynon D100 : Where to mount compass unit |
Hi all
Well I am up to doing the electrical stuff and was wondering were folks are putting the compass unit that comes with the D100.
I was hoping to put it up behind the D100 but looks like there may be some power cables near enough to upset it.
Any pictures would also be appreciated
Kevin
_________________ Back home ................. |
tigerrick(at)mindspring.c Guest
Posted: Wed Sep 08, 2010 6:55 am Post subject: Dynon D100 : Where to mount compass unit |
Hey, Kev.
I had to move the magnetometer on my Blue Mountain installation three times before I found a location that wasn't affected by random magnetic fields from ferrous airframe components. Even the control cables (steel) caused a reverse sensing between east and west! But north and south were OK, go figure!
I finally ended up going down the tail cone, and mounting the unit with plastic screws to the top of fuselage from the inside, about 2 feet forward of the rudder. Works OK there.
Rick
N42KP, Upgrade Close to DONE! Yay!!
psm(at)att.net Guest
Posted: Wed Sep 08, 2010 6:57 am Post subject: Dynon D100 : Where to mount compass unit |
Hi Kevin,
I put mine on the fuselage floor under the baggage compartment.
A photo is attached . . .
Paul
XL upgrading second wing
34.44 KB |
18305 Time(s) |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Sep 08, 2010 7:44 am Post subject: Re: Dynon D100 : Where to mount compass unit |
Kevin,
My remote compass is mounted in about the same place as Paul's. I placed it behind the access hatch, but I also made made a mounting bracket to level the unit. The Dynon instructions say to mount the compass within 1 degree of the panel mounted unit, a D180 in my case, in pitch, roll and yaw. Since the fuselage slopes upward towards the tail, my bracket counters that slope. Picture attached.
This has worked very well for me in the 2+ years I have been flying.
Good luck,
121.34 KB |
18295 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Thu Sep 09, 2010 2:22 am Post subject: Re: Dynon D100 : Where to mount compass unit |
Well I thought it came internally with the D100?
so you have to set up a remote compass for the D100?
another thing to write down
Chris..
Posted: Thu Sep 09, 2010 2:40 am Post subject: Dynon D100 : Where to mount compass unit |
Hi Chris,
Yes, you need to mount the remote magnetic sensor and run a cable to it.
The Dynon unit comes with extensive instructions which talk all about this
and other installation issues.
Good luck,
Paul
sonar1@cox.net
Joined: 02 Oct 2007 Posts: 55 Location: Santa Barbara, Ca
Posted: Thu Sep 09, 2010 8:21 am Post subject: Re: Dynon D100 : Where to mount compass unit |
I mounted mine on the floor as far back as I could reach, and only ran a hot lead to the aft nav light, grounding the ground lead at the tail. The wires were high up on the side of the fuselage, but still affected the compass.
Discovered that when I turned on the nav lights the compass swung 10 degrees. Had to run both a hot and a ground twisted pair to the tail nav light.....Fred
AZFlyer
Posted: Sat Sep 11, 2010 3:14 pm Post subject: Re: Dynon D100 : Where to mount compass unit |
Kevin,
from the FWIW column...
Here's a pic of my solution. Not difficult if you have the trap door in.
They tell me this unit must be pretty close level with longerons and side to side.
294.59 KB |
18210 Time(s) |
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
chris Sinfield
Posted: Fri Oct 28, 2011 10:03 pm Post subject: Re: Dynon D100 : Where to mount compass unit |
guys and girls
when you mounted the Compass unit down the back, where did you run the cable from the Dynon 100?
I was thinking down the LH side above the vertical uprights ,although that is also where my flap motor and trim wires are.
Would moving the flaps or trims electrically cause an issue to the heading in that location ?
Chris
Posted: Sat Oct 29, 2011 1:36 am Post subject: Dynon D100 : Where to mount compass unit |
Hi Chris,
That seems to work fine for me. The cable to the magnetic sensor is a
computer style digital connection with good shielding. I think there is
a small processor in the magnetic unit. I have not seen any strange
behavior on mine, and the wires are all bundled together going to the
rear of the cockpit.
Paul
XL 20 hours into flight testing.
On 10/28/2011 11:03 PM, chris Sinfield wrote:
guys and girls
Chris
http://forums.matronics.com/viewtopic.php?p=356247#356247
aprazer
Posted: Sun Oct 30, 2011 7:36 am Post subject: Re: Dynon D100 : Where to mount compass unit |
Greetings,
Why weren't you guys around when I was looking for a OAT location? I like the vent idea!
Mine is under the stabilizer - also out of the direct sun light.
Mack
_________________ The poh-oh-unemployed farm boy from Idaho |
