dim able strip LED lighting
Goto page 1, 2  Next
chris Sinfield
PostPosted: Mon Sep 06, 2010 3:38 am    Post subject: dim able strip LED lighting Reply with quote
Hi all
I was going to use the new Dim-able LED strip lighting for under the Inst combing for my NVFR aircraft
they come in red or blue. never really used blue before ??
Anyone used these yet?? do the dimmers come with the strip LED's or do you have to buy them separately.
Chris
mdnanwelch7(at)hotmail.co
PostPosted: Mon Sep 06, 2010 6:01 am    Post subject: dim able strip LED lighting Reply with quote
Chris
Chris,
  Irrespective of the different colors of LEDs, you have to keep in mind
specifically what you are using the LED for.
  Blue panel LEDs may look "cool" but they are NOT appropriate for use
as a night lighting.  Blue light is a shorter wavelength than red, and this
aspect does not work as well for rapidly adjusting light/dark conditions
as red.
  Red light has a longer wavelength than blue, and this phenomenon allows
the human eye to adjust quicker from a dark environment to a red lit
environment than blue lighting.
  This is the reason aircraft cockpit lighting is red.  When you look outside at
night while flying, and then look back inside at the instruments, the red lit
instruments don't mess up your vision (light receptors) as much as any other
color wavelength will.
Mike Welch
sprocket(at)vx-aviation.c
PostPosted: Mon Sep 06, 2010 7:52 am    Post subject: dim able strip LED lighting Reply with quote
Here's an interesting article http://stlplaces.com/night_vision_red_myth/.
In my cockpit, I only use low-level white dimmable lighting for the express purpose of reading charts at night. Charts require white light in order to see all of the colors. When not reading charts, all of the modern instruments have their own back-lights, which are kept dim. Looks like red flood lighting is useful for general night lighting.
Vern
Sent: Monday, September 06, 2010 6:17 AM
Subject: RE: dim able strip LED lighting
Chris
Chris,
as red.
Mike Welch
RV7ASask
PostPosted: Mon Sep 06, 2010 8:06 am    Post subject: Re: dim able strip LED lighting Reply with quote
I have installed a strip of white dimable LEDs above my switches. They work great! The strip happens to be 3/8 in wide and fit perfectly into an aluminum channel integrated at the bottom of the panel. I would agree with Vern. Stick with white. The dimmer is available from Spruce.
http://www.aircraftspruce.ca/catalog/elpages/pwmDimmer.php
David
tim2542(at)sbcglobal.net
PostPosted: Mon Sep 06, 2010 8:45 am    Post subject: dim able strip LED lighting Reply with quote
According Stein-air’s web site Blue is now the standard color on commercial and military aircraft….FWIW
Tim Andres
(rnbraud(at)yahoo.com)
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Welch
Subject: RE: AeroElectric-List: dim able strip LED lighting
> Chris
Chris,
as red.
Mike Welch
No virus found in this incoming message. Checked by AVG - www.avg.com 271.1.1/3117 - Release Date: 09/05/10 23:35:00 [quote][b]
riggs_la(at)yahoo.com
PostPosted: Mon Sep 06, 2010 12:34 pm    Post subject: dim able strip LED lighting Reply with quote
White is not good for your night vision. The military has found that a
blue-green light is the best in night operations.
Lynn
gerry.vandyk(at)shaw.ca
PostPosted: Mon Sep 06, 2010 3:46 pm    Post subject: dim able strip LED lighting Reply with quote
That is rather curious. Amateur astronomers use red flashlights at night
when looking at their charts, the reason being red light doesn't cause the
eye's iris to close, which kills dark adapted vision. When observing
objects through larger telescopes one can occasionally pick up a blue-green
color in subjects like the Ring Nebula (M57)the reason being the color
receptors in the retina pick up the middle of the visible spectrum (520
nanometer wavelength)at the lowest light levels. I have a suspicion that
this study determined that blue-green is the easiest to see, which is
different than the best color for preserving night vision.
http://www.oneminuteastronomer.com/astro-course-day-5/
I would suggest doing some research into WWII night fighters. For one, the
P-61 Black Widow used red cockpit lighting. Red allows you to look at the
instruments, then look out the window without having to wait for your eyes
to re-adapt to the darkness.
Gerry
PostPosted: Mon Sep 06, 2010 4:36 pm    Post subject: dim able strip LED lighting Reply with quote
Gerry
Gerry,
  This tendency of the red light not affecting the iris' closing, was what I getting at.
You offered more detail than me, and you're correct.  I think that this is also why darkrooms
for developing film are lit with red lights.
  My Cessna(s) had red cockpit lighting.  Like I said initially, you have to determine the
primary purpose of the LED lighting.  If you want to see things inside the cockpit, and
not screw up your night vision, use red.  If you want to be able to see something very
well in the dark, like an instrument, use blue/green lighting (and you can turn down the
brightness a lot).
Mike Welch
n8zg(at)ATT.NET
PostPosted: Mon Sep 06, 2010 5:59 pm    Post subject: dim able strip LED lighting Reply with quote
Ummm… No.
Darkroom lamps are red because black & white photo paper will tolerate low levels of red light – film will not tolerate ANY light. I’ll suggest that red light in the cockpit descended from the photo world, where folks had been working in very low light levels for many decades before there were lights in airplanes…
Working in a darkroom will give you a completely different perspective on the red-light/night-blind transition. We go from low-intensity red ambient to low intensity white (enlarger lamp on to set-up, crop the print, then starring into the lamp with a mirror to focus the lens) to room light and back to low-intensity red in a matter of seconds. Given that experience, I’ve never given much credence to the night-vision and red-light argument. Unless I’m slapped right in the face with a LOT of light that dazzles the retinas (close, exceptionally bright landing lights?), I find I’m very tolerant of cockpit light levels, and the transition from inside reading charts and gauges to outside looking at stars and horizons is uneventful.
Neal
RV-7 N8ZG (all the loose ends)
CherokeeJet N9586J
I think that this is also why darkrooms for developing film are lit with red lights.
Mike Welch
[quote] [b]
email(at)jaredyates.com
PostPosted: Mon Sep 06, 2010 6:15 pm    Post subject: dim able strip LED lighting Reply with quote
This is an interesting dimmer.  Does it have the noise problems that Bob was writing about?
On Mon, Sep 6, 2010 at 12:06 PM, RV7ASask <rv7alamb(at)sasktel.net (rv7alamb(at)sasktel.net)> wrote:
[quote]--> AeroElectric-List message posted by: "RV7ASask" <rv7alamb(at)sasktel.net (rv7alamb(at)sasktel.net)>
David
http://forums.matronics.com/viewtopic.php?p=311539#311539
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
PostPosted: Mon Sep 06, 2010 6:37 pm    Post subject: dim able strip LED lighting Reply with quote
I have flown with both, I am a retired Army pilot, and can tell you that the
blue-green lighting has less of an impact on night vision than red and is
easier to read charts with. At lease the blue-green the Army used.
Lynn
RV7ASask
PostPosted: Mon Sep 06, 2010 7:04 pm    Post subject: Re: dim able strip LED lighting Reply with quote
>>This is an interesting dimmer. �Does it have the noise problems that Bob was writing about?
I am just finishing installing the radios so I can't tell you about noise problems at this time. More to follow.
Weighing in on the color of the light. I said earlier 'Stick with White.' I think both Mr Boeing and Mr Airbus have opted for white in the cockpit and I think they got it right.
David
rickofudall
PostPosted: Tue Sep 07, 2010 5:41 am    Post subject: dim able strip LED lighting Reply with quote
Using the example of Boeing and Airbus for cockpit lighting in a good example of not examining the application before making a decision, IMHO. When was the last time an airline crew really needed to have good night vision for looking outside the cockpit? Unless you plan on flying on instruments from takeoff to touchdown, or very nearly, is this the wise choice? Even using the military, particularly what the helicopter cockpits use, is questionable since their decision may have been driven as much by compatibility with night vision equipment as the human eye.
Just exactly how much improvement is blue/green over red? Does the difference amount to anything more that picking the fly poop from the pepper, or are we dealing with an unquantifiable "coolness factor"?
Rick Girard
On Mon, Sep 6, 2010 at 10:04 PM, RV7ASask <rv7alamb(at)sasktel.net (rv7alamb(at)sasktel.net)> wrote:
David
http://forums.matronics.com/viewtopic.php?p=311626#311626
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
 - G.K. Chesterton
blackoaks(at)gmail.com
PostPosted: Tue Sep 07, 2010 6:55 am    Post subject: dim able strip LED lighting Reply with quote
And remember when the red cockpit lighting made all of the fan markers and LF ranges mysteriously disappear from our charts on night flights!
On Mon, Sep 6, 2010 at 7:25 PM, Lynn Riggs <riggs_la(at)yahoo.com (riggs_la(at)yahoo.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Lynn Riggs" <riggs_la(at)yahoo.com (riggs_la(at)yahoo.com)>
Lynn
jimw_btg(at)earthlink.net
Jim Wickert here, I have been following this thread and have the following to put up for added fodder.  We have a Government Marine contract which we are working on that has a section for Night Illumination of Instrumentation and we are doing the scope research now. Below is some interesting information and food for thought.  At this time our general consensus is Soft White Flood of panels?  We have not released our findings to our customer however.  Take care sorry for the amount of text but this is only a snip of the 13 page findings.
FLITELite Light Color, Intensity & Night Vision:
Pilots have a choice of FLITELite colors - NVIS White (more information on NVIS White), Soft White that is NVIS friendly, Green, Red and Blue. The best light choice is NVIS White, followed by soft white, for a light that will protect your central night vision and provide full spectrum light. Green and Blue will protect central night vision as well, but blues and greens will disappear with this color of light - something for a pilot to consider prior to use. Red is also available, which will protect peripheral night vision, but not central vision as well as the soft white, blue and green. Red's on charts will also not be visible with red light, another consideration for the pilot to consider when making a color choice.
The eyes are comprised of Rods and Cones. We hear people talk about Rods being for night vision, and Cones for day vision, and while they both have their special attributes, it would be better to classify them in the aviation environment at Peripheral (Rods) and Central (Cones) vision. Both rods and cones have a day and night mode, and they both react to light at different rates, and to have sensitivity to different light frequencies.
Rods surround the periphery of the eye and are used for peripheral vision, and night vision. They do not see color, and do not detect motion. Rods only provide non-color vision at an acuity of 20/200. Rods are most susceptible to blue light. You never read, or scan your instruments with your Rods - or your peripheral vision - think about it. You are reading this article with your central vision - your cones.
Cones are used for color, central vision, with visual acuity of 20/20. The cones have a focal width of approximately 20 to 30 degrees. Cones are most susceptible to red light.
Cones are used when you read, day or night. During the day we read with our cones - during the night we need a light to read - obvious, but it shatters the red light myth in the aviation cockpit.
So the question is what is the best light that will provide your eyes, and brain with the best light for reading? The answer is a dim white light. Look inside any of the new jets, and you will find that the lighting is white. Military cockpits specify NVIS White. NVIS White appears to have a green tint, but it is a full spectrum light. More on NVIS Compatibility
FLITELite is set to a 25 degree field of view to maximize the physiology of the pilot’s eye. But to preserve night vision the intensity of the light is what matters. By using a full spectrum white light, the full spectrum light and low reflection reduces the amount of light needed. The 25 degree field is critical to keep the light out of our peripheral vision so we can look for traffic, and gauge height when we are making that perfect night landing.
Under red light, magenta symbols disappear on charts, and during electrical failures, red markings on instruments and gauges are unreadable. Blue light will make Blue 100LL fuel disappear.
Unaided night vision even now in the 21st century is still the subject of some controversy.
For those just looking for an executive answer as to what supplemental lighting should be used to reduced the recovery time back to night vision (dark adapted or scotopic) here it is: a fully dimmable white light! This of course is a very incomplete answer but so are the answers red or blue-green and you should know why.
Let’s start with red, specifically what I will call the red light myth.
I believe the myth started in the photographic darkroom.
Until about 1906 most photosensitive material (plate, film, and paper) was not very sensitive to red. Some of these orthochromatic materials are still used. This allowed these materials to be dealt with for a short time under a relative bright red light because the human eye can see red if the level is bright enough. The fact that L.E.D.s (having a number of advantages over other light sources) were economically only available in red for some time has also help to perpetuate this myth.
As more research about the eye was done it was found that the structure responsible for very low light vision, the rods, were also not very sensitive to red.
It was assumed then that like film you could use red light, which is seen by the red sensitive cones (there are also blue and green sensitive cones to give color vision), without affecting the rods.
It takes a while for true night vision to be recovered. About 10 minutes for 10%, 30-45 minutes for 80%, the rest may take hours, days, or a week. The issue is the chemical in the eye, rhodopsin - commonly called visual purple, is broken down quickly by light. The main issue then is intensity; color is only an issue because the rods (responsible for night vision) are most sensitive at a particular color. That color is a blue-green (507nm) similar to traffic light green (which is this color for a entirely different reason). It would seem that using the lowest brightness (using this color) additional light needed for a task is the best bet to retain this dark adaptation because it allows rods to function at their best.
Unfortunately there are a number of drawbacks using only night vision.
Among these are:
  • The inability to distinguish colors.
  • No detail can be seen (about the same as 20/200 vision in daylight).
  • That nothing can be seen directly in front of the eyes (no rods in the center of the retina), you must learn to look about 15-20° off center.
  • Only motion can be detected well, therefore you may have to learn to move your eyes to detect something that doesn't move.
  • Objects that aren't moving appear to move (autokinesis). This has probably led to a number of plane crashes.
If you need to see directly in front of you or see detail you need red. Like many myths the red light myth has some basis in fact. The red truth?
Why red? The center 1.5% of your retina (the fovea) which provides you with most detailed vision is packed almost exclusively with red sensitive cones.
This is the same area that has no rods and is responsible for the night blind spot. There are fewer total green sensitive cones than red. The number of blue sensitive cones is very small compared to green and red.
Which is just as well since the lens in the human eye cannot focus red and blue at the same time. And using green really only changes perceived brightness because of the way the signals are processed in our neural pathways. Unlike a digital camera, more pixels, in this case, doesn't give us more detail.
<![endif]--><![if !vml]>[img]cid:image002.gif(at)01CB4E6E.8A036B00[/img]<![endif]>Chart showing the distribution of rods vs cones. Note the absence of rods in the center and the absence of both about 15° away from the the center toward the nose where the optic nerve passes.
At first glance the tendency would be to pick the hue of red at which we are most sensitive (566nm) which would make sense except for the real reason: we don't want to involve the rods. The reason is the rods share the neural pathways with the cones so that you have this fuzzy image overriding the detailed one. This effect disappears at slightly higher mesopic levels which is why white is a good choice for most tasks. Many people look at the numbers for sensitivity for rods and cones and forget that in most cases the numbers have been adjusted so that rod peek sensitive matches cone peak. Rods are in fact sensitive well into the infrared (not too useful except to know that light you can barely sense can adversely impact your night vision). The key then is finding a hue that we can have at a high enough intensity that we can see the detail we need without activating our rods to the point where they obscure that detail. Most source say this should be nothing shorter than 650nm. Experimentation shows a L.E.D. with a peek around 700nm seems to work best (perceived as a deep red). Note that red may be fatiguing to the eyes.
Conclusions:
  • No matter what your color choice it must be fully adjustable for intensity.
  • If you need the fastest dark adaptation recovery and can adjust to the limitations, or everyone in your group is using night vision equipment then blue-green.
  • If you must see detail (reading a star chart, or instrument settings) and can lose peripheral vision (see note 1), then a very long wavelength red at a very low level. Red really only has an advantage at very low levels (were the night blind spot is very obvious).
  • A general walking around light so that you don't trip over the tripod, knock over equipment or bump into people, then blue-green with enough red added to get rid of the night blind spot, or maybe just use white. Blue-green at higher brightness also works very well and at a lower intensity than white.
  • If you need to see color and detail then likely the best choice is the dimmest white light for the shortest amount of time.
  • If you are in the military you must follow their rules; hopefully they will have a good course in unassisted night vision.
  • If you are a pilot and say you only fly in the day, you should be aware of the problems of night vision and should consider a basic (ground) course in night flying.
  • If you wonder why no one else has drawn these conclusions look at the dashboard of most cars. The markings are large, the pointers are large and an orange-red (a compromise, for certain "color blind" persons) and at night it is edge lit with blue-green filtered fully intensity adjustable light.
For Best night vision:
  • Be sure you are getting enough vitamin A or its precursor beta-carotene in your diet (needed for the visual purple).
  • Green leafy stuff is best followed by vegetables that have an orange color. Yes that includes carrots but spinach or dark leaf lettuce are better. It is possible to get too much vitamin A especially as a supplement.
  • Keep up your general health. Smoking is also very bad for night vision, as are most illegal drugs and some prescription drugs.
  • Keep you blood sugar level as even as possible. No meal skipping. Six small meals are better than three large meals. For carbohydrates favor starches (potatoes, rice, and bread) over simple sugars (sweets, alcohol).
  • Use dark neutral gray sunglasses, that pass no more that 15% in full sun, when outside during the day.
True night blindness is rare. Most of what people call night blindness is either a lack of vitamin A in the diet or a failure to understand the night blind spot.
Cataracts, even minor ones, increase the effects of glare at night and the eye's lens does yellow and passes less light as we age which may contribute to what some call night blindness.
Note: The red filtered light at the intensity most people use is likely decreasing night vision much more than a properly dimmed white or blue-green light would!
Note: There are day blind spots also but are in a different position in each eye so are less of a problem.
Note: Blue-green (also called cyan, turquoise, teal and other names) as used here is NOT the combination of two colors but is a single particular hue. I use the most common name for that hue.
Mil-STD 1472F 5.8.2.2 (table XVI) display lighting
Brightness of markings
Condition of use
Lighting Technique *
cd/m2
foot-lamberts
Brightness Adjustment
Indicator reading, dark adaptation necessary
Red flood, indirect, or both, with operator choice
0.07-0.35
(0.02-0.1)
Continuous throughout range
Indicator reading, dark adaptation not necessary but desirable
Red or low-color-temperature white flood, indirect, or both, with operator choice
0.07-3.5†
(0.02-1.0)
White flood
3.5-70
(1-20)
Fixed or continuous
Panel monitoring, dark adaptation necessary
Red edge lighting, red or white flood, or both, with operator choice
0.07-3.5
(0.02-1.0)
Panel monitoring, dark adaptation not necessary
White flood
35-70
(10-20)
Fixed or continuous
Possible exposure to bright flashes, restricted daylight
White flood
35-70
(10-20)
Fixed
Chart reading, dark adaptation necessary
Red or white flood with operator choice
0.35-3.50
(0.1-1.0)
Chart reading, dark adaptation not necessary
White flood
17-70
(5-20)
Fixed or continuous
* Where detection of ground vehicles or other protected assets by image intensifier night vision devices must be minimized, blue-green light (incandescent filament through a filter which passes only wave lengths shorter than 600 nm) should be used in lieu of red light.
† Possible error in original, read as: 0.07-0.35, likely occurred when converted to metric.
This is intended only as an overview; no warranty of this information is expressed or implied
[Update 17 Nov 2003] I find new myths are springing up. Such as blue-green L.E.D.s are emitting two colors of light. This is a mis-understanding of the color name and that this is the most accepted name for this one color. Another is that blue improves night vision. While at somewhat higher levels it, of course, is stimulating the rods. It is not an optimum color. Another long standing myth is that human visual perception is based on three colors when it is really based on four. The rods are usually ignored because many people believe, wrongly, that at the brightness at which we perceive color the rods are no longer providing our brains with any information. In fact the perception of brightness is highly influenced by the rods well into the photopic (bright light) range of vision. Fluorescent lamp manufacturers have used this knowledge for a long time. "Cool White" lamps have an additional amount of green phosphor added to make us "see" them as being brighter! Of course the whole subject of color vision and the variances thereof (wrongly called "color blindness") will require a number of new pages even in synopsis form.
A point I forgot to cover is that to help preserve night vision in one eye the other may be closed or covered if you know you are about to be exposed to a brighter light, such as from a oncoming vehicle. For normal observation both eyes should be kept open. If it is difficult to concentrate on the desired image the eye not being used may be covered but not closed. Closing affects focus and possibly acuity.
[Update 14 Dec 2003] A very important point barely mentioned in the original is that human peripheral vision is almost completely rod based! The implication then is that we cannot see color at the edges of our vision. If you think we can, try this simple experiment. You will need a small assortment of color cards (try sheets of construction paper) and someone to assist you. Sit looking straight ahead while you’re assistant, about 6 to 10 feet away, slowly moves a random color card into the margin of your vision. Now, while still looking straight ahead, what color is the card?
This is the second most important factor that has been ignored in the design of outdoor lighting, the first being glare! However this study (in pdf), at the U. S. Dept. of Transportation, is a subjective study of blue tinted headlamps.
[Update 23 Jan 2004] A few random notes to be better integrated into this document later.
Luminances are approximate and will vary with the individual and conditions.
Vision luminance rage 1 * 10-6 to 1 * 106 cd/M2
Rods luminance rage 1 * 10-6 to 1 * 103 cd/M2 (may still play a roll above this range)
Cones luminance rage 1 * 10-3 to 1 * 106 cd/M2
Explain "Purinke shift"
20/20 vision is the ability to resolve 1 minute of arc at 20 feet.
Discuss Ricco's Law.
Discuss afterimages.
LITELite NVIS Compatibility
MIL-STD-3009 was developed by the Department of Defense in February 2001 and superceded MIL-L-85762A. It specifies that NVIS White for crew cockpit and utility lighting. NVIS Green A is grand fathered into the cockpit for certain applications, but not for new applications.
The chromacity of NVIS White makes it a full spectrum light even though is appears to have a green tint. Visible light can be split into the three primary colors, red, green and blue. The eye needs two primary colors to see 'white'. NVIS White, in simple terms is blue range through the green range. NVIS goggles filters allow a thin band of green light though the lens - so that users can see heads up displays and other required applications through the goggles.
The level of light with respect to the chromacity is important due to this leak (filter) in the goggles. Other manufacturers claim to be the 'only authorized' lights produced since they meet a request for proposal standard. These claims are false - they have never tested FLITELite products how could they know? FLITELite meets and exceeds non-binding RFP standards, AND meets the modern, more stringent MIL-STD-3009, which is a binding requirement specified by the military.
General Aviation pilots can benefit from this technology. This light spectrum and intensity is perfect for general night vision use as well.
Read MIL-STD-3009 here.
FLITELite minimizes the crossover zone by using a special combination of LED's and Filter material. The filter material ensures that the light greater than 600 nm is not transmitted.
Jim Wickert
Vision #159 “Vision some will have some will not”
Tel 920-467-0219
Cell 920-912-1014
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Tuesday, September 07, 2010 8:35 AM
Subject: Re: Re: dim able strip LED lighting
Rick Girard
David
MS -
e -
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
 Filesize:  4.11 KB
 Viewed:  17890 Time(s)
 Filesize:  6.7 KB
 Filesize:  41.1 KB
 Filesize:  21.3 KB
 Filesize:  30.48 KB
PostPosted: Tue Sep 07, 2010 6:57 am    Post subject: dim able strip LED lighting Reply with quote
Your point with the white light in the Airbus is quite valid.  As to the NVG compatibility, when flying with NVG’s the cockpit lighting is turndown so low you cannot read your instrument without using the NVG’s and color does not make much difference.  The Army was looking for a different lighting in the cockpit because the red lighting gave off an IR signature which is not good.  They found that the blue-green light was preferred buy their pilots, especially the older pilots,  and did not give off an IR signature.  I have over 600 hours of flight time at night and a lot of that flying low level or terrain flight in VFR conditions with about 60 hours using the blue-green lighting which I thought to be much better than the red lighting.  I would not use white lighting in the cockpit for night VFR flight.  The problem I have found is the blue-green cockpit lighting is not available.
Lynn
Rick Girard
David
[quote] [b]
AV8ORJWC
PostPosted: Tue Sep 07, 2010 8:06 am    Post subject: dim able strip LED lighting Reply with quote
Excellent research material. I work on Part 121 Airliners and your below post seems consistent with what is being done up in their cockpits (Flight decks). My darkroom days are way in the past and images of the damage of red light left too long on either film or paper are still remembered as damaging.
Being able to dim the intensity and use of the most pleasing hue seem important to me. Thank You. Hope your Marine contract serves you well.
John Cox
From: owner-aeroelectric-list-server(at)matronics.com on behalf of Jim Wickert
Sent: Tue 9/7/2010 7:51 AM
Subject: RE: Re: dim able strip LED lighting
[img]image001.gif[/img]
Among these are:
[img]image002.gif[/img]Chart showing the distribution of rods vs cones. Note the absence of rods in the center and the absence of both about 15° away from the the center toward the nose where the optic nerve passes.
Conclusions:
Condition of use
cd/m2
foot-lamberts
0.07-0.35
(0.02-0.1)
0.07-3.5†
(0.02-1.0)
White flood
3.5-70
(1-20)
Fixed or continuous
0.07-3.5
(0.02-1.0)
White flood
35-70
(10-20)
Fixed or continuous
White flood
35-70
(10-20)
Fixed
0.35-3.50
(0.1-1.0)
White flood
17-70
(5-20)
Fixed or continuous
[img]image003.jpg[/img]
[img]image004.jpg[/img]
[img]image005.jpg[/img]
Jim Wickert
Tel 920-467-0219
Cell 920-912-1014
 Filesize:  4.11 KB
 Viewed:  17888 Time(s)
 Filesize:  6.7 KB
 Filesize:  41.1 KB
 Filesize:  21.3 KB
 Filesize:  30.48 KB
PostPosted: Tue Sep 07, 2010 8:14 am    Post subject: dim able strip LED lighting Reply with quote
Another good point.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John McMahon
Sent: Tuesday, September 07, 2010 9:30 AM
Lynn
longg(at)pjm.com
PostPosted: Tue Sep 07, 2010 9:09 am    Post subject: dim able strip LED lighting Reply with quote
I take Bilberry Extract which was used in WW2 and suggested for improving rod stimulation. Could be an old wives tale, but I do well with it. On trick to flying at night is to do it more often. Regardless of color (yes, some are better than others), choosing the best color will not automatically improve your night vision. People are always looking for a magic pill.
One thing I notice is that when I fly more often at night, my vision becomes more readily sensitive to the light available. In other words, the third night is better than the first. It’s the same thing that happens when I go from the city to hunting in the woods. For the first few days I never see an animal and then almost magically I begin to see small changes in the landscape and critters moving about were before not seen.
I believe they call the process adaptation. So, buy the best color that suits your needs, but better yet, sleep in Saturday morning and take to the stars more often.
Glenn,
New Garden, PA
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Tuesday, September 07, 2010 11:57 AM
John Cox
Among these are:
<![endif]--><![if !vml]>[img]cid:image002.gif(at)01CB4E8D.6D0C9ED0[/img]<![endif]>Chart showing the distribution of rods vs cones. Note the absence of rods in the center and the absence of both about 15° away from the the center toward the nose where the optic nerve passes.
Conclusions:
Condition of use
cd/m2
foot-lamberts
0.07-0.35
(0.02-0.1)
0.07-3.5†
(0.02-1.0)
White flood
3.5-70
(1-20)
Fixed or continuous
0.07-3.5
(0.02-1.0)
White flood
35-70
(10-20)
Fixed or continuous
White flood
35-70
(10-20)
Fixed
0.35-3.50
(0.1-1.0)
White flood
17-70
(5-20)
Fixed or continuous
Jim Wickert
Tel 920-467-0219
Cell 920-912-1014
 Filesize:  4.11 KB
 Filesize:  6.7 KB
 Filesize:  41.1 KB
 Filesize:  21.3 KB
 Filesize:  30.48 KB
raymondj(at)frontiernet.n
PostPosted: Tue Sep 07, 2010 4:01 pm    Post subject: dim able strip LED lighting Reply with quote
Greetings Jim,
I appreciate you sharing the info. Would it be possible to make the
balance of your research available? I certainly understand in you
choose not to, but I thought I'd ask.
Thanks again for making this info available.
Raymond Julian
Kettle River, MN
on NVIS White <http://www.flitelite.com/isite/nvis.htm>), Soft White
light frequencies.
http://www.flitelite.com/isite/images/rcdist.gif
<http://www.flitelite.com/isite/nvis.htm>. NVIS White appears to have a
sensitive to red.
Among these are:
* The inability to distinguish colors.
* No detail can be seen (about the same as 20/200 vision in daylight).
* That nothing can be seen directly in front of the eyes (no rods in
center.
* Only motion can be detected well, therefore you may have to learn
* Objects that aren't moving appear to move (autokinesis). This has
sensitive cones.
rod density vs. conesChart showing the distribution of rods vs cones.
Conclusions:
* No matter what your color choice it must be fully adjustable for
intensity.
* If you need the fastest dark adaptation recovery and can adjust to
* If you must see detail (reading a star chart, or instrument
settings) and can lose peripheral vision^ (see note 1)
<http://stlplaces.com/night_vision_red_myth/#note1> , then a very
obvious).
* A general walking around light so that you don't trip over the
* If you need to see color and detail then likely the best choice is
* If you are in the military you must follow their rules; hopefully
* If you are a pilot and say you only fly in the day, you should be
* If you wonder why no one else has drawn these conclusions look at
* Be sure you are getting enough vitamin A or its precursor
* Green leafy stuff is best followed by vegetables that have an
* Keep up your general health. Smoking is also very bad for night
* Keep you blood sugar level as even as possible. No meal skipping.
* Use dark neutral gray sunglasses, that pass no more that 15% in
night blind spot.
*Mil-STD 1472F 5.8.2.2 (table XVI) display lighting*
Condition of use
cd/m^2
foot-lamberts
0.07-0.35
(0.02-0.1)
operator choice
0.07-3.5†
(0.02-1.0)
White flood
3.5-70
(1-20)
Fixed or continuous
0.07-3.5
(0.02-1.0)
White flood
35-70
(10-20)
Fixed or continuous
White flood
35-70
(10-20)
Fixed
0.35-3.50
(0.1-1.0)
White flood
17-70
(5-20)
Fixed or continuous
*This is intended only as an overview; no warranty of this information
is expressed or implied*
<http://stlplaces.com/cgi/redirect.cgi?http://dmses.dot.gov/docimages/pdf66/133155_web.pdf>
Vision luminance rage 1 * 10^-6 to 1 * 10^6 cd/M^2
Rods luminance rage 1 * 10^-6 to 1 * 10^3 cd/M^2 (may still play a roll
above this range)
Cones luminance rage 1 * 10^-3 to 1 * 10^6 cd/M^2
Read MIL-STD-3009
<http://www.flitelite.com/isite/support/MIL_STD_3009.pdf> here.
http://www.flitelite.com/isite/images/nvischart.jpg
http://www.flitelite.com/isite/images/range.jpg
http://www.flitelite.com/isite/images/nvissys.jpg
Jim Wickert
Tel 920-467-0219
Cell 920-912-1014
*From:* owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of
*Richard Girard
*Sent:* Tuesday, September 07, 2010 8:35 AM
*To:* aeroelectric-list(at)matronics.com
*Subject:* Re: Re: dim able strip LED lighting
choice?
Rick Girard
<mailto:rv7alamb(at)sasktel.net>> wrote:
<rv7alamb(at)sasktel.net <mailto:rv7alamb(at)sasktel.net>>
David
ric-List"
MS -
e -
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
*http://www.matronics.com/Navigator?AeroElectric-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
Goto page 1, 2  Next
Page 1 of 2
