wdaniell(at)etb.net.co Guest
Posted: Mon Sep 06, 2010 12:43 pm Post subject: Batteries and fuel systems |
Two questions for the assembled wisdom
- Has anyone installed a larger battery with the 914 on the basis that you might need to run the fuel pumps off it if the alternator gives up?
- Does anyone have a pic of their fuel pump installation/fuel system?
Will
[quote] [b]
frans(at)privatepilots.nl Guest
Posted: Mon Sep 06, 2010 1:01 pm Post subject: Batteries and fuel systems |
On 09/06/2010 10:34 PM, William Daniell wrote:
| Quote: | 1. Has anyone installed a larger battery with the 914 on the basis
gives up?
It takes less weight to install a secondary alternator (ACS has nice
ones that fit on the vacuum pump pad) so you never have to use the
batteries during flight and hence the batteries can be very light. You
can use the secondary alternator to power the second fuel pump, or you
can create a completely dual electrical system, and spread the load over
both buses and create redundancy for nav, com, and other essential
equipment. I have done the latter. I use an 8 Ah Odyssey battery and
this is more than sufficient for starting. Talk about weight savings!
Also, there is a mechanical fuel pump available for the 914. Bob Borger
can tell you more about it. In this case the engine no longer depends on
the electrical system.
Installing a larger battery is the heaviest solution, and as you can
never know how much capacity the battery has (due to aging, or
incomplete charging) it is not a reliable solution and leaves you
guessing how long it will be able to keep the engine running.
Frans
g-iani(at)ntlworld.com Guest
Posted: Mon Sep 06, 2010 1:34 pm Post subject: Batteries and fuel systems |
Will
Attached is a picture of the fuel pump setup for G-IRON
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: 06 September 2010 21:34
Subject: Batteries and fuel systems
Two questions for the assembled wisdom - Has anyone installed a larger battery with the 914 on the basis that you might need to run the fuel pumps off it if the alternator gives up?
Will
198.68 KB |
10176 Time(s) |
Posted: Mon Sep 06, 2010 2:08 pm Post subject: Batteries and fuel systems |
Posted: Mon Sep 06, 2010 2:39 pm Post subject: Batteries and fuel systems |
On 09/06/2010 11:27 PM, G-IANI wrote:
| Quote: | Attached is a picture of the fuel pump setup for G-IRON
Nice! I love that manifold you created.
But I can't help noticing that the springs inside the filters are
missing.
Furthermore, I would recommend to use two separate electrical connectors
for the fuel pumps. It even looks like both pumps share a common ground
wire... and this makes the system very vulnerable for a single point
failure. After all, the whole point of having two fuel pumps and two
filters is to eliminate single point failures as much as possible. As
connectors are known for their high failure rate I would highly
recommend to separate all the wires and connectors for the fuel pumps as
much as possible! You are going to hate it if this single connector
fails due to some minor corrosion while you are flying over the channel,
taking both fuel pumps out of the equation at the same time...
Frans
Posted: Mon Sep 06, 2010 3:40 pm Post subject: Batteries and fuel systems |
Attention Will Daniels.
Hi! Will.
I think it should be said that the picture shown by Ian Rickard does comply with the fuel flow diagram suggested by the Europa Engineers and can be worked entirely by rubber pipes therefore excluding the specially made manifold as shown.
However mine is the same in modular form but for the fact that my filters on G-PTAG consist of two Mini-Andair Gascolators situated between the module and the tank exits. and arranged to allow easy sampling from the belly of the aircraft of both gascolators. Also I have the Graham Singleton tank connectors which easily facilitate water drains from each side of the saddle tank.
However from bitter experience I have also incorporated a tank top access panel (allowing annual inspection and mop out capability) whilst fitting the fuel depth gauge.
Care needs exercising as to how the two pumps are circuited for power to ensure real redundancy Also the positioning of diodes on each pump is very relevant.
Best regards
Bob Harrison. G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of G-IANI
Sent: 06 September 2010 22:27
Subject: RE: Europa-List: Batteries and fuel systems
Will
Subject: Europa-List: Batteries and fuel systems
Will
rparigoris
Posted: Mon Sep 06, 2010 4:07 pm Post subject: Re: Batteries and fuel systems |
Hi Will
914 fuel system:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=28612
http://www.europaowners.org/forums/gallery2.php?g2_itemId=28355
http://www.europaowners.org/forums/gallery2.php?g2_itemId=27522
Using a PC545:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=30710
Also a 2.2 amp total loss NiMh battery:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=30502
Using a SD20S as mail alternator on vacuum pad and a LR3C regulator:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=28318
Hope that helps.
Ron Parigoris
BTW PTAG, I was cleaning kitchen floor yesterday and washing off mop in kitchen sink. we have a yellow lab. Anyway it didn't take long for the strainer to get clogged. after a while the dog hair began to get few and far between. I decided to try an experiment, I made a template to only expose a 3/16" hole. Dog hair had no problem with just a fews hairs that would somehow lay across 3/16" hole and after a while just clog it.
I tried putting a fine screen over intake and after a while it would clog. I tried a course screen and it would allow hairs to get through and clog the 3/16" outlet.
I even left the drain wide opened which was about a 1" opening that had a thin cross over it with a ~ 3/16" hole in the center. Dog hair would clog that as well after a while.
Bottom line dog hair is bad stuff to get in your tank. I don't think not having a screen on tank outlets will save you by just passing hair through to filter, it will create a net and then catches debris and other hair like a magnet.
Posted: Mon Sep 06, 2010 6:40 pm Post subject: Batteries and fuel systems |
thanks - oh boy and I have 4 of them! Labs I mean.
Posted: Tue Sep 07, 2010 12:24 am Post subject: Batteries and fuel systems |
Hi! Ron/Will/all
Re:- finger filters etc.
"just don't remind me !" Thanks for doing the tests and making my event just
more believable. I didn't have any followers when I scrapped the finger
filters and since then a friend has produced "brass finger tubes" with many
deburred holes in them which I am successfully flying. (he was intent on my
preservation) Of course finger filters have in the past prevented many fuel
failures but I believe they are somewhat redundant with nylon tanks. The
best way is to use pre-filters when filling the tank, or another extreme is
to "shave the dog" as Neveille Eyre, ex-Europa factory fame suggested.
Also an annual inspection and mopping out hole in the tank top would help as
per mod of fitting fuel level sensors in the tank top.
Bob Harrison G-PTAG
Posted: Tue Sep 07, 2010 12:34 am Post subject: Batteries and fuel systems |
Frans
Thanks for your thoughts on the pump setup in G-IRON. You are absolutely
right about the electrical connector setup. We missed that when doing this
board even though I had separated them in G-IANI.
The filters are the later type with the cast centre section (not the tube).
These do not need the springs as the filter buts against a fixed stop.
Posted: Tue Sep 07, 2010 3:35 am Post subject: Batteries and fuel systems |
My dogs say that that Nev's solution in unacceptable...perhaps you could
send a pic of the mopping our hole
Will
Robert C Harrison wrote:
Hi! Ron/Will/all
Bob Harrison G-PTAG
Posted: Tue Sep 07, 2010 4:23 am Post subject: Batteries and fuel systems |
Hi! Will.
I can hear the howls of protest ....woof! in unison!
Can't help with a picture ...it's buried! However my records show
PFA Mod 10602 perhaps Ian Rickard would help with a pdf of the mod?
Bob H G-PTAG
Posted: Tue Sep 07, 2010 6:07 am Post subject: Batteries and fuel systems |
Will/Bob
Mod 10602 was for the Averlec Fuel Gauge. I never used that gauge, as
Europa introduced their fuel gauge, but the large "manhole" cover makes for
easy access to the tank. Copy of 10602 attached.
For most purposes the hole for the Europa fuel gauge (Mod 60) should be
sufficient. It is big enough to get a vacuum cleaner hose in.
 Download |
| Filename: |
Avelec.pdf |
701.92 KB |
| Downloaded: |
460 Time(s) |
DanBish
Posted: Tue Sep 07, 2010 7:57 am Post subject: Batteries and fuel systems |
thanks
Yes I have this mod BUT obedient (this was the early days) to the
instructions it came with I put it under the headrest.....so given that
I don't have quadruple jointed arms it will be difficult to use this as
a mopping out hole. That is unless someone has another mod for making
the headrest removable - perhaps one could cut it off make a flange and
then use screws/nut plates to put it back in place. I suppose the other
option is to remove the tank fuel outlet assembly and the finger
strainers annually which looks considerably easier.
Any ideas?
Will
G-IANI wrote:
| Quote: | Will/Bob
