Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Sun Sep 05, 2010 3:54 pm Post subject: Flush door handle locks |
I am getting ready to install the door locks for the flush door handles from IFLYRV10.com. Haven't a clue where I put the instructions, and I can't find them posted on the website. I have searched the archives and found some install pics for the handles, but nothing for the final install of the lock. Anyone have one they can post? Install the locks and glue on the interior fabric and the doors go on for good.
Eric Kallio
capsteve(at)iflyrv10.com Guest
Posted: Sun Sep 05, 2010 7:35 pm Post subject: Flush door handle locks |
Eric,
heres the pdf files. they are in the website in the documents section.
I've been meaning to change the site
a bit to make it easier to navigate..
steve
Sent: Sunday, September 05, 2010 7:54 PM
Subject: Flush door handle locks
Eric Kallio
http://forums.matronics.com/viewtopic.php?p=311484#311484
 Download |
| Filename: |
billethandle0.pdf |
879.32 KB |
| Downloaded: |
1050 Time(s) |
 Download |
| Filename: |
flushlocks%20small.pdf |
171.48 KB |
| Downloaded: |
1838 Time(s) |
ivankris
Joined: 29 May 2009 Posts: 21 Location: Guelph, Ontario. Canada
Posted: Mon Sep 06, 2010 2:25 pm Post subject: Re: Flush door handle locks |
Eric, I just installed these locks from iflyrv10.com, I did it a bit differently than what he shows on the website but they work superbly this way. Please go to my photo album for pictures showing how I did it.
http://ivankristensen.phanfare.com/2292606_5334866
_________________ Ivan Kristensen.
www.ivankristensen.com
Builder # 40838
Flying (430hrs.)
C-GMDV |
sean(at)stephensville.com Guest
Posted: Mon Sep 06, 2010 4:24 pm Post subject: Flush door handle locks |
I was wondering if the flush handles will work with the door latch
modification from Plane Around in regards to the modified racks?
-Sean #40303 (fuse side skins)
On 9/5/10 10:33 PM, Steve DiNieri wrote:
| Quote: | Eric,
section. I've been meaning to change the site
steve
> Eric Kallio
> Checked by AVG - www.avg.com
> 14:34:00
Eric_Kallio
Posted: Mon Sep 06, 2010 5:10 pm Post subject: Re: Flush door handle locks |
Sean, I have the IFLYRV10 flush handles installed and the latch from Sean at planearound. There is no issue in using the two together. My issues with the locks are because I installed the full handle before changing my mind and wanting locks to meet my solely random and arbitrary desire to meet the TSA recommendations for locks. They are merely for looks only because a strong twist and they will strip. Bottom line I have both products and they work great.
Eric Kallio
putting all the pieces together
mouser
Joined: 02 Feb 2010 Posts: 14 Location: Los Alamos, NM
Posted: Tue Sep 07, 2010 11:03 am Post subject: Re: Flush door handle locks |
Hi Eric,
Just to clarify, do the iflyrv10 flush handles work with the 180 degree planearound latch system? Or just the 90 degree (i.e. without the delayed pin extension feature)?
-M
_________________ RV-10 #40988
http://mouser.org/projects/rv-10/
KLAM |
Eric_Kallio
Posted: Tue Sep 07, 2010 11:41 am Post subject: Re: Flush door handle locks |
Ahhhhh. Sorry, can't answer that one. I have the 90 degree.
Eric
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Sep 09, 2010 9:38 am Post subject: Re: Flush door handle locks |
Mouser,
If you haven't cut your Vans' handle racks yet you can just buy the 180 new kit and try to get as much rotation from it as possible. The 180 new kit and the 90 kit are the same price. The 180 retro is more because the extra gear racks to replace the Vans' handle racks are included. I have sold 180 degree kits to builders with flush handle installations do I know they are out there.
Feel free to call me. number on www.planearound.com.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
mouser
Posted: Fri Sep 10, 2010 7:17 am Post subject: Re: Flush door handle locks |
Hi Strasnuts,
I'm still a long way out from ordering door hardware; just waiting on my wing kit to arrive right now. I'm just thinking ahead. Currently, I see your latch and the iflyrv10 handles as the best in show. I plan on going that way when the time comes. Hopefully by then someone will have some photos of a >90degree install showing how much travel you get and how much delay in pin extension that affords.
-Mouser
KLAM |
kearney
Posted: Mon Sep 13, 2010 4:38 pm Post subject: Flush door handle locks |
Sean
I just installed the first of two door catches I picked up from you at KOSH.
To recap, I have the IFLYRV10 flush door handles and lockks installed
already.
It is the flush handle cams that determine how far the door pins can move.
This appears to be about 110 degrees of handle turn. I also found that the
180 degree racks are not required /
kearney
Posted: Mon Sep 13, 2010 4:41 pm Post subject: Flush door handle locks |
Hmmm
I seemed to have hit send before I finished the email below. Here it is
again in its entirety...
Sean
already.
180 degree racks are not required / or useful as the amount of rotation can
be accomodated by the standard racks. You gent a little extra length from
the racks by removing the pop rivet studs at the end of the door racks. They
are not necessary as the IFLYRV10 cam limits the amount of movement.
Cheers
Les
#40643
