Posted: Thu Sep 02, 2010 11:41 am Post subject: HID Lights |
There was a Tom who did this. Hopefully the pictures will come through.
He had his light right inside the inlet on the cowls.
Sent: Wednesday, September 01, 2010 1:22 PM
To: "RV 10 list" <rv10-list(at)matronics.com>
Subject: Taxi Light
Has anyone put a taxi light in their cowl, or are most just aiming one
of two landing lights for taxi?
Sean #40303 fuse side skins
52.08 KB |
17261 Time(s) |
59.45 KB |
17261 Time(s) |
jdriggs49(at)msn.com Guest
Posted: Thu Sep 02, 2010 12:22 pm Post subject: HID Lights |
Not too many are putting the light in the cowl because with the engine running you get a LOT of reflection off the back of the prop. At any kind of engine revolutions the prop disc becomes rather solid and reflects back most of the light trying to shine through it.
[quote] From: rv10builder(at)verizon.net
Subject: RV10-List: Fw: HID Lights
Date: Thu, 2 Sep 2010 12:35:25 -0700
Subject: RV10-List: Taxi Light
> --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com>
sean(at)stephensville.com Guest
Posted: Thu Sep 02, 2010 12:40 pm Post subject: HID Lights |
That's kind of what I was worried about. So, one of the two leading
edge duckworks aimed for landing and the other aimed for taxi. During
landing, both on, during taxi, only taxi aimed one on. That will be
easy to setup in the VP-200 menus.
-Sean #40303
On 9/2/10 3:20 PM, Danny Riggs wrote:
| Quote: | Not too many are putting the light in the cowl because with the engine
> To: rv10-list(at)matronics.com
> Subject: Fw: HID Lights
> From: "Sean Stephens" <sean(at)stephensville.com>
> Subject: Taxi Light
one
wwc4(at)njit.edu Guest
Posted: Thu Sep 02, 2010 12:54 pm Post subject: HID Lights |
Cirrus use to mount their lights in the cowl inlets but since they were unable to cushion them effectively, the failed prematurely. Cirrus has subsequently moved the single main landing light to the forward base of the cowl. I'll be mounting my lights in the cowl just like they are on my Cardinal RG. One oriented for landing, the other oriented for taxi.
On Van's Airforce forum, there was a picture of an RV-10 fro Brazil with dual cowl mounted lights.
William
N40237 - http://wcurtis.nerv10.com/
On Thu, Sep 2, 2010 at 3:35 PM, Pascal <rv10builder(at)verizon.net (rv10builder(at)verizon.net)> wrote:
[quote]There was a Tom who did this. Hopefully the pictures will come through.
From: "Sean Stephens" <sean(at)stephensville.com (sean(at)stephensville.com)>
To: "RV 10 list" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Subject: Taxi Light
| Quote: | --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
Has anyone put a taxi light in their cowl, or are most just aiming one of two landing lights for taxi?
| [b]
Posted: Thu Sep 02, 2010 1:03 pm Post subject: HID Lights |
Are you stating this from experience or ... truthiness?
This is definately not my experience with the dual cowl mounted lights on my Cardinal RG. As mentioned in my other post, Cirrus also mounts a single HID light in the cowl.
William
On Thu, Sep 2, 2010 at 4:20 PM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
[quote] Not too many are putting the light in the cowl because with the engine running you get a LOT of reflection off the back of the prop. At any kind of engine revolutions the prop disc becomes rather solid and reflects back most of the light trying to shine through it.
| Quote: | Sent: Wednesday, September 01, 2010 1:22 PM
> Subject: Taxi Light
| Quote: | >
Tim Olson
Posted: Thu Sep 02, 2010 1:12 pm Post subject: HID Lights |
Why put anything in the way of cooling air?
Tim Olson - RV-10 N104CD
On 9/2/2010 2:35 PM, Pascal wrote:
| Quote: | There was a Tom who did this. Hopefully the pictures will come through.
Subject: Taxi Light
Posted: Thu Sep 02, 2010 1:46 pm Post subject: HID Lights |
Experience.
Date: Thu, 2 Sep 2010 17:03:07 -0400
Subject: Re: Fw: HID Lights
William
> Subject: Taxi Light
| Quote: | >
http://www.mathref="http://forums.matronics.com" target="_blank">http://forums.matron=====[b]
Posted: Thu Sep 02, 2010 2:23 pm Post subject: HID Lights |
Danny,
Can you share some details on this? Type of light, etc? Aircraft type? Was this on an RV?
Unless the cowl mounted light was cycling at the same frequency as the propeller rotation, and the back of the prop was painted white, I can’t imagine how the light would be reflected back toward the pilot.
As previously stated many certified propeller aircraft have cowl mounted lights. If your experience was borne out, I think those manufacturers would have altered that approach.
William
On Thu, Sep 2, 2010 at 5:45 PM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
| Quote: | Experience.
William
| Quote: | Not too many are putting the light in the cowl because with the engine running you get a LOT of reflection off the back of the prop. At any kind of engine revolutions the prop disc becomes rather solid and reflects back most of the light trying to shine through it.
dlm46007(at)cox.net Guest
Posted: Thu Sep 02, 2010 2:29 pm Post subject: HID Lights |
The halogens get very hot but HID do not.
Kellym
Posted: Thu Sep 02, 2010 2:30 pm Post subject: HID Lights |
I think the difference is that the lights pictured are in the cowl
inlets at the top of the cowl, where all certified aircraft lighting in
the cowl is near the bottom of the cowl. You only need to look at the
projector based product that was displaying a heads up EFIS on the back
of the prop to see how reflective it can be.
Kelly
On 9/2/2010 3:22 PM, William Curtis wrote:
| Quote: | Danny,
William
<mailto:jdriggs49(at)msn.com>> wrote:
Experience.
To: rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
William
KCHD |
Tim Olson
Posted: Thu Sep 02, 2010 2:44 pm Post subject: HID Lights |
That's not my point. Like James cowl users found, something as simple as a deflector in front of an injector causing various air pressure and flow changes....in that case a positive one.
So why stick a big lightbulb right in the path of airflow coming into the cowl and plenum when we spend time trying to make air ramps and smooth flow transitions. Seems pointless to me when there are plenty of superior lighting positions to choose from. Why in a cowl inlet?
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Sep 02, 2010 3:31 pm Post subject: Re: HID Lights |
Geez Tim, I already fitted one light on my cowl. I bet you are REALLY going to hate it.
27.42 KB |
17241 Time(s) |
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Tim Olson
Lenny Iszak
Strasnuts
Posted: Thu Sep 02, 2010 5:05 pm Post subject: HID Lights |
Maybe I'll sell a kit for it on PlaneAround.com!
780 Hours
larkrv10(at)yahoo.ca Guest
Posted: Thu Sep 02, 2010 7:19 pm Post subject: HID Lights |
I think Kelly (and William) hit it bang on. The Cessna Cardinals have the lights down low in the cowl, so there is no reflection back into the cockpit from the prop. Certainly I have never seen any in mine.
Thx for the opinions. I will be ordering the Duckworth's 35W D1S HID with the Phillips bulb.
Another question then begs an answer. Why the left wing for the landing light as opposed to the right?
Regards, Rick
#40956
Southampton, Ont
--- On Thu, 9/2/10, Kelly McMullen <kellym(at)aviating.com> wrote:
Received: Thursday, September 2, 2010, 10:28 PM
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
I think the difference is that the lights pictured are in the cowl inlets at the top of the cowl, where all certified aircraft lighting in the cowl is near the bottom of the cowl. You only need to look at the projector based product that was displaying a heads up EFIS on the back of the prop to see how reflective it can be.
Kelly
| Quote: | Danny,
-- William
On Thu, Sep 2, 2010 at 5:45 PM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com) <mailto:jdriggs49(at)msn.com (jdriggs49(at)msn.com)>> wrote:
Experience.
From: wwc4(at)njit.edu (wwc4(at)njit.edu) <mailto:wwc4(at)njit.edu (wwc4(at)njit.edu)>
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) <mailto:rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
William
ww.matronics.com/Navigator?RV10-List" target=_blank>http://www.matronics.========================h= -->
rv10flyer
Posted: Fri Sep 03, 2010 4:25 am Post subject: Re: HID Lights |
DW HID in both wing most outboard bays look like they will work great. I had thought about lower cowl or wheelpants, but decided to cut holes in my wing. I was worried about compromising wing strength, but since it is in that bay and many have test flown before I am fine with them now. I installed them just before installing outboard leading edges. Much easier on the bench. Things that turned me away from cowl were vibration/heat. Then wheel pants was that some have already had problems with extensions breaking and I did not want to add more weight to my pants due to lights and increasing fg strength. I will have enough fiberglass when the doors/top cover come along. Emp fg already complete. Back to the flaps now.
_________________ Wayne G. |
eagerlee
Posted: Sun Sep 05, 2010 3:56 pm Post subject: Re: HID Lights |
hasn't anyone come up with a drop in replacement for the GE4509 that uses LED's and costs less than a hundred bucks?
jrlark
Posted: Sun Sep 05, 2010 7:09 pm Post subject: HID Lights |
I saw a drop in replacement (someone correct me if I'm wrong) that
aeroleds.com had at Airventure. The lumen output was similar to HID's.
| Quote: | From what I gather the length and width of the beam from the led landing
lights are the issue (again someone correct me if I'm mistaken). Also I
believe the price was significantly more than $100
Rick
#40956
mouser
Joined: 02 Feb 2010 Posts: 14 Location: Los Alamos, NM
Posted: Tue Sep 07, 2010 11:00 am Post subject: Re: HID Lights |
Yeah AeroLEDs has a PAR36 lamp that fits in the DW mounts, but they are $500 a pop. Never need replacing... but you'd have to fly HIDs for a long time before you needed $500 worth of replacement bulbs.
_________________ RV-10 #40988
http://mouser.org/projects/rv-10/
KLAM |
