Duckworth HID lights
larkrv10(at)yahoo.ca
PostPosted: Wed Sep 01, 2010 3:42 pm    Post subject: Duckworth HID lights Reply with quote
Hi all
I'm just about to order a 35Watt, DS1 HID light kit from Duckworth's. The less expensive 50 Watt system is tempting as it's supposedly 5X more bright than a halogen. The 35W is 4X more bright (as I've been told by the Duckworth people).
What does the group think? I'm still flying behind a '76 Cardinal with 75 W incandescend so I know the HID's will be a huge improvement. I plan to mount it in the leading edge, and don't plan to put any antennas in the wing tips, led strobes and nav lights are also planned.  Is the higher noise issue of the less costly system of any concern???
Opinions all welcomed. Thx...
Rick
#40956
Southampton, Ont
Strasnuts
PostPosted: Wed Sep 01, 2010 3:51 pm    Post subject: Duckworth HID lights Reply with quote
I bought the 35w DS1 phillips for the reduced noise....I haven't installed it yet so I went off this:
What TYPE of HID Lamp is used?
There are various types of HID lamps. The D1S and D2S are 2 of the most common, with the D1S being the preferred lamp. The reason is that D1S lamps have the ‘igniter’ in the lamp base, whereas D2S have the ‘igniter’ in the ballast. That means that the D2S lamps have a high voltage wire (upwards of 20kV possible!) from the ballast to the lamp that can cause much more ‘noise’ and shock hazard, while the D1S has the high voltage step right at the lamp. D1S lamps for the HIDs in your plane are preferred to minimize radio interference and high voltage on cables.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Tim Olson
PostPosted: Wed Sep 01, 2010 4:07 pm    Post subject: Duckworth HID lights Reply with quote
I'd stick with the lower noise. As a side benefit, you run less wattage at 35W so your current draw won't be quite as much. They are PLENTY bright. Tim
On Sep 1, 2010, at 6:40 PM, Rick Lark <larkrv10(at)yahoo.ca (larkrv10(at)yahoo.ca)> wrote:
[quote]Hi all
Rick
#40956
Southampton, Ont
robin(at)PaintTheWeb.com
PostPosted: Wed Sep 01, 2010 4:25 pm    Post subject: Duckworth HID lights Reply with quote
Rick, I purchased the 35 Watt units from DW (only 35 Watt offered at the time) and have received MANY compliments for brightness and ability to recognize from great distances especially with Wig/Wag.
On my “budget” 8A I purchased two 50 Watt auto HID’s on eBay for ~$70/set. They include wiring, ballast and bare bulb. We placed them in standard rectangular auto bulb just like the Duckworks Lightweight Rectangular light kits for $12.00 each. All in I have dual 50 Watt HID’s for under $110. Not a great savings when considering one has to buy the Leading Edge install kit too but I think I paid more for my original HID’s than DW now gets for them. You will appreciate the power of HID’s.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rick Lark
Sent: Wednesday, September 01, 2010 4:41 PM
To: RV10-list
Subject: Duckworth HID lights
Hi all
Rick
#40956
Southampton, Ont
= Use the Matronics List Features Navigator to browse[/b]
[/b][/quote] Day Browse, Chat, FAQ,[/b]w.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV1[/quote] =======================[/b][/quote] m">http://forums.matronics.com[/b][/quote]                    -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b] [b]
sean(at)stephensville.com
PostPosted: Wed Sep 01, 2010 4:28 pm    Post subject: Duckworth HID lights Reply with quote
I went 35W also. Was told they will be plenty bright. Not flying yet,
so no data points.
-Sean #40303
On 9/1/10 6:50 PM, Seano wrote:
[quote] I bought the 35w DS1 phillips for the reduced noise....I haven't
*What TYPE of HID Lamp is used?*
voltage on cables.
Site Admin
PostPosted: Wed Sep 01, 2010 6:30 pm    Post subject: Duckworth HID lights Reply with quote
I've got a 50w DW HID kit in each wing of the RV-8. Just right. I wouldn't want any less.
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: 90+ Hours TTSN - Enjoying Every Minute...
At 05:27 PM 9/1/2010 Wednesday, you wrote:
I went 35W also. Was told they will be plenty bright. Not flying yet, so no data points.
-Sean #40303
dlm46007(at)cox.net
PostPosted: Wed Sep 01, 2010 8:33 pm    Post subject: Duckworth HID lights Reply with quote
I installed HID from www.planelights.com
http://www.planelights.com/index.php?id=661 is my aircraft.
