RV-8A Ideal ELT Location & Antenna
robin(at)PaintTheWeb.com
PostPosted: Wed Aug 25, 2010 6:44 pm    Post subject: RV-8A Ideal ELT Location & Antenna Reply with quote
Is there an ideal location for the ELT and ELT Antenna on an RV-8A?
Robin
Site Admin
PostPosted: Wed Aug 25, 2010 7:13 pm    Post subject: RV-8A Ideal ELT Location & Antenna Reply with quote
Robin
Hi Robin,
Here's a ton of documentation on what I did with the installation of the ELT and antenna. I've got the unit that takes a GPS serial input and transmits your last coordinates as well. Pretty cool feature. Lots of dialog on the various pages about setting it up, etc.
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2971&log=77846&row=50
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2971&log=77847&row=49
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2971&log=77848&row=48
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2971&log=77849&row=47
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2971&log=77850&row=46
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: 90+ Hours TTSN - Enjoying Every Minute...
chaskuss(at)yahoo.com
PostPosted: Sat Aug 28, 2010 3:24 pm    Post subject: RV-8A Ideal ELT Location & Antenna Reply with quote
Robin,
I would suggest that you NOT follow Matt's installation of the ELT, as it does not meet the recommendations of the FAA for ELT mounting. The FAA recommends mounting the ELT where:
#1 A 100 pound weight can be set on the area of the ELT, without any flexing of the mount.
#2 The mount can support a 300 pound load without breaking.
These recommendations are to prevent failure of the mount during a crash AND to prevent the ELT from triggering during a hard landing, due to a flimsy mount. The battery/bell-crank cover is flimsy, even with a doubler.
A better location would be on the floor [in front of, under or behind the battery/bell-crank cover]. Place the bracket between the lower longeron and the fore/aft belly rib. This will give you the required strength.
I can supply photos off list if desired.
Charlie Kuss
snipped
on an RV-8A?
>Thanks,
>Robin
Hi Robin,
snippped
RV-8 #82880 N998RV
http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV
YouTube Channel
Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
