Speedy11(at)aol.com Guest
Posted: Tue Aug 17, 2010 6:10 am Post subject: RV Speeds |
I've done multiple GPS speed calculations and all of the TAS calculations came within one knot of the EFIS TAS numbers, so if I have a CAS error, it is not very large.
My A is less draggy than a neighbors 390 powered A and we've used WOT side by side and I pull away from him. I'm also working on reducing drag before painting in the fall. I'm working on winglets, I'm fairing the aileron hinges and fuel drains, I'm working on cooling air drag, I'm making mods to the wheel pants, I have straight exhaust pipes for "jet effect," and other speed mods.
The best I can do right now is 184 KIAS at 1K" - WOT and 2680 RPM. My goal, with mods, is to indicate 188. I just can't seem to get the numbers that others are getting.
Stan Sutterfield
| Quote: | Airspeed calibration error .... or drag?
BIll
Matt,
I must be doing something wrong because my IO-390 powered RV-8A numbers
aren't even close to yours.
At 7K', to get 177 KTAS (204 MPH TAS) I have to burn 10.2 GPH and turn
2450 RPM. I can get 3000 FPM climb, but only to pattern altitude.
Enroute climb at 145-150 KIAS produces only 600 FPM. I've climbed to
15.5K' and I'm planning a test flight to FL240 - to see if it will make
it.
I have Bower's ram air and a MT 3 blade - both of which should help with
high altitude performance.
I'm planning a trip from FL to VT in 2 weeks, so I'll see how my cruise
numbers are after that flight.
But, with the numbers I have now, I'm nowhere near your numbers.
I wonder why?
Stan Sutterfield
rv-8a.net
On the way home, I had the IO-390 engine dialed in at 7000ft, 22.4" MP /
2200 RPM and 204 MPH True at 8.8 GPH. Earlier in the week I took it to
18,000ft
(on oxygen) and was seeing 170 MPH True at 5.5 GPH, 192 MPH (at) 6.5 GPH,
and
202 MPG (at) 7 GPH. At the 5.5 GPH, that's about a 1300 mile range less
reserves.
Coupled with the 3000+ FPM climb solo
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
wpaulin(at)usa.net Guest
Posted: Tue Aug 17, 2010 8:28 am Post subject: RV Speeds |
Sorry to act like an expert when I am only an obsolete aerodynamisist but:
1. If you are relatively sure of your weight, airspeed, altitude and engine calibrations (i.e., sure you are pretty close to lift, speed, altitude and thrust measures), then
2. Since T= D & L=W in unaccelerated flight,
3. Either your D is higher than the others (due to W --> L --> D ... or just D items), or they are wrong in their airplane performance measures.
4. If you believe their claims (I'd be careful here), then you have more W, less T or more D than you think.
But since you pull away from your friend (and assuming his calibrations are OK), then my personal guess is that you have to doubt the other's claims / calibrations.
If you don't, then my personal guess would be that since you probably know your engine (T) and W pretty well (but I am not an engine expert), the airframe D is the problem (out of rig, bad airfoils, etc., etc.) ... but your problem then becomes endless. Flying side by side seems the simplest way to get at differing "calibrations."
But again, I am just guessing and probably no help at all.
Bill
On Aug 17, 2010, at 7:08 AM, Speedy11(at)aol.com (Speedy11(at)aol.com) wrote:
Stan Sutterfield
BIll
Matt,
it.
I wonder why?
Stan Sutterfield
rv-8a.net
18,000ft
and
reserves.
href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List
William & Sandra Paulin
1575 South Forest Drive
Prescott, AZ 86303
Bill
Cell +1 858 722 2905
Office +1 760 720 2905
Europe +358 40 720 4047
wpaulin(at)usa.net (wpaulin(at)usa.net)
Sandy
Cell +1 858 349 1729
Office +1 928 443 7739
bifft(at)xmission.com Guest
Posted: Tue Aug 17, 2010 9:33 am Post subject: RV Speeds |
On Tue, 17 Aug 2010, Speedy11(at)aol.com wrote:
| Quote: | The best I can do right now is 184 KIAS at 1K" - WOT and 2680 RPM. My goa
I wonder how much of the difference is knots indicated vs mph true?
184 knots indicated would be 212 mph at sea level, about the same as Van's
180hp numbers.
| Quote: | On the way home, I had the IO-390 engine dialed in at 7000ft, 22.4" MP /
This calculator:
http://www.newbyte.co.il/calc.html
shows 204 TAS at 7000' (standard atmosphere) to be 184 mph CAS, or 160
KIAS.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 Fitting wings
1/4 Starduster II N23UT flying
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27647 Location: Toledo Washington (KTDO) USA
Posted: Tue Aug 17, 2010 9:52 am Post subject: RV Speeds |
On multiple occasions, I have seen a top speed of 229-230 mph true at about 2000 msl, full throttle, and 2700 rpm, and gently leaned. This was confirmed by the GPS GS from both the EFIS GPS and the Kenwood GPS. The autopilot was on to assure no ascending/descending error. These were on cool evenings (70-75f).
That being said, there are other days when it won't go much above 222-225 mph.
I will rig up the cockpit HD video camera again to verify my readings...
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: 90+ Hours TTSN - Enjoying Every Minute...
At 07:08 AM 8/17/2010 Tuesday, you wrote:
Stan Sutterfield
BIll
Matt,
it.
I wonder why?
Stan Sutterfield
rv-8a.net
18,000ft
and
reserves.
_________________ Matt Dralle
tcone1(at)comcast.net Guest
Posted: Tue Aug 17, 2010 10:16 am Post subject: RV Speeds |
Matt,
The National Test Pilot School has a nice excel spreadsheet for removing the
effects of wind in determining true airspeed.
http://www.ntps.edu/images/stories/documents/gps-pec.XLS
Posted: Tue Aug 17, 2010 7:42 pm Post subject: RV Speeds |
Well, I had to see what my IO-390 RV-8A would do at 18K, so today I climbed to 17,500 (couldn't get ATC clearance higher) and had the following numbers:
15.4" MP - 2400 RPM - 8.5 GPH - KIAS 124 - KTAS 166 (191 MPH)
15.4" MP - 2310 RPM - 9.0 GPH - KIAS 120 - KTAS 162 (186 MPH)
Fuel pump was out of service, so I'll confirm the actual fuel burn next week.
I'm simply not getting your numbers, Matt. Must be my ham fisted flying. I can't imagine that the engines are that much different.
Scratching my cranium.
Stan Sutterfield
| Quote: | Matt,
At 7K', to get 177 KTAS (204 MPH TAS) I have to burn 10.2 GPH and turn 2450
RPM. I can get 3000 FPM climb, but only to pattern altitude. Enroute
climb at 145-150 KIAS produces only 600 FPM. I've climbed to 15.5K' and I'm
planning a test flight to FL240 - to see if it will make it.
I wonder why?
Stan Sutterfield
rv-8a.net
18,000ft
(on oxygen) and was seeing 170 MPH True at 5.5 GPH, 192 MPH (at) 6.5 GPH, and
reserves.
Coupled with the 3000+ FPM climb solo |
Posted: Tue Aug 17, 2010 8:03 pm Post subject: RV Speeds |
Looks to me like your RPMs are WAY too high! At 5.5gph I was at 2000 RPM. Lowering the RPM is how you get the flow rates down. Bigger bite might make you go faster too.
I want to say that at 5.5/2000/18000/170mph I was at about 12.5" MP. I think that I took still pictures of the EFIS's in all the various configurations I did. I'll download them from the Camera and double check my numbers.
Matt
At 08:36 PM 8/17/2010 Tuesday, you wrote:
Stan Sutterfield
Matt,
I wonder why?
Stan Sutterfield
rv-8a.net
18,000ft
reserves.
Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550
gcomfo(at)tc3net.com Guest
Posted: Wed Aug 18, 2010 3:16 am Post subject: RV Speeds |
You have different props, right?
Gordon Comfort
Posted: Wed Aug 18, 2010 5:22 pm Post subject: RV Speeds |
Those are amazing numbers. 230 true MPH would be 200 KTAS. That is 6 knots more than I am getting.
The only thing I can think of is that my Barrett IO-390 is not producing full power. If my engine were producing only 190 HP at sea level and yours were producing 210 HP, then that would likely make the difference in speeds.
Maybe I should talk to Allen about the engine. The original dyno run was low on power but that was attributed to high density altitude at the time. It should be producing a solid 210 HP since I asked them to mill .015 off the cylinder bases to increase compression a bit.
I also have an oil leak (since new) directly over the alternator. I haven't yet discovered the source.
Maybe I should fly the plane to OK and talk to Allen and Monty about the engine. Might be a good reason for a nice flight.
Stan Sutterfield
| Quote: | On multiple occasions, I have seen a top speed of 229-230 mph true at about 2000
That being said, there are other days when it won't go much above 222-225 mph. |
martinaerodrome(at)gmail. Guest
Posted: Thu Aug 19, 2010 10:23 am Post subject: RV Speeds |
Stan,
I hate to tell you this, but your inability to achieve the higher speeds is to sell your 3 blade MT to some one you do not like, and use the proceeds to buy either the New blended airfoil blade Hartzell from Vans AC, or better yet, buy a Aerocomposites 2 blade 72 or 74 inch propeller. Also, you could contact Same James and consider one of his cowlings and plenum chambers (proven speed prudecers). Good luck.
Dick Martin
RV8 N233M
the fast one
On Tue, Aug 17, 2010 at 10:36 PM, <Speedy11(at)aol.com (Speedy11(at)aol.com)> wrote:
Stan Sutterfield
| Quote: | Matt,
I wonder why?
Stan Sutterfield
rv-8a.net
18,000ft
reserves.
et="_blank">http://www.matronics.com/Navigator?RV8-List
ttp://forums.matronics.com
robin(at)PaintTheWeb.com Guest
Posted: Thu Aug 19, 2010 11:04 am Post subject: RV Speeds |
Dick,
I take exception to your usually EXCELLENT advice regarding the James cowl & plenum combination. I am placing one on my 8A (yet to fly) strictly for looks but I have also installed one on my RV-10 to near disastrous results. Significantly higher CHT’s and oil temps, poor airflow top to bottom and slower TAS. There is absolutely no engineering associated with the RV-10 James cowl & plenum regardless of what one hears or is told. And much like the two place James cowls that require a modification including additional fill for even a basic proper fit the James Plenum for the -10 does not even align with the cowl inlet openings. Speaking of the inlet openings on the -10 cowl they are the same 4.5” openings used in the two place RV’s. This MAY be the source of the temp issues as one builder has modified the cowl for custom made 6” inlet rings to apparent success in cooling. Think of the effort required to hack out the 4.5” rings and replace with 6” rings. Both the upper & lower cowl have to be mutilated to make room for this mod. Then one has to rework the baffles, inlet ramps etc… You are truly in the experimental world a that point. The -10 cowl has cost me well over $14K in R&D, modifications (oil coolers, turbo injectors…), wasted fuel and I still have not properly resolved the issues. Who knows what damage the extra heat has caused to my new $45K engine. If I were to do it again I would absolutely NOT install the James Cowl on my -10. I am pretty sure the stock cowl is faster too. I knowingly installed the James cowl on my 8A because there are many more success stories with the 4 cylinder versions.
Good luck,
Robin
From: owner-rv8-list-server(at)matronics.com (owner-rv8-list-server(at)matronics.com) [mailto:owner-rv8-list-server(at)matronics.com (owner-rv8-list-server(at)matronics.com)] On Behalf Of Richard Martin
Sent: Thursday, August 19, 2010 11:15 AM
To: rv8-list(at)matronics.com (rv8-list(at)matronics.com)
Subject: Re: Re: RV Speeds
Stan,
Dick Martin
RV8 N233M
the fast one
Stan Sutterfield
Matt,
I wonder why?
Stan Sutterfield
rv-8a.net
18,000ft
reserves.
Coupled with the 3000+ FPM climb solo et="_blank">http://www.matronics.com/Navigator?RV8-List |
Use the Matronics List Features Navigator to browse[/b] | 0 Day Browse, Chat, FAQ,[/b] [/quote]123 m">http://forums.matronics.com[/b] [/quote]45 -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b] [/quote]6
bjudge(at)gmail.com Guest
Posted: Fri Aug 20, 2010 6:02 am Post subject: RV Speeds |
Does anyone have a comparison of the Aerocomposites vs Whirlwind on
the same airframe? I've heard that the WW is faster/more efficient
but I'm biased.
I've got a WW 200RV, RV-8, Superior Airparts IO-360 w/ Ryton exploding
sump, lightspeed II ignition and I generally run 160 knots TAS 10,000
feet, 6.5 gph, WOT, LOP, 1950 RPM. Everything else about the airframe
is pretty much standard. I'm very confident in that 6.5 GPH (at) 160
knots TAS figure. I'm not as confident in other power setting since I
generally just run in the econo cruise (at) 160. As the fuel burns off I
generally pick up 2-3 knots from the reduced weight.
I know that for keeping the efficiency up the low RPM is key.
Bill judge, RV-8, N84WJ 515 Hrs
rv-8.blogspot.com
Time: 11:23:12 AM PST US
From: Richard Martin <martinaerodrome(at)gmail.com>
Stan,
Dick Martin
RV8 N233M
the fast one
Posted: Fri Aug 20, 2010 6:24 pm Post subject: RV Speeds |
Dick,
You gave me the same advice standing in my hangar last Jan. Told you then I don't plan to change the prop. I'm going to experiment with reducing the size of the Van's inlets (ala Dave Anders) to see if I can gain anything. But, I'm not willing to toss my cowling and put on the James cowling. My homemade plenum is working great. CHTs are well under control and Oil temp is perfect at 180.
I did take your advice to straighten out the exhaust pipes for some jet effect. I don't notice any difference. Except the exhaust is hitting the bottom of the plane.
Are you coming to FL for the winter?
Stan Sutterfield
| Quote: | I hate to tell you this, but your inability to achieve the higher speeds is
Dick Martin
Posted: Sat Aug 21, 2010 6:58 pm Post subject: RV Speeds |
Bill,
Thanks for your input. Each data point is valuable and informative.
160 KTAS is impressive for 1950 RPM. I'll try the same parameters next time I go flying and report back.
Stan Sutterfield
| Quote: | I've got a WW 200RV, RV-8, Superior Airparts IO-360 w/ Ryton exploding
tracy(at)rotaryaviation.c Guest
Posted: Sun Aug 22, 2010 4:03 am Post subject: RV Speeds |
Mine aren't quite that good but in the same ballpark. Typical cruise conditions are 12,500 ft, 172 mph, 1965 RPM (at the prop) burning 6.5 gph. That's with one of those presumably gas hungry Mazda rotary engines.
Tracy Crook
On Sat, Aug 21, 2010 at 10:55 PM, <Speedy11(at)aol.com (Speedy11(at)aol.com)> wrote:
Bill,
Stan Sutterfield
#avg_ls_inline_popup { position:absolute; z-index:9999; padding: 0px 0px; margin-left: 0px; margin-top: 0px; width: 240px; overflow: hidden; word-wrap: break-word; color: black; font-size: 10px; text-align: left; line-height: 13px;} [quote][b]
Posted: Sun Aug 22, 2010 3:23 pm Post subject: RV Speeds |
Well, some new numbers today.
I filed IFR to FL200 and then continued the climb to FL240. It took awhile to get up there, but I made it. As it turns out, FL200 is the more comfortable (for aircraft handling) and fuel efficient altitude.
FL200 WOT (13.8") 2400 RPM about 6.3 GPH IAS - 113K TAS - 160K Peak EGT OAT - 40F
FL240 WOT (11.5") 2300 RPM about 6.3 GPH IAS - 92K TAS - 139K 40 LOP OAT - 28F
CHTs and Oil Temp were no problem at all altitudes.
I didn't have time to do a 10K' run to compare with Bill's numbers, but I'll try that in the AM if possible.
Stan Sutterfield
Posted: Mon Aug 23, 2010 5:19 am Post subject: RV Speeds |
Bill<
I have raced against Whirlwinds and find them to be good performers, however I can usually outrun them by an average 5 knot difference,
Good Luck.
Dick Martin
RV8 N233M
the fast one
On Fri, Aug 20, 2010 at 8:32 AM, Bill Judge <bjudge(at)gmail.com (bjudge(at)gmail.com)> wrote:
[quote]--> RV8-List message posted by: Bill Judge <bjudge(at)gmail.com (bjudge(at)gmail.com)>
but I'm biased.
rv-8.blogspot.com
> From: Richard Martin <martinaerodrome(at)gmail.com (martinaerodrome(at)gmail.com)>
Stan,
| Quote: | yet, buy a Aerocomposites 2 blade 72 or 74 inch propeller. Also, you could
| Quote: | Dick Martin
RV:
-List" target="_blank">http://www.matronics.com/Navigator?RV8-Listh
a href="http://www.matronics.com/contribution" target="_blank">http://www.matronics.com/contribution
