hgmckay
Posted: Tue Aug 10, 2010 12:48 pm Post subject: Engine roughness |
I need some help and advice. I was mechanically adjusting my carbs yesterday, and in the process I thought I would check the position of the Idle Mixture screw on the bottom of the carbs. I ran the screws in fully closed, and then backed them out the 1.5 turns as recommended by Rotax. The engine now runs rough at idle, and in the operating range up to 3000 rpm. You can feel it. I did not increase the speed beyond 3000 rpm for fear of harm to the engine. Unfortunately I did not count the number of turns it took to close the Idle Mixture Screws, so I don't know if they were set at 1.5 turns (counterclockwise) initially. I have not pneumatically checked the balance. What are some of the conditions that can cause this type rough engine operation?
Hugh McKay
Allegro 2000
Rotax 912 UL
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Roger Lee
Posted: Tue Aug 10, 2010 12:54 pm Post subject: Re: Engine roughness |
Hi Hugh,
Those mixture screws should be set before a pneumatic balance. Since you now have those set you absolutely need to do a pneumatic balance. Leave the screws at 1.5 turns out. The roughness is because they are helping with the mixture at the low rpms. As you go above 3500 rpm to 4000+rpm that circuit now longer is in play. After the pneumatic balance I would bet your engine will be smooth.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
hgmckay
Posted: Thu Aug 12, 2010 5:00 pm Post subject: Engine roughness |
Roger,etal
Well, in the course of balancing my carbs a friend of mine ask me to check
to make sure nothing was coming in contact with the pick-ups for the
ignition circuits. All were fine except one. On my Allegro one of the
cooling pipes drops down vertically near the back of the engine. This
aluminum pipe was barely touching the pick-up for what I believe to be
ignition circuit B. On page 121 in the Lockwood Aviation Supply Catalogue
the pick-up I am referring to is the one shown as number 3. I assume the
wiring diagram as shown is as if you are looking at the back of the engine.
I corrected the position of the aluminum pipe so it cleared the pick-up an
finished balancing the carbs. I noticed one of the small wires on the
pick-up looked like it had the insulation worn off in one spot. I took a
small amount of silicone and covered the spot. After finishing everything I
decided to test fly the plane. During the normal starting procedure
everything went fine and I taxied to the hold point. At the hold point I was
going through the normal checks, one of which is an ignition check (i.e. I
ran the engine up to 4000 rpm and killed one switch. The rpm drop was
normal. When I killed the other switch the engine immediately shut off. I
quickly opened the switch and the engine caught an ran fine. This alarmed me
so I backed the engine down, revved it back up to 4000 rpm and the same thin
happened. I began to taxi back to the hanger, but decided to try the circuit
again. This time everything was normal. I did this three or four times and
everything was normal so I decided to fly.
I flew around the "patch" for about 30 minutes with no problem, so came back
an landed. I decided to fly one more pattern, but I though I would check the
ignition circuits again. This time when I "killed" the first circuit all was
fine. But when I "killed" the second one it failed again and shut the engine
down. This time I took it to the hanger. Help!!!!!!
Hugh McKay
Allegro 2000 ELSA
Rotax 912 UL
Sent: Tuesday, August 10, 2010 4:54 PM
To: <rotaxengines-list(at)matronics.com>
Subject: Re: Engine roughness
Quote: |
Hi Hugh,
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=308271#308271
Thom Riddle
Posted: Fri Aug 13, 2010 2:20 am Post subject: Re: Engine roughness |
Hugh,
A mag not firing is far more likely to be a wiring or switch fault than a faulty mag, also cheaper to remedy. I would start looking at the magneto switches first. If the connections are clean and secure, these generally fail before other components since they are mechanical and are switched off an on at least twice every flight. Randomly occurring faults are a hit-and-miss proposition when looking for them so if the switch seems okay, check out every inch of the wiring to/from that switch.
Keep us posted on what you find.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
hgmckay
Posted: Fri Aug 13, 2010 4:32 am Post subject: Engine roughness |
Thom/Dick,
Ok, I understand what you are telling me to do, and I will. However, being
an engineer (civil, not electrical) my brain is asking what is causing the
engine to cut off when I turn off the one mag? If the wire is broke in the
first place, what does turning the switch off have to do with shutting the
engine down? I am confused (which may be normal in my case)!
Hugh
Sent: Friday, August 13, 2010 6:20 AM
Quote: |
<riddletr(at)gmail.com>
Hugh,
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
The truth will set you free. But first, it will piss you off.
- Gloria Steinem
http://forums.matronics.com/viewtopic.php?p=308626#308626
Thom Riddle
Posted: Fri Aug 13, 2010 4:55 am Post subject: Re: Engine roughness |
Hugh,
Magnetos that are working correctly, are functional UNLESS the the "P-Lead" is GROUNDED. When you turn the mag switch to the OFF position, that grounds the mag so it will not function. If the mag is inadvertently grounded without turning the mag switch to OFF, then it will not work. So essentially, you are looking for an inadvertent grounding of the mag that "fails" when you check them during the run-up.
The fact that mags function unless grounded is why it is important to check the mag off switch for proper functioning during pre-take-off check. Your check for rpm drop is important but also making sure the switch does ground the mag is a safety issue too. If the switch does not ground the mag, it is always hot.
Buffalo, NY (9G0)
- Anonymous |
hgmckay
Posted: Fri Aug 13, 2010 5:38 am Post subject: Engine roughness |
Thom,
My head is probably really thick on this one. I still do not understand what
would cause the engine to completely cut off if there is a break in the wire
on that mag when the mag switch is turned off. I there is a break in the
wire between the switch and the engine anyway, what does activating or
de-activating the switch have to do with it?
Hugh
Sent: Friday, August 13, 2010 8:55 AM
Hugh,
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Gloria Steinem
http://forums.matronics.com/viewtopic.php?p=308646#308646
Thom Riddle
Posted: Fri Aug 13, 2010 5:56 am Post subject: Re: Engine roughness |
Hugh,
When you turn off the Left mag switch (for example), that action should ground the Left mag (disabling it), thus leaving the engine running on the Right mag only. If you turn off the Left mag and the engine quits, it means that the Right mag is not firing the engine. This means that one (or combination) of the following things is happening:
1) Right mag is faulty.
2) Right mag is grounded.
The Right mag being inadvertently grounded could be caused by one of two things, that I can think of:
A) A bad switch (mistakenly grounding the mag when the switch is in the on position), unlikely but possible.
B) Right mag wire has made ground elsewhere, most likely.
So, what you are looking for is these two things. If you find no fault in either of these, then you need to look deeper, i.e., check out the functioning of the mag itself. That is beyond the scope of my ability to explain in an email.
I hope this helps.
Buffalo, NY (9G0)
- Anonymous |
sdemeyer
Posted: Fri Aug 13, 2010 7:13 am Post subject: Engine roughness |
I have had this broken wire problem too, several times with exactly the same symptoms. The faulty wire(s) in my case was the one coming from the stator assembly and was broken just before the module connector.
Scott
To: rotaxengines-list(at)matronics.com
Date: Friday, August 13, 2010, 6:56 AM
--> RotaxEngines-List message posted by: "Thom Riddle" <[url=/mc/compose?to=riddletr(at)gmail.com]riddletr(at)gmail.com[/url]>
Hugh,
I hope this helps.
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Gloria Steinem
http://forums.matronics.com/viewtopic.php?p=308657#308657
jonathan(at)entry.co.za Guest
Posted: Fri Aug 13, 2010 8:32 am Post subject: Engine roughness |
Yep that is where I had the problem too.
Jonathan
s.clive.richards(at)homec Guest
Posted: Fri Aug 13, 2010 9:20 am Post subject: Engine roughness |
Thom
The break in the wire they are referring to is in a Red
power supply wire to the electronic module not the P lead which if grounded
by mag switch or a short to ground turns that module off.
Clive
Thom Riddle
Posted: Fri Aug 13, 2010 9:46 am Post subject: Re: Engine roughness |
Clive,
I never mentioned a broken wire, that was someone else. I was providing guidance to Hugh to help him find a possible source of the problem, beginning with the mag switches on to the mag grounding wires. I know an OPEN in a ground wire will not cause a mag to 'fail', but to remain hot.
In any case, since the failure appears to be intermittent, it is likely to be a bad connection or partially broken wire if on the power side, or a "sometimes grounding" P-lead or p-lead switch wire.
Thom
http://sites.google.com/site/riddletr/a&pmechanix
Buffalo, NY (9G0)
- Anonymous |
sdemeyer
Posted: Fri Aug 13, 2010 11:16 am Post subject: Re: Engine roughness |
Thom Riddle wrote: | Clive,
Thom
http://sites.google.com/site/riddletr/a&pmechanix |
Sorry Guys, there are two threads going on here with almost exactly the same subject. My reply was meant for the other thread!
Scott
Posted: Fri Aug 13, 2010 12:22 pm Post subject: Engine roughness |
Thom
Sorry this should have been addressed to Hugh in
reply to his question included in my post I typed name at top of post
instead of bottom.
Clive-
rickofudall
Posted: Fri Aug 13, 2010 3:35 pm Post subject: Engine roughness |
Just a guess, but the wire is broken and the insulation is holding it such that it makes intermittent contact.
Rick Girard
LSARM # 3178721
On Fri, Aug 13, 2010 at 7:29 AM, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
[quote]--> RotaxEngines-List message posted by: "Hugh McKay" <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)>
Thom/Dick,
Ok, I understand what you are telling me to do, and I will. However, being an engineer (civil, not electrical) my brain is asking what is causing the engine to cut off when I turn off the one mag? If the wire is broke in the first place, what does turning the switch off have to do with shutting the engine down? I am confused (which may be normal in my case)!
Hugh
From: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
To: <rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)>
Quote: | --> RotaxEngines-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Hugh,
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Gloria Steinem
"im">
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
