billlang(at)live.com.au Guest
Posted: Sun Aug 01, 2010 7:29 pm Post subject: Starter sequence M14 |
GDay all
Thank you all for your help. The fault has finally been isolated and fixed . All of the advice had been used, but to no avail. As I said originally, this is a new engine, so we were really frustrated in that doing everything by the book, it would still turn a few pots and then oscillate. Problem was eventually traced back to incorrect factory installation of two lines from the spider valve being installed on the incorrect cylinders. Who would have thought the Russians could make that mistake. Friday built engine? I hope everything else inside was put together by someone else!
Thanks again
Bill
Date: Sat, 17 Jul 2010 13:19:34 -0700
Subject: Re: RE: Starter sequence M14
To: yak-list(at)matronics.com
Dennis, it looks like my "translation" version on CD missed a step. Sorry about that Bill. But, seriously, being off 4 degrees should not cause that darn thing not to even spin at all.
Bill, ... Dennis said: "There is an inner and an outer hole in the air distributor slider."
Did you catch that?
Mark
--- On Sat, 7/17/10, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Date: Saturday, July 17, 2010, 8:42 AM
.ExternalClass #ecxyiv1749091937 .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass #ecxyiv1749091937 .ecxhmmessage {font-family:Verdana;font-size:10pt;} According to the Task Card 204 in the M14 manual, the correct procedure is to first position the engine at 12 degrees after TDC on the #4 cylinder. Then rotate the prop in its normal direction back to 8 degrees after TDC. This is where you set the air distributor. The instructions in task card 204 say at this point to set the slide to where the inner hole opens for 1 mm. There is an inner and an outer hole in the air distributor slider.
Dennis
Posted: Mon Aug 02, 2010 4:33 am Post subject: Starter sequence M14 |
Woodka Friday.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Bill Lang
Sent: Sunday, August 01, 2010 10:28 PM
To: Yak List
Subject: RE: RE: Starter sequence M14
GDay all
Thanks again
Bill
Did you catch that?
Mark
Dennis
----- Original Message -----
To: Yak List ; Tim Windsor ; Milton
Sent: Saturday, July 17, 2010 2:18 AM
SITREP
12 Degrees off no 4 pot all set. Zero rotation, just a loud POP of air as the starter is pushed. Pull started and ran it for half hour. Expecting some rotation with starter, but still the POP of air not turning anything.
Very frustrating!!
What is encouraging is that the movement of the spider valve is definitely effecting the prop movement on start.
8 degrees seemed the best, so will fiddle around there maybe.
The Aussie with the 18T and box of matches might like to come over to Cessnock and do an overnight stocktake for me
Any One Bueller?
Anyone?
Bill
> Date: Mon, 12 Jul 2010 11:13:19 -0400
> From: mark.bitterlich(at)navy.mil
> --> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
> That info was pulled from a direct translation of the M-14 manual written the folks who made the engine.
> Mark
cjpilot710(at)aol.com Guest
Posted: Mon Aug 02, 2010 1:21 pm Post subject: Starter sequence M14 |
Bill,
I got a brand new engine from the factory that had a scraper ring where the oil ring should have been on #3 cylinder. It worked for 438 hours!
Jim "Pappy" Goolsby
In a message dated 8/1/2010 11:30:14 P.M. Eastern Daylight Time, billlang(at)live.com.au writes:
[quote]GDay all
Thanks again
Bill
Did you catch that?
Mark
Dennis
