Roger Lee
Posted: Sat Jul 31, 2010 4:51 pm Post subject: Magnetic oil plug check and 5 year rubber part replacement |
Here is a page out of the Rotax manual on what your magnetic oil plug should look like or not and it is a mandatory check at every oil change.
Here is what needs to be changed on the Rotax 5 year rubber parts replacement. If you fly an SLSA then these are mandatory, but if you fly an experimental your not forced to, but it isn't in your best interest to let either of the above go.
| 5 year rubber parts replacement |
 Download |
| Filename: |
Rotax 5 year Rubber component change.PDF |
100.53 KB |
| Downloaded: |
319 Time(s) |
 Download |
| Filename: |
Rotax magnetic plug check.pdf |
57.73 KB |
| Downloaded: |
336 Time(s) |
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
