floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Fri Jul 30, 2010 7:59 am Post subject: Upgrade Question: ref. 6-ZU-4-1 |
Mike,
You will need to enlarge the slot.
Here is what I did. After the ailerons are rigged, I put the stop in place
but did not fasten it down. Push the stick to get the aileron to one stop
on the wing at the aileron. The new control stop will slide over as the
stick moves. Measure how far it slid then make the slot that much wider.
Repeat for other side.
Floyd Wilkes
601XL
_________________ Floyd Wilkes |
AZFlyer
Posted: Fri Jul 30, 2010 9:55 am Post subject: Re: Upgrade Question: ref. 6-ZU-4-1 |
Thanks Floyd, however, I have riveted in the piece with the slot so I will need to climb up through the access hole and cut away the material.
Appreciate your feedback. How much did you need to open up the 50mm slot?
Mike
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
floyd wilkes
Posted: Fri Jul 30, 2010 3:41 pm Post subject: Upgrade Question: ref. 6-ZU-4-1 |
Mike,
I bet with your new found rivet removal skill, you can remove the rivets in
short time.
I would think it difficult to expand the slot while riveted in place but
maybe you have a plan.
On mine, the left and right extensions were different. One was about 30 MM.
I made the stops on the wing so that the aileron would travel about .5
degree more than the new stop allows to ensure you cannot put too much
pressure on the cable.
Good luck
Floyd
