Turbo_Boss
Joined: 14 Jul 2009 Posts: 10 Location: Panama Rep. of Panama - Central America
Posted: Mon Jul 26, 2010 8:32 pm Post subject: Rotax 912 Carburator Sockets Problem |
Hello guys,
I have problem with the Rotax 912 carburator sockets were the rubber get separated from the steel insert part.
In my club, almost everybody with 912 engines, has exactly the same problem with these carburator sockets showing the same type problem.
Please look at the pics. My 912 is like 18 months old and it only have 52 hours of use and this part have fail. Also, you will see a white powder. I dont know what is that.
Also, I was checking the net and found this company that produce 912 socket carburators in USA and they say they are better than the Rotax ones.
http://jbmindustries.com/
Have any one have try these JBM 912 carburator sockets? Are they better?
THX,
Isaac
69.92 KB |
7699 Time(s) |
31.87 KB |
7699 Time(s) |
33.89 KB |
7699 Time(s) |
rickofudall
Posted: Tue Jul 27, 2010 12:03 am Post subject: Rotax 912 Carburator Sockets Problem |
The white powder is probably the result of corrosion of the aluminum, i.e. aluminum oxide. I've not seen this type of separation of carb sockets before, the usual failure is cracks in the interior of the socket that causes air leaks and can destroy the engine. There was a bad batch of sockets produced a few years ago that were fitted to both the 912 and the HKS engines. I replaced mine with the JBM units and have seen no cracking since, although inspection and replacement of the carb sockets is a regular maintenance item checked off at 100 hour and annual conditional inspections.
Rick Girard
On Mon, Jul 26, 2010 at 11:32 PM, Turbo_Boss <turbo_boss(at)cwpanama.net (turbo_boss(at)cwpanama.net)> wrote:
[quote] --> RotaxEngines-List message posted by: "Turbo_Boss" <turbo_boss(at)cwpanama.net (turbo_boss(at)cwpanama.net)>
Hello guys,
THX,
Isaac
http://forums.matronics.com/viewtopic.php?p=306411#306411
http://forums.matronics.com//files/rotax912carburatorsocket_a_759.jpg
http://forums.matronics.com//files/rotax912carburator_socket_2_177.jpg
http://forums.matronics.com//files/rotax912carburator_socket_1_376.jpg
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
Posted: Tue Jul 27, 2010 6:53 am Post subject: Re: Rotax 912 Carburator Sockets Problem |
I have used the JBM Industries sockets with great success and cost savings on more than one 912/914 engine. I think they are as good as, or better than, the ones sold through Rotax at twice the price. BUT, looking at your pictures the real problem is moisture. Everything has a layer of corrosion on it. Your environment seams to have a lot of moisture and that is the problem. It looks like you will be replacing the carb sockets and probably other items as a regular scheduled maintenance requirement.
Rick
_________________ 701Driver
N35 26.700, W118 16.743 |
Roger Lee
Posted: Tue Jul 27, 2010 9:31 am Post subject: Re: Rotax 912 Carburator Sockets Problem |
I agree with both these gentlemen.
This is corrosion and most likely from water or a very high humidity area. Once it starts this process the rubber will come away from the metal. If you live in a high moisture environment I would spray down a large part of my engine and exposed parts (metal and rubber) with Boeing T-9 (my first choice as it is a more dry application) and Corrosion -X is my second choice (a little wetter after it is applied). These will block out the rain or moisture.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Turbo_Boss
