CJ6 Hot Starts
Okanogan Lew
PostPosted: Mon Jul 26, 2010 10:32 am    Post subject: CJ6 Hot Starts Reply with quote
Hey guys, I got one for you. I flew into Fairchild AFB for a show & parked the CJ. The next day we were to fly in the show & start up time was noon. By then it was about 90 degrees & I preformed my standard start-up routine, which is 5 primes with a pull of the blade between each. I hit the start & the engine turned over, but would not start. It didn't even fire. I gave it 3 more primes, but still nothing. I then gave it about 5 primes & still nothing. By then, I was very low on air & gave up. The next morning about 0700 I tried it again with my usual start-up routine & the blade turned about a half & it fired off. I ran it for about 15 minutes & shut it down. We were again scheduled to fly at noon & by then it was in the mid 90's. I did my usual start-up & again it would turn over, but wouldn't even fire. I primed the hell out of it & still nothing. Finally gave up again. This morning, it started with the usual start up routine. Go Figure!! A couple of points. I had 1/2 car gas & 1/2 av gas in the tanks. The right side of the plane (primer side) was facing the sun. Do you think the heat cased a vapor lock in the primer tube & was blocking the fuel flow? Any other thoughts? I have the 285 HP engine & it ran fine for the hour trip home. Thanks in advance for an info.
mark.bitterlich(at)navy.m
PostPosted: Mon Jul 26, 2010 1:51 pm    Post subject: CJ6 Hot Starts Reply with quote
I personally think this has something to do with the "shower of sparks"
(Booster Coil... Whatever) system used in these aircraft. I had a very
bad problem with this exact same thing in my YAK-50, and it still is not
totally corrected, but since I use Dennis's high performance wire and
plugs, I was able to correct a lot of this by using a plug gap of .020
versus .032, or .035 However, the engine would always start when cold,
even when using a .035 plug gap and it always RAN well once started even
with that wide plug gap. This tends to infer that for some reason the
starting system is not producing enough energy to fire properly with a
hot engine and a wide plug gap. I really am not sure how much this has
to do with fuel. I was running 100% 100 Low Lead at the time. The
engine simply would not start when hot and did EXACTLY what yours did.
Outside temperature on the days this happened were also in the 90's. So
while fuel MIGHT have been involved, it sure did not have anything to do
with MO-GAS being used.
I worked on this problem a long time. I replaced the Shower of Sparks
vibrator coil with one from another YAK-50. However, it was NOT a new
one. Never-the-less, a working one. It did not help. I replaced the
high tension wire going from the coil to the mag. No help. I then
devised a way to make darn sure that the wire running from the coil to
the mag was making good contact inside the mag cap (where normally the
wire is penetrated by a sharp screw in pin. No help. I replaced the
mag rotor. No help. I then replaced the mag cap. No help. I then
put in new spark plugs gapped to .020 Problem went away... Mostly.
But it still rears it's ugly head now and again on a very hot start.
A gent from Australia (sorry I forget your name) mentioned that there is
an adjustment of the buzzer points that are internal to the shower of
sparks coil, and he is absolutely correct. I took a few apart and saw
that adjustment but did not toy with it, because I was reluctant to
change it not knowing what the exact gap is supposed to be. Since the
Shower of Sparks coils are identical in the YAK-50 and the CJ-6A models,
I wonder if Doug or anyone else has a "Task Card" that specifies what
that gap is supposed to be. Like the Australian Gent, I have a strong
feeling that this gap will make a HUGE difference in the voltage output.
Misadjustment could easily result in not enough energy to fire a really
hot engine, and I have suspected this might have been my problem all
along. I just am not sure how to test this though. Looking at the
output of a coil like that is not really simplistic, but it might be
simply a matter of trying what the other gent did, and just move it one
or two clicks and see what happens.
In any case, I don't have a definitive answer, and the matter is worth
discussing.
Mark Bitterlich
dsavarese0812(at)bellsout
PostPosted: Mon Jul 26, 2010 2:05 pm    Post subject: CJ6 Hot Starts Reply with quote
Take a look at the points in the "shower of sparks" unit. I would venture a guess they are pitted. If so, burnish the points with a fine point file and test again. I do not know the correct gap, but Mark is 100% right, as usual. The gap will make a huge difference in the spark. With the "mounding" of the points, the gap is reduced and the output of the unit is also reduced. Clean up the points first. Then for experimentation, adjust the gap and watch the spark "jump" from the wire to ground. REAL easy to do on the CJ by simply removing the cover. The wider the point gap, the bigger the spark jump....to a point. Get them too wide and nothing will happen. I adjusted mine at one time after burnishing the points and called the adjustment the "that looks good adjustment" or as we say in Alabama, 'bout right!
Dennis
okanoganlew(at)gmail.com
PostPosted: Mon Jul 26, 2010 2:46 pm    Post subject: CJ6 Hot Starts Reply with quote
Mark, where is the shower of sparks unit located?  I assume it's close to the mags? I have 5 chinese manuals, but none of them show it.
Paul
On Mon, Jul 26, 2010 at 2:50 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
discussing.
Mark Bitterlich
dougsappllc(at)gmail.com
PostPosted: Mon Jul 26, 2010 2:58 pm    Post subject: CJ6 Hot Starts Reply with quote
Paul,
Normally on the left hand top motor mount leg, has a shielded plug wire lead coming out of it.  Have also seen them mounted on the fire wall, but always on the left hand side.
Doug
On Mon, Jul 26, 2010 at 3:45 PM, Paul Lewis <okanoganlew(at)gmail.com (okanoganlew(at)gmail.com)> wrote:
[quote] Mark, where is the shower of sparks unit located?  I assume it's close to the mags? I have 5 chinese manuals, but none of them show it.
Paul
discussing.
Mark Bitterlich
PostPosted: Mon Jul 26, 2010 3:44 pm    Post subject: CJ6 Hot Starts Reply with quote
It is mounted on the upper engine mount on the left side (from the cockpit). There is a shielded wire coming from the unit to the front cover plate of the left magneto. Look at the right mag and you will see there is no shielded wire going to the front cover plate.
Dennis
viperdoc(at)mindspring.co
PostPosted: Mon Jul 26, 2010 4:49 pm    Post subject: CJ6 Hot Starts Reply with quote
Okanogan,
Don't know what the CJ procedure for starting the engine when it is hot but
the YAK calls for a couple of strokes of prime to start when the temp is
over 90 degrees (35 -37 C). I do not have my 42 manual close buy but
remember it called for less prime than the 6 in winter. I personally prime
first then pull 4 blades stopping on a compression stroke (I assume that
with increase in resistance to advance the blade). Is it possible that you
have over primed?
Next time this happens open your intake drain if you have one in place to
see how much fuel drains out.
We had (have) temps in Alabama now constantly in the high 90's F. and I have
not had an issue starting the 52. I had a different issue with the 50
starting but it had nothing to do with fuel vapor pressure or the electrical
system. It has more to do with leaking air around the base of a couple of my
air injectors. At least I think it was that so far.
I am running 100 LL too.
Doc
Noplugs
PostPosted: Mon Jul 26, 2010 5:28 pm    Post subject: Re: CJ6 Hot Starts Reply with quote
Paul
Look in your manual Figure 11-12
 Filesize:  151.15 KB
 Viewed:  16697 Time(s)
wlannon(at)persona.ca
PostPosted: Mon Jul 26, 2010 7:03 pm    Post subject: CJ6 Hot Starts Reply with quote
Your problem is simple. It is pretty severe over priming.
You are trying to fire up a air/fuel mixture with a ratio of maybe 3:1 (?)
instead of about 14:1. You are also washing the cylinder walls of oil which
is already thinned out by the high temperature and increasing the
possibility of hydraulic lock with excess fuel.
In the conditions you describe I use 1 or 2 shots after filling the primer
for the Huosai and the M14P. Works every time. For the R1340 I use 1/2
shot after filling the primer (large barrel type).
In addition I never pull the prop through while priming. I put that in the
same category as Russian roulette. If you have a failed mag. switch, a
disconnected or a broken "P"
lead you have a live mag. and are flirting with disaster.
Walt
PostPosted: Mon Jul 26, 2010 7:30 pm    Post subject: CJ6 Hot Starts Reply with quote
Thanks Walt, I posed the overpriming question to the Yak List a while back & was told that the priming mixture went into the super charger & wouldn't wash down the cyclinders.  Was that bad info?
Paul
On Mon, Jul 26, 2010 at 8:02 PM, Walter Lannon <wlannon(at)persona.ca (wlannon(at)persona.ca)> wrote:
[quote]--> Yak-List message posted by: Walter Lannon <wlannon(at)persona.ca (wlannon(at)persona.ca)>
You are trying to fire up a air/fuel mixture with a ratio of maybe 3:1 (?) instead of about 14:1.  You are also washing the cylinder walls of oil which is already thinned out by the high temperature and increasing the possibility of hydraulic lock with excess fuel.
In the conditions you describe I use 1 or 2 shots after filling the primer for the Huosai and the M14P.  Works every time.  For the R1340 I use 1/2 shot after filling the primer (large barrel type).
In addition I never pull the prop through while priming.  I put that in the same category as Russian roulette.  If you have a failed mag. switch, a disconnected or a broken "P"
Walt
PostPosted: Mon Jul 26, 2010 7:33 pm    Post subject: CJ6 Hot Starts Reply with quote
Paul;
The reason for that is simply that it is not a 'shower of sparks" system.
The subject has been discussed ad infinitum on this list but of course makes no difference.
In our lexicon it is a "start boost coil". In the CJ6 manuals it is a "starting ignition coil". The P/N is DH-2, it is located on the LH firewall readily identified by the HT lead to the LH mag.
It is an absolutely exact copy of the original Bendix/Scintilla
unit from the 1940's.
Walt
PostPosted: Mon Jul 26, 2010 7:53 pm    Post subject: CJ6 Hot Starts Reply with quote
Paul;
That is true and is surely slightly less of a hazard than direct - to cylinder priming. Depends on how much fuel and evaporation time. As soon as engine rotation starts the destination is the cylinders with the blower turning at 7.87:1 for the Huosai.
Walt
ph451(at)yahoo.com
PostPosted: Mon Jul 26, 2010 8:50 pm    Post subject: CJ6 Hot Starts Reply with quote
Walt,
What do you mean by "after filling the primer?"
--- On Tue, 7/27/10, Walter Lannon <wlannon(at)persona.ca> wrote:
Subject: Re: CJ6 Hot Starts
To: yak-list(at)matronics.com
Date: Tuesday, July 27, 2010, 4:02 AM
Walt
PostPosted: Tue Jul 27, 2010 4:18 am    Post subject: CJ6 Hot Starts Reply with quote
When you first start pushing the primer in the pressure is low. If you open the intake drain and watch for fuel to start to drip out it takes about 3 to 5 cycles on the primer pump on the cylinder side to feel the pressure increase in the primer handle (resistance to pushing). Now watch the intake drain as you continue to pump. It takes 2 more strokes to see a small amount of fuel to start flowing from it. Push in the full 6 strokes and watch the stream that forms flowing out of the drain.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Paul Hamlin
Sent: Monday, July 26, 2010 11:50 PM
Walt,
--> Yak-List message posted by: Walter Lannon <wlannon(at)persona.ca>
Walt
PostPosted: Tue Jul 27, 2010 8:09 am    Post subject: CJ6 Hot Starts Reply with quote
Walt, his problem may have been over-priming. Mine is certainly not.
I also do not think his was either to be honest. This is not a person
who has never started a hot engine before, and the problem he is having
is something that just started.
Mark Bittelich
PostPosted: Tue Jul 27, 2010 8:12 am    Post subject: CJ6 Hot Starts Reply with quote
Thanks Dennis!
Mark
P.s. I'll try your way!
PostPosted: Tue Jul 27, 2010 8:20 am    Post subject: CJ6 Hot Starts Reply with quote
Some call it TOMATO Some call it TOOMATOO, what-ever.
If you really want to be accurate, let's call it a Model "T" Vibrator
Coil.
In any case, this is a coil that is stand alone and uses a square wave
input in order to generate a secondary output from a transformer. The
square wave is generated by a BUZZER with electrical contacts that makes
and breaks a 28 VDC input. This produces a steady stream of spark
energy that is in no way controlled by internal MAG components, like
points, etc. The internal MAG coil is not used, the internal MAG points
are not used, the Internal MAG Cigarette is not used. The spark energy
is fed directly to the ROTOR and as the ROTOR spins a steady stream of
spark energy jumps to each spark plug in turn. In truth the engine
should be able to RUN on this energy alone. Not very well, because on a
M-14 it is very much retarded, but it will in fact run.
Whatever you want to call it is fine with me, but most people understand
it when you call it a SHOWER OF SPARKS. BOOSTER COIL is fine too, but
it sure is not BOOSTING anything as far as I can see, so it is a simple
matter of nomenclature. OK? Walt is correct in that the people that
made this unit for 1940 engines called it a "Booster Coil". He's right.
It does BOOST the 28 volts way up there. It then provides a continious
"shower of sparks" as the rotor turns. So it is a BOOSTER COIL that
produces a SHOWER OF SPARKS... Or if not that... A WHOLE LOT OF SPARKS
JUST WAITING TO GET THERE. Whatever.
The point gap will influence the length of the square wave which will in
turn impact the strength of the field as it builds. The longer the time
period of the square wave, the bigger the transformer flux field will
build. If you go too much, the field will already be at maximum and you
will just start flowing excess current through the coil heating it. Be
nice to be able to look at it somehow with a measurement and be able to
go for the max. Just not sure how to do that. I think just LOOKING at
it may be in fact the best solution.
Mark
PostPosted: Tue Jul 27, 2010 11:22 am    Post subject: CJ6 Hot Starts Reply with quote
Hi Paul;
Operate the primer until you feel a definite resistance to the down stroke.
If the primer is in good shape - no leaking ball valves, etc. it should take about 3 strokes
Do the upstroke slowly for best results
Cheers;
Walt
