Rib Stitching
Richard Pike
PostPosted: Tue Jul 20, 2010 6:26 pm    Post subject: Rib Stitching Reply with quote
Had a friend come over today and help me with the covering. Occurred to me that maybe some Kolbers had never done or seen any rib stitching, so we filmed it.
This is doing the false ribs:
http://www.youtube.com/watch?v=estp-yxb0XA
This is doing the normal ribs:
http://www.youtube.com/watch?v=uJjuljzCpbI
Richard Pike
MKIII N420P (420ldPoops)
slyck(at)frontiernet.net
PostPosted: Tue Jul 20, 2010 6:58 pm    Post subject: Rib Stitching Reply with quote
Very well done Richard. The advantages are: doesn't weaken the rib as much as drilling and riveting
and if you need to recover you don't have to drill 'em out.
-besides, it looks neat.
BB
Richard Pike
http://forums.matronics.com/viewtopic.php?p=305684#305684
Eugene Zimmerman
PostPosted: Wed Jul 21, 2010 4:09 am    Post subject: Rib Stitching Reply with quote
But is it actually stronger?
The stitch would surely tear/wear through the fabric before a rivet
would pull through the reinforcing tape and fabric?
Gene
BB
PostPosted: Wed Jul 21, 2010 4:59 am    Post subject: Rib Stitching Reply with quote
In a certified aircraft you lay(glue) reinforcing tape on before the rib stitching. I would do a Kolb the same way.
My Aeronca used little stainless screws into aluminum ribs, also through reinforcing tape.
I got in a lovely 8:00 PM flight last night. 77F and calm. Wonderfully tranquil and smooth.
Don't get many of those.
BB
On 21, Jul 2010, at 8:09 AM, Eugene Zimmerman wrote:
The stitch would surely tear/wear through the fabric before a rivet would pull through the reinforcing tape and fabric?
Gene
> BB
PostPosted: Wed Jul 21, 2010 6:35 am    Post subject: Rib Stitching Reply with quote
Gene
Rib stitching was used for flat wooden rib strips which gave the stitch more
area and a flat surface to attach the fabric.
Normally, sheet metal ribs use clips or screws.
Fabric rivets work well with tubing, especially small, 5/16" tubing.
Rib stitching does not grip small diameter, smooth tubing as well as it does
flat wooden strips.
Tube ribs, 5/16", have a very small apex that makes contact with the fabric.
I noticed Richard P made his stits as wide as the reinforcing tape. Seems
to me this would pull a pucker in the fabric as the knot was tightened. I
could not tell from the vid clip.
Richard Pike
PostPosted: Wed Jul 21, 2010 8:39 am    Post subject: Re: Rib Stitching Reply with quote
Wow, good responses, thanks guys!
To reply to Eugene's question, if you did not use reinforcing tape, the cord would cut through the fabric so quickly you would not even be able to do it, so whether you are using cord or rivets, you have to use reinforcing tape below the cord or rivet in either case. Then whether you are using a rivet or a cord passing over it, one is going to be as strong as another. The cord method has a long history of not failing, and at the speeds we fly, it is surely not an issue.
In reply to John's comment that rib stitching does not grip small diameter, smooth tubing as well as it does flat wooden strips, I guess we will have to agree to disagree. If you have a length of reinforcing tape laying along the top of the rib, and a cord wraps around that rib, then the cord is pulling on the tape across the full width of the tape. A rivet flat across the top of the tape is touching more of the tape, but less of the rib, except that is not an issue, because of the mechanical assistance of the finishing tape over the whole bit, which is what is actually holding everything together.
As far as 5/16" tube ribs having a very small apex that makes contact with the fabric, that is the case whether you are using rivets or cord. The fabric is held securely by the finishing tape that you lay over the top of the whole business after your mechanical attachment is complete. If you did not put the finishing tape over everything else, I doubt that either method would be very secure.
Also, you do not get a pucker in the fabric if you use the right size reinforcing tape. I used Stits 1/4" wide reinforcing tape, and when the cord is tightened, it pulls down perfectly with no pucker. If you used wider reinforcing tape, then obviously you would have a mess.
We had to use rivets at the tip rib, since the reinforcing angle right next to the rib precluded rib stitching, also we riveted a couple places above and below the main spar since there is no way to get a needle around it, and it wasn't worth the trouble to get fancy and make a custom needle.
Here are pictures comparing two adjacent ribs, one the riveted tip rib, and one stitched, the finishing tape has not yet been ironed. Judge for yourself which one creates more of a pucker, bump or whatever.
Stitching the full ribs is fairly time effective, because you are effectively doing two rivets with one full stitch, doing false ribs is certainly not. Rivets would have to be quicker, except I hate drilling all those holes in my ribs, and invariably I screw a couple up, and I hate that. To each his/her own, all this is for is to shed a little light on the process for those who might want to try the alternative.
Richard Pike
 Filesize:  24.22 KB
 Viewed:  10101 Time(s)
 Filesize:  30.59 KB
williamtsullivan(at)att.n
PostPosted: Wed Jul 21, 2010 8:53 am    Post subject: Rib Stitching Reply with quote
My two cents worth. I had two sets of wings for the Firestar, one original set that was damaged in a storm rollover, and the other set was damaged when I crashed it. One set was rib stitched, and the other was riveted. Even though both of them had extensive structural damage, neither one had any sign of attachment failure. When I rebuilt the wings, I used rivets because of extensive experience and familiarity with them. If I do another set, ecpecially a very lightweight set, I probably will use stitching twine to cross brace the ribs. That way there will be less warping when the fabric is tightened.
      Bill Sullivan
      Windsor Locks, Ct.
      5 rib FS 447
Eugene Zimmerman
PostPosted: Wed Jul 21, 2010 5:59 pm    Post subject: Rib Stitching Reply with quote
Richard,
Thanks for that clarification. In the video I missed seeing the
reinforcing tape as you were doing the stitching. Either your
workmanship is exceptional, or my eyes are not. Apparently it is the
former. My confidence in you as a Kolb builder is restored. <grin>
Gene Z
PostPosted: Wed Jul 21, 2010 7:44 pm    Post subject: Rib Stitching Reply with quote
Then
Maybe if both systems are using the same width reinforcing tape. However, I
believe 1/4" reinforcing tape will not be as strong as 1/2".
Even at the speeds Kolbs fly, there are documented rib stitch failures.
Yes, rib stitching has a long history, but I personally know of two Kolb
aircraft that suffered failure of rib stitches on top of the inboard ribs,
probably caused by prop drumming, or improper rib stitch technique.
One may use whatever method they desire, but I will stick to fabric rivets
on my Kolb.
WhiskeyVictor36(at)aol.co
PostPosted: Wed Jul 21, 2010 8:23 pm    Post subject: Rib Stitching Reply with quote
In a message dated 7/21/2010 12:41:05 P.M. Eastern Daylight Time, richard(at)bcchapel.org writes:
Richard,
I noticed that the first picture showed pinked edges on the finishing tape, while the second picture showed straight edged tape. Are these on the same plane/wing?
Bill Varnes
Original Kolb FireStar
Audubon NJ
Richard Pike
PostPosted: Thu Jul 22, 2010 6:03 am    Post subject: Re: Rib Stitching Reply with quote
[quote="WhiskeyVictor36(at)aol.co"]In a message dated 7/21/2010 12:41:05 P.M. Eastern Daylight Time, richard(at)bcchapel.org writes:
Richard,
Bill Varnes
Audubon NJ
Yep. I wanted to use bias tape on the final outboard rib, as the fabric at the front drops off at a fairly steep angle, and the straight tape would wrinkle badly. Unfortunately, the only bias tape I have has pinked edges, so it will be slightly different from the rest of the tapes, but I don't think it will show much after it is painted.
Good catch.
Richard Pike
Richard Pike
PostPosted: Thu Jul 22, 2010 6:31 am    Post subject: Re: Rib Stitching Reply with quote
John Hauck wrote:
Maybe if both systems are using the same width reinforcing tape. However, I believe 1/4" reinforcing tape will not be as strong as 1/2".
I believe you are right. Now we are both happy. Very Happy
Richard Pike
