Facet Boost Pump Fuses
messydeer
PostPosted: Thu Jul 15, 2010 6:36 am    Post subject: Facet Boost Pump Fuses Reply with quote
Hi!
I'm wondering what size fuse to use for my Facet 40104 boost pump. I talked to somebody in their engineering department and he said 3 is recommended. I told him I'd heard of a couple people blowing 3A fuses in a 40105. They replaced it with a 5A and had no further problems. For some reason Facet is stingy with documentation. They list 20 or more pumps and give only their psi and gph ranges individually, then lump them all together and say they draw an average of 1.6A. The 04 I have is the smallest, with the 05 only slightly bigger. http://www.facet-purolator.com/index.php?option=com_content&task=category&sectionid=7&id=16&Itemid=31
I asked if putting a 5A in would work. The Facet dude said it probably would work, but it'd increase the chance of wrecking the coil, but wouldn't get hot enough to start a fire. I have 15-20' round trip of 20awg wire going to it, so I know a 5A fuse would protect the wire. I plan on using this as a boost pump for my mechanical, turning it on before startup, check the pressure, then some seconds later crank the engine. It would then be turned off at altitude and back on for landing. The boost pump is near the bottom of the cowl, ~1' below the mechanical pump. They are in series with no recirculation, so it would be pumping with no flow until cranking.
The fuses I'm thinking of are the fast ATO/ATC style. I could go with slower 3AG fuses, if there is a any advantage in doing this. I assume that if the Facet is pumping against a closed valve a couple feet downstream it would in a few seconds reach its max current draw. I haven't heard of anyone wrecking their boost pump, just a few that blew 3A fuses.
I'm waiting for Facet to return my emailed questions. I also could bench test this pump with my VOM and see what the current draw really is.
Suggestions?
Dan
PostPosted: Thu Jul 15, 2010 1:40 pm    Post subject: Facet Boost Pump Fuses Reply with quote
At 09:36 AM 7/15/2010, you wrote:
Hi!
That is . . . shall we say . . . no . . . I'll be civil.
First, supply fuse (at least in an airplane) is never
intended to protect devices . . . only wiring.
until cranking.
If it's 20AWG, put a 7A fuse in an don't loose
any sleep over it. Having too robust a feeder
protection cannot put anything inside the pump
at risk.
We had a thread on this topic some months ago. The
current draw by solenoid pumps is pulsed. I cited
a number of patents that go back to the 50s or earlier.
The first devices had mechanical contacts that pulsed
the coil when the fuel pumping piston approached end
of stroke thus pulling the piston back against a spring
for another stroke. The energy consumption of these
pumps WAS somewhat dependent in fuel flow. You could
hear the stroke-rate go up as flow increased.
Modern pumps are all solid state, no switches and
simply pulse the coil so many times per minute irrespective
of flow rate. If the flow is high, the piston strokes
long in the bore. If the flow is low, the piston barely
moves with each pulsed and tends to stay in the max
compressed end of the stroke.
Trying to get any sort of current measurement on
on of these things by watching a meter is meaningless.
It will be all over the place. A true ENERGY
measurement must be made with some RMS type ammeter
having a very long time constant . . . or a fast
data acquisition system that will secure a sufficiently
verbose data stream to do bit-wise integration of
current values.
I've got that on my list of things to do . . . in fact,
there's a Facet pump on my bench loaned to me by a
generous Lister for that purpose. I tried to get
real engineering data from Facet on several occasions
with no success. I'm doubtful that anyone there
even understood the question.
Nonetheless, the have been building a really slick,
trouble-free product for a very long time. You don't
have to know how it all works to serve great hamburgers,
fries and a shake . . . just follow directions. It's
the ISO way.
jloram
PostPosted: Thu Jul 15, 2010 6:20 pm    Post subject: Facet Boost Pump Fuses Reply with quote
[quote] --
messydeer
PostPosted: Fri Jul 16, 2010 10:57 am    Post subject: Re: Facet Boost Pump Fuses Reply with quote
Thanks, Bob Smile
Nice to get some background on how the pump works.
Facet told me in an email 5A would be fine, I see from Table 11-3 of AC43.13-1B a 5A fuse would work, and you say 7A is peachy. So I'm happy and will think no more about this issue.
 Filesize:  36.83 KB
 Viewed:  7143 Time(s)
Dan
PostPosted: Fri Jul 16, 2010 5:05 pm    Post subject: Facet Boost Pump Fuses Reply with quote
> at risk.
Would this reasoning not lead to running "really" robust feeders/fuses, and
then a fuel pump (or other device) with and internal problem that is
generating a lot of heat (fire/smoke)?
I agree that we're not trying to 'save/protect' the pump, rather trying to
prevent smoking wires, but a smoking load can be a big problem, too.
Most devices we use in our airplanes are considered
not flight worthy if they exhibit any failure mode that
becomes a hazard source for combustion . . . emitting
smoke is frowned upon too. The "really robust" feeders
was more rhetorical than anything else . . . after all,
with a fuse block, one has the option of selecting the
optimal fuse for each application . . . and easily
changing it if later circumstances suggest it's a
good idea. Specifically, with the FACET being a low
energy device totally enclosed in a metal box. The
risks are nil . . .
[img]cid:7.1.0.9.0.20100716195619.01fe8f38(at)aeroelectric.com.0[/img]
Although I seem to recall that G. Richter suggested
that the entire airplane could be configured with an
array of one-size-fits-all, self-resetting PTC polyswitches
soldered to a nifty etched circuit board product he
offered. But when it's so easy to achieve the elegant
solution, why not do it?
 Filesize:  26.77 KB
 Viewed:  7133 Time(s)
