Drilling Flap Bearing Blocks
stazel(at)cpros.com
PostPosted: Tue Jul 13, 2010 2:04 pm    Post subject: Drilling Flap Bearing Blocks Reply with quote
I'm ready to drill the bolt holes through the F445 Bearing Blocks, but I'm concerned about the possibility of the drill bit walking and the hole being way off location when it breaks through the other side even though I used my protractor to set the drill press table normal to the drill line. I have considered using a 3/16" spur point drill to make a pilot hole and then opening up with a #10 per instructions. Seems like that might work better than just punching through with a #10 in one shot. Am I over analyzing this?
Stan Loer
RV8 QB
stazel(at)cpros.com (stazel(at)cpros.com)
Michael Wynn
PostPosted: Tue Jul 13, 2010 2:10 pm    Post subject: Drilling Flap Bearing Blocks Reply with quote
Hi Stan,
If I were you, I would start with something a lot smaller, like a #40 and then work my way up. Use a center punch to guide the first hole.  Replacement blocks are not very expensive. Ask me why I know this...
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 7/13/2010 3:05:17 P.M. Pacific Daylight Time, stazel(at)cpros.com writes:
[img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/QMARK.GIF[/img][img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/ARROW.GIF[/img] I'm ready to drill the bolt holes through the F445 Bearing Blocks, but I'm concerned about the possibility of the drill bit walking and the hole being way off location when it breaks through the other side even though I used my protractor to set the drill press table normal to the drill line. I have considered using a 3/16" spur point drill to make a pilot hole and then opening up with a #10 per instructions. Seems like that might work better than just punching through with a #10 in one shot. Am I over analyzing this?
Stan Loer
RV8 QB
="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Michael Wynn
RV 8
San Ramon, CA
Site Admin
PostPosted: Wed Jul 14, 2010 5:29 pm    Post subject: Drilling Flap Bearing Blocks Reply with quote
Agreed. Start small and work your way up. Also, make sure its clamped to the table REALLY well. I have a huge scar on my hand from where I didn't... Wink
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Enjoying The Fruits of 2500 Hours of Labor...
At 03:09 PM 7/13/2010 Tuesday, you wrote:
Hi Stan,
Michael Wynn
RV 8 Finishing
San Ramon, CA
Stan Loer
RV8 QB
<mailto:stazel(at)cpros.com>stazel(at)cpros.com
RV-8 #82880 N998RV
