pilot4pay
Joined: 01 Jan 2007 Posts: 171 Location: Louisville, KY
Posted: Thu Jun 24, 2010 4:11 am Post subject: Skinning the Stab |
the IPL implies that one should completely assemble and cleco the entire stab (nose and rear skins) then disassemble deburr etc.
The photographs in the assembly CD imply that the rear skins are riveted (except spar) before fitting the nose skin.
The only down side I see is there will be some difficulties deburring the spar rivet locations. Probably could gently lift the edge of the rear skin to get the top surface, but the back of the spar would be closed off. dunno if that matters too terribly much on as the rivet pretty much crushes any little flakes or aluminum snikkies.
What have you guys done?
| | - The Matronics Zenith640-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith640-List |
_________________ Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin |
Scott Stewart
Joined: 29 Jul 2008 Posts: 30 Location: Windsor, California
Posted: Thu Jun 24, 2010 4:37 am Post subject: Re: Skinning the Stab |
Hi Craig,
I drilled and clecoed the full assembly before doing any riveting (see attached picture).
I noticed that many of the pictures on the CD are from the assembly of their prototype and show parts being riveted before they should be or installed in the wrong sequence. The pictures should only be used as a reference to understand how the parts fit together. The IPL gives you the correct sequence; and even then, you need to be sure to read ahead and use some personal judgment on the best sequence to build your plane.
Good luck with your build.
120.83 KB |
11227 Time(s) |
_________________ Scott Stewart
CH-640 built from plans
Flying since August 2014 |
carlossa52(at)gmail.com Guest
Posted: Thu Jun 24, 2010 5:53 am Post subject: Skinning the Stab |
Craig, when I built the tail feathers for my 601 HD (still under construction), I did a complete assembly with clecoes and only then did the deburr/clean/prime dance.
Personally, I think it is better to do it this way as you do all the priming in one session: I do it in the garage, where the car is the preferred tenant, so there is some prep work necessary before I do the priming.
So, much better to do it once for the whole assembly.
YMMV...
Cheers
Carlos
CH601-HD, plans
Rear fuse in progress
On 24 June 2010 08:11, pilot4pay <pilot4profit(at)sbcglobal.net (pilot4profit(at)sbcglobal.net)> wrote:
[quote]--> Zenith640-List message posted by: "pilot4pay" <pilot4profit(at)sbcglobal.net (pilot4profit(at)sbcglobal.net)>
Craig Smith
CH640 builder
SN: 0078
pilot4pay
Posted: Mon Jun 28, 2010 9:48 am Post subject: Re: Skinning the Stab |
Thanks, your reasoning makes sense.
CH640 builder
SN: 0078
--George Carlin |
super58d
Posted: Tue Aug 10, 2010 3:15 pm Post subject: Re: Skinning the Stab |
Craig, I had the same questions and took a middle of the road approach to the issue. I riveted about half way up the rear skins on both sides. This held the entire assembly together much better and helped keep it straight and true while drawing in the forward skins. It then still allowed me to lift the forward sections to debur the new holes from the nose skins. I found that ensuring the whole assembly stayed straight and true while keeping everything together was quite difficult while applying pressure to pull in the nose skins.
_________________ Mark
s/n 094
My Build Site:
http://www.mykitlog.com/stephen363/ |
