eric hendriks
Posted: Thu May 13, 2010 12:22 pm Post subject: kitfox landing gear |
Hello
I have a KF 3 but I dont like the open bottom with this kind of landing gear.
I have seen a picture from a kf with a landing gear wich has his springs like a Pipercub
Does anyone have plans or something so that I can rebuild mine?
Thank You
Eric (NL)
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Thu May 13, 2010 1:29 pm Post subject: Re: kitfox landing gear |
There are several designs for this out on the market, now.
Airdale, Highwing LLC and Kitfox itself has kits on the market for this conversion.
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
larry huntley
Posted: Thu May 13, 2010 2:50 pm Post subject: kitfox landing gear |
What kind of springs have you seen on a Piper Cub? Larry
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
57_kid
Posted: Thu May 13, 2010 3:41 pm Post subject: Kitfox landing gear |
I believe the people who now own the Kitfox line sell a landing gear like
the cub has. John and Deb Mcbean I think .. I'm sure someone else will chime
in hear at some point
Av8r3400
larry huntley
Posted: Fri May 14, 2010 3:39 am Post subject: kitfox landing gear |
Die springs would be great. Is there an STC for a Cub? Larry
Dick Maddux
Posted: Fri May 14, 2010 3:54 am Post subject: kitfox landing gear |
The landing gear you are referring to is the "bush gear".If you go to highwing llc.com you will see a picture of my "bush gear" I bought this from Lowell Fixx and it was a bolt on installation. Everything fit perfectly. You use your old wheels,brakes and axles.
I have flown with this gear for over 50 hrs now. It is a vast improvement over the old gear. Better ground handling, No bungees,gear spread increases by almost 3 ft,no weight increase....it doesn't get any better. I even sold my old gear on EBAY so recovered a major portion of the purchase price.
John McBean at Kitfox also offers this style of gear (albeit using different wheels,brakes,axles..last time I checked)
You also have the option of the tough heavier all aluminum spring gear from Grove.
Dick Maddux
Fox 4
Milton,Fl
Pat Reilly
Posted: Fri May 14, 2010 9:07 am Post subject: Kitfox landing gear |
Eric, Lowell Fitt , High Wing LLC also builds a sprung bush gear with or w/o metal fairings. I have it, and recommend it.
Pat Reilly
Mod 3 582 REBUILT
Rockford, IL
On Thu, May 13, 2010 at 6:40 PM, steve eccles <eccles(at)chartermi.net (eccles(at)chartermi.net)> wrote:
[quote]--> Kitfox-List message posted by: "steve eccles" <eccles(at)chartermi.net (eccles(at)chartermi.net)>
jdmcbean(at)kitfoxaircraf Guest
Posted: Fri May 14, 2010 9:14 am Post subject: kitfox landing gear |
The axles, wheels and brakes can be the same.. However, we also offer the larger axle size if one wants to go to tires like the 26 or 29” Alaskan Bush Tires.
So basically we offer all 4 gear systems, Bungee, Grove-Aluminum, Bush Gear with ¾ axles (your existing ones or new) and 1.25” axles for those already using a different wheel and brake system or wanting to go to the Much larger tires.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Friday, May 14, 2010 5:54 AM
Subject: Re: kitfox landing gear
Dick Maddux
Fox 4
Milton,Fl
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
eric hendriks
Posted: Sat May 15, 2010 11:39 am Post subject: Re: kitfox landing gear |
Thank you all
Are there drawings or plans available so that I can make them myself
we here in Europe have to buy all that parts in the USA and that costs a lot of shipping.
eric
Av8r3400
Posted: Sat May 15, 2010 7:19 pm Post subject: Re: kitfox landing gear |
I doubt that any of these manufacturers will want to part with all the engineering time and expense that selling plans would entail.
Look at the Aerotrek / EuroFox as an example why...
Av8r3400
YouTube Videos |
eric hendriks
Posted: Sun Jun 20, 2010 6:05 am Post subject: Re: kitfox landing gear |
If Lowell fitt is reading this
I would answer Your E-mail to me but I won't get access
I would be very pleased if You would mail me the pictures.
thank You
eric hendriks
Posted: Wed Jun 23, 2010 1:54 pm Post subject: Re: kitfox landing gear |
Hello Lowell
I would be very pleased with some pictures from how You connect the cross tube under the fuselage to the landing gear connectionpoints and how You connect the suspension to the landing gear.
How thick are the templates You used.
I don't want to make the gear wider,I only want to make it possible to disconnect the suspension so that I can lay the plane flat on his belly to make it lower on the trailer.
(ps I don't have access to Your mail address)
Eric
