armywrights(at)adelphia.n Guest
Posted: Sat Apr 22, 2006 1:21 pm Post subject: antenna |
On Comant's spec sheets for DME/Transponder antennae, what is the
significance of "Power RF?"
Rob
nuckollsr(at)cox.net Guest
Posted: Sat Apr 22, 2006 3:22 pm Post subject: antenna |
At 04:08 PM 4/22/2006 -0500, you wrote:
Quote: |
<armywrights(at)adelphia.net>
For antennas, it's the maxiumum rated po
< with experiment. >
< --Lawrence M. Krauss >
endspeed(at)yahoo.com Guest
Posted: Sun Apr 23, 2006 6:33 am Post subject: antenna |
--- "Robert G. Wright" <armywrights(at)adelphia.net>
Posted: Sun Apr 23, 2006 9:23 am Post subject: antenna |
Rob
Hmmm . . . seems my reply was truncated. For antennas, there's
a design limit for the maximum power you can expect it to
handle. For example, a simple DME/Transponder antenna for
mounting to the bottom of an airplane could be severely
taxed at say 10,000 watts. It could be a current issue
where some part of the antenna might be overheating and
be damaged (not a problem with DME/Transponder antennas
because while PEAK power is perhaps 100-200 watts, the average
power is measured in milliwatts. If it's a voltage issue
(gaps in construction or capacitors arc over) then peak
power is a significant concern irrespective of
average power.
In any case, a DME/Transponder antenna you purchase for
use on an aircraft isn't going to be at-risk for damage
by any radio installed for that purpose at the power levels
commonly supplied. A 50-ohm antenna accepting 250 watts
of power sees peak currents on the order of 2.5 amps
and peak voltages on the order of 110 volts. Generally
not a big thing in the aviation antenna world.
The same company may well make antennas rated in the
killowatts where such things are a design challenge.
They may have a data sheet format that says
"tho shalt put a power rating on thy product"
so even the lowly DME/Transponder antenna gets a power
rating.
This gives rise to the neophyte's dilemma, "Gee, there's
a power rating stated for this product I might want to
buy for my airplane . . . how and why would I consider
this as significant for my buy-decision?" The answer
in this case is, "No big deal."
brian
![](images/avatars/28567319943bd489733e72.jpg)
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun Apr 23, 2006 11:08 am Post subject: antenna |
Transmitting antennas are usually rated for how much transmitter output
power they can handle. Remember that transponders and DMEs have
transmitters and transmit with peak power levels on the order of 200-300
watts. They transmit in short bursts so that the average power is low
but still, the peak voltages and currents are those of the 300W level.
This can cause arcing internally to the antenna if it isn't rated for
this power level.
But if the antenna says it is for a DME or transponder, you are pretty
safe using it for that function.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
Posted: Sun Apr 23, 2006 12:35 pm Post subject: antenna |
Bob, you're so quick on replies, you even beat me to labeling myself the
neophyte that I am! I'm just trying to wrap myself around all the info out
there on airframe and panel wiring that Revision 11 just can't hold. I'm
weighing the desire to do all my own wiring (time and learning) against
farming the panel out to $omeone el$e just to have it correct. Too bad
there're no avionics seminars around my area for the next foreseeable
future....
Rob
Rob
average power.
rating.
simon.miles(at)skynet.be Guest
Posted: Sun Apr 23, 2006 12:37 pm Post subject: antenna |
I'm intrigued. Why does a transponder or DME draw such high power? My
radio only draws about 5 watts and that seems to work perfectly well -
or is the peak draw actually much higher?
Simon Miles.
this power level.
brian
Posted: Sun Apr 23, 2006 1:39 pm Post subject: antenna |
It doesn't draw high power. It is just that it transmits very short
bursts of high power so while the peak power is high, the average power
(which is what your power bus has to deliver to the radio) is very low.
Think of it this way. It might transmit with 100W for 1/100th of a
second every second. The peak power is 100W but the average power is 1W.
The durations and rates are different than that in real life but it
gives you the idea how it works.
Posted: Sun Apr 23, 2006 2:28 pm Post subject: antenna |
future....
We are ALL neophytes at many things. I presume your presence
here on the List is search out useful things to apply to your
decision making and/or to enhance your abilities to take on
new tasks. It's my pleasure and that of many others to share
what we've learned toward your goals.
Posted: Sun Apr 23, 2006 2:53 pm Post subject: antenna |
At 08:08 PM 4/23/2006 -0700, you wrote:
Quote: |
simon miles wrote:
<simon.miles(at)skynet.be>
Brian nails it. Consider that power is a rate thing and does not
consider duration. For example, cruising down the road may require
40-50 horsepower from your engine . . . but how does that translate
to energy? To speak of energy, you must consider duration. Driving
500 miles might take ten hours . . . so while the power was 50 h.p.,
the energy was 500 horsepower-hours.
You can have a 100 watt lightbulb on the ceiling that you
turn on for one second out of each hour. Peak power is 100
watts, energy is 100/3600 watt-hours or 1/36th of a watt-hour.
Your transponder puts out a stream of 0.45 microsecond wide
pulses at 100W, or what ever the "power rating" of your transponder
is.
See http://www.airsport-corp.com/modec.htm
The strings happen over a span of 21 uS and repeats several times
each time the REPLY light on your transponder lights up. One might
say that the AVERAGE power for a reply of all "1" in the bit stream
approaches 50 watts . . . but this is still very periodic and even when
your're being painted by several radar sites, the average power over
say 10 seconds is less than 1 watt which accounts for about 100 millampers
of the input power to your transponder . . . the rest being lost
in running associated circuitry and losses in the transmitter's high
power output stage.
Tying this back to the antenna power rating question, knowing that
peak power is as much as 200W, the designer might have some voltage
issues to
consider but from an average power handling perspective, current
stresses to the antenna are trivial.
