AirMike
Posted: Sat Jun 19, 2010 6:03 am Post subject: TruTrak Display issue - panel planning |
My digiflight II -VS has an LCD screen that has gone wierd. The nice people at TruTrak are replacing it under warranty and are aware of the problem - apparently a manufacturers defect. They have new debugged and better displays that they are installing. The defect does not affect the operation of the unit (which I love), but it is obvious that the display will not get better so I am returning it to them for repair.
My point in making this post is that I positioned my D-II-VS in the left hand corner of my panel which made it relatively easy to replace. If it were on top of the stack or above the EFIS I might have had to pull the whole panel to get at it. Keep in mind that it also has pitot and static connections on it.
_________________ See you OSH '18
Q/B - sold. |
