lcfitt(at)sbcglobal.net Guest
Posted: Fri Jun 18, 2010 5:53 am Post subject: Engine Mount |
Guy,
I thought an update on the engine mount. It is installed and bolts
tightened. I was surprised that while fitting the cowl, the oil tank needed
a bit of surgery. I was thinking of cutting a corner off the bottom and
having a welder weld it up again. I noticed a small dent on the bottom
corner and it gave me the idea that I might be able to do a little body and
fender work on it to get it to fit. I did exactly that and used some micro
and epoxy to smooth it out and then painted the bottom bowl my finish color
to hide the fix.
I am making the donuts, but I had two miscasts so only have four to date. I
think I still have enough of the rubber for the remaining four. I used the
light weight engine stand from Harbor Freight. I made a jig that mated to
it and if you would like it, I can send it down. It allows for two axis
alignment - pitch and bank. I did weld the rotating tube in the stand for
stability. I also found some cone shaped things that I used to locate the
donut rings while welding. You can have those as well. They won't burn up
with the welding.
Photos attached.
Lowell
139.57 KB |
6424 Time(s) |
140.55 KB |
6424 Time(s) |
116.63 KB |
6424 Time(s) |
144.57 KB |
6424 Time(s) |
Posted: Fri Jun 18, 2010 11:58 am Post subject: Engine Mount |
Sorry, this was to go direct.
Lynn Matteson
Posted: Fri Jun 18, 2010 1:54 pm Post subject: Engine Mount |
Not again, Lowell ? : )
Lynn Matteson
Jabiru 2200, #2062, 976 hrs (since 3-27-2006)
Countdown to 1000 hrs~24 to go(36 days to go)
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: out of service
On Jun 18, 2010, at 2:57 PM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Fri Jun 18, 2010 1:59 pm Post subject: Engine Mount |
Most of us have done it, Lowell...more than once. It was interesting
though.
Deke
