KingCJ6(at)aol.com Guest
Posted: Wed Jun 16, 2010 7:38 pm Post subject: Housi pickling procedure |
We are acquiring a backup Housi 285 that will be put in storage for some time. The engine is currently on an operating a/c , so it can be run prior to preserving. Looking for “best practices” recommendations for the proper pickling method, as it will be stored horizontally on the shipping pallet.
Thanks, Dave
Posted: Fri Jun 18, 2010 12:21 pm Post subject: Housi pickling procedure |
Dave,Moisture is the biggest problems with stored engines, rust in the cylinders, etc. Coating the cyl walls with oil is a must, rather this is done spray or flooding it should be done if the engine is to be stored for a extended period of time. Desiccant plugs in the spark plug holes is also a good idea. They are available from Spruce, but like any desiccant tool it is useless if not monitored on a regular basis. Exhaust port plugs should be installed if you have them. Check in your Tech Spec manual, I think I recall some storage guidelines there.
Good luck,
Doug
On Wed, Jun 16, 2010 at 8:32 PM, <KingCJ6(at)aol.com (KingCJ6(at)aol.com)> wrote:
Thanks, Dave
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
