Center Tunnel
Albert Gardner
PostPosted: Mon Jun 14, 2010 6:35 am    Post subject: Center Tunnel Reply with quote
After reading about the explosion/fire in the RV-10 possibly due to a fuel leak in the tunnel I took a look at mine just to check since it has been awhile since the annual inspection. No leaks but I still don't like the spillage associated with opening the filter for inspection/cleaning. One thing I changed was the routing of the brake lines. Page 36-3 routes the lines almost against the floor making cleanup difficult. I changed the orientation of the cushion clamps so that the brake line is held up off the floor and cleanup is much easier.
Now I'm looking at the idea of accessing the filter through the bottom of the tunnel so that no fuel is spilled inside cleaning the filter. Also, getting in the tunnel from the top is difficult as the rudder cables must be disconnected, seats removed, and carpet removed to get access to the tunnel cover.
I'm thinking of installing a cup holder in the tunnel cover so that I could easily inspect the interior by pulling out the cup holder and shinning a flashlight in there without removing anything else.
Albert Gardner
N991RV
Yume, AZ
RV-9A N872RV
RV-10 N991RV
pitts_pilot(at)bellsouth.
PostPosted: Mon Jun 14, 2010 6:49 am    Post subject: Center Tunnel Reply with quote
You could remove the tunnel filter and put it under the front seat, and buy a second one for the other side. Far more room to swing a wrench and get your hands on the filter. Before I put the wings on, I'll seal the fuel lines at the root and draw a vacuum on the system to the firewall ..... Don't want any slow leaks.
Linn
do not archive.
Albert Gardner wrote: [quote] <![endif]--> <![endif]-->
Albert Gardner
N991RV
Yume, AZ
Phil.Perry(at)netapp.com
PostPosted: Mon Jun 14, 2010 6:53 am    Post subject: Center Tunnel Reply with quote
I did the same thing on mine, but I’m not 100% committed to it yet. I might turn them back correctly.
My bigger concern were the brake lines rubbing on the shop-head-side of the rivets that are directly below the lines. With the cushion clamps held in their “correct” position, the brake lines aren’t more than 1/32 - 1/16” off those shop heads and I didn’t want the rivets working my brake lines. (BTW – I’m using Bonaco lines all the way through the tunnel.)
I’d like the clamps to be oriented correctly, but I don’t like the possibility of the rivets working on those lines. I’ve been trying to come up with a rub-barrier that I can insert between the rivets and the lines, but I haven’t come up with anything yet. So I might end up flipping the clamps over too, but with flex lines, I’d really need to be careful that they don’t eventually rotate down a few degrees pushing the flex lines back down on the rivets (again). J
There has to be a barrier we could put in there to keep the lines off the rivet tails.
Phil
From: Albert Gardner [mailto:ibspud(at)roadrunner.com]
Sent: Monday, June 14, 2010 9:32 AM
Subject: Center Tunnel
Albert Gardner
N991RV
Yume, AZ
Kellym
PostPosted: Mon Jun 14, 2010 7:24 am    Post subject: Center Tunnel Reply with quote
Side access panel makes it easier. Bob Leffler has a picture of it on
his site. I'm not finding the web link for ordering the kit right now.
Seems like Air Ward was the vendor, but paperwork is at the hangar.
Albert Gardner
N991RV
Yume, AZ
Kelly McMullen
KCHD
Albert Gardner
PostPosted: Mon Jun 14, 2010 7:38 am    Post subject: Center Tunnel Reply with quote
I had the same concern about the close proximity of the rivets and the brake line so I slid rubber tubing over the lines in the area between the cushion clamps. I
suppose that also made it a little harder to clean up under the brake lines though.
Albert Gardner
N991RV
Yuma, AZ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Monday, June 14, 2010 7:53 AM
Subject: RE: Center Tunnel
Phil
RV-9A N872RV
RV-10 N991RV
jesse(at)saintaviation.co
This is a great way to do it, but don't forget that you will need to drain your fuel tanks before cleaning the filters.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jun 14, 2010, at 10:42 AM, Linn Walters wrote:
[quote] You could remove the tunnel filter and put it under the front seat, and buy a second one for the other side. Far more room to swing a wrench and get your hands on the filter. Before I put the wings on, I'll seal the fuel lines at the root and draw a vacuum on the system to the firewall ..... Don't want any slow leaks.
Linn
do not archive.
Albert Gardner
N991RV
Yume, AZ
AV8ORJWC
PostPosted: Mon Jun 14, 2010 9:44 am    Post subject: Center Tunnel Reply with quote
A great rule of thumb is a minimum of 0.125" from any surface (we often try for 0.375") which could otherwise chafe lines during the airframe's life. During the Conditional, it's the guy inspecting that must (should) look for new chafes, dents and damage before the hydro-carbons find a new path to freedom. The Adels help the inspector get under there with an inspection mirror.  Dan Checkoway had excellent examples of where even the best of his plans and well intentioned construction could overlook those contact points.  Adel clamps - MS21919DWG are a solid means to build in such protection. They can be a bitch but those Aircraft Spruce Pliers seem nifty. There are aluminum spacers (in various heights) that allow for stacking of Adels or for staggering. Always try to route wiring above and 6" away from hydro-carbon lines. Paul Grimstad had some nifty foam adhesive pads that electricians use that could help.
Although the AC 43.13 is boring, it can serve as a good clarifying reference.
I won't speak for VANs but I doubt they would say "Forgetaboutit... just build it". Oh, that's right. KS has said that before.
John Cox
Sent: Mon 6/14/2010 7:53 AM
Phil
Albert Gardner
N991RV
Yume, AZ
Kelly McMullen
PostPosted: Mon Jun 14, 2010 11:09 am    Post subject: Center Tunnel Reply with quote
To follow up: http://www.airward.com or http://tinyurl.com/2eetgbe for
the exact page.
On Mon, Jun 14, 2010 at 8:21 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Side access panel makes it easier.  Bob Leffler has a picture of it on his
site. I'm not finding the web link for ordering the kit right now. Seems
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Deems Davis
PostPosted: Mon Jun 14, 2010 2:51 pm    Post subject: Center Tunnel Reply with quote
FWIW
I fabricated and installed the side tunnel access door for servicing the fuel pump/filter. http://deemsrv10.com/album/Sec%20The%20Home%20Stretch/slides/DSC05413.html I don't think I'd do it again if I had to. The reason, is that there's so much stuff in the tunnel that you want to check and inspect during the condition inspection, that really requires you to take the tunnel cover off. I haven't had the need/opportunity to get inside for anything else, and it was a fair amount of work to fabricate and install. In my case it requires removing the center console that sits on top of the tunnel, and I still think its better to remove the tunnel cover. I DID split the forward tunnel cover into 2 pieces, http://deemsrv10.com/album/Control%20Approach%20Rudder-Brake%20Pedals/slides/DSC06591.html and I WOULD definitely do that again.
I removed and cleaned my fuel filter during the last ACI and with the andair fuel selector turned OFF and some paper towels placed under the fittings. I didn't have any leakage into the bottom of the tunnel. YMMV
Deems Davis
N519PJ
www.deemsrv10.com
On 6/14/2010 12:08 PM, Kelly McMullen wrote: [quote]
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> (apilot2(at)gmail.com)
the exact page.
On Mon, Jun 14, 2010 at 8:21 AM, Kelly McMullen <kellym(at)aviating.com> (kellym(at)aviating.com) wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com> (kellym(at)aviating.com)
rnewman(at)tcwtech.com
PostPosted: Mon Jun 14, 2010 5:47 pm    Post subject: Center Tunnel Reply with quote
Although not flying yet, here's my tunnel access that I made. I changed from carburated to fuel injected so I had to change my fuel pump. I went to the andair pump and decided to move the filtering out to each wing root via an andair gascolator. So I have no filter to be changed in the tunnel, my access panel is intended for inspection purposes and possible pump servicing if necessary. Like Deems I have a center console that I really don't want to have to remove to get to the tunnel, so I'm hoping to carry out inspections via this panel, perhaps with the aid of borescope type video camera.
Bob Newman,
www.tcwtech.com
40176.
http://picasaweb.google.com/rcnewman64/FuelPumpAndAccessDoor#
Strasnuts
PostPosted: Mon Jun 14, 2010 8:59 pm    Post subject: Re: Center Tunnel Reply with quote
Here is my AndAir install.
 Filesize:  134.85 KB
 Viewed:  7124 Time(s)
 Filesize:  110.52 KB
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Strasnuts
 Filesize:  134.85 KB
 Viewed:  7123 Time(s)
 Filesize:  110.52 KB
780 Hours
SuperSTOL 60 hours
