Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27801 Location: Toledo Washington (KTDO) USA
Posted: Tue Jun 08, 2010 8:00 pm Post subject: Replacing Fuel Level Senders... |
Dear Listers,
Well, okay, so I've resigned myself to replacing my Princeton capacitance fuel level probes with the standard S&W float probea from Van's. Has anyone replaced these without removing the wing or the fuel tank from the airplane? Basically just doing it from underneath the airplane through the gap afforded by the fuselage-to-wing fairing? Is this even possible?
I know that it won't be possible to remove the Princeton units without destroying them, but can the S&W probes be installed? If I can do it without pulling the fuel tanks or wings off, then I might just tackle this sooner than later. But if the tanks have to come off, then I might procrastinate more and enjoy the great flying weather. That being said, I'm going in for paint in either August or October and it has to be complete before then either way.
Arg, why couldn't those Princeton probes just work? Geeze, how much do you have to spend to get a product that works. How frustrating.
So, how accurate are the bending dimensions on the Van's plans for the S&W float arms? I've got no way to test or trial fit these units so its a one-shot deal. I've already pulled the probes out once, I definitely don't want to do this again!
Thanks for the insight...
RV-8 #82880 N998RV
Status: Enjoying The Fruits of 2500 Hours of Labor!
_________________ Matt Dralle
Posted: Wed Jun 09, 2010 3:49 am Post subject: Replacing Fuel Level Senders... |
I removed my tanks on my RV-4 to make some modifications. I don't
remember it being a big deal at all. I think it took less than 20
minutes per side with a drill motor. I think you'd have a much easier
time in removing the tanks and doing it that way.
Just one builders opinion....
-Mike
On Jun 9, 2010, at 12:00 AM, Matt Dralle <dralle(at)matronics.com> wrote:
Dear Listers,
RV-8 #82880 N998RV
ualpilot3(at)aol.com Guest
Posted: Wed Jun 09, 2010 6:03 am Post subject: Replacing Fuel Level Senders... |
Matt,
I just pulled the fuel senders off a RV-8A to replace the gasket. It
is no problem doing it through the tank-fuselage space. Call me if you
have any questions. 210-887-4546
Les Bourne
ghinman(at)mts.net Guest
Posted: Wed Jun 09, 2010 7:13 am Post subject: Replacing Fuel Level Senders... |
Dear Listers,
again!
RV-8 #82880 N998RV
Matt
I managed to remove and re-install my fuel senders
without removing the wing.
So you should be able to install them.
The bending instructions are fairly accurate,but you will have
to snap out and reverse the float on one side ,or it will hit
an angle on bottom of the tank.
George H. Inman
ghinman(at)mts.net
Posted: Wed Jun 09, 2010 7:51 am Post subject: Replacing Fuel Level Senders... |
Dear Listers,
capacitance fuel
replaced
Basically
destroying
later.
enjoy
either August
you have
S&W float
one-shot deal.
again!
RV-8 #82880 N998RV
Matt
George H. Inman
ghinman(at)mts.net
geezer02(at)windstream.ne Guest
Posted: Wed Jun 09, 2010 3:44 pm Post subject: Replacing Fuel Level Senders... |
You can install the Van fuel floats without removing the wing. I don't know about removing the present probes. It will be eaiser if you didn't use pro seal or some other material on the gaskets.
Louis Dunn
RV8 some day
---- George Inman 204 287 8334 <ghinman(at)mts.net> wrote:
Dear Listers,
capacitance fuel
replaced
Basically
destroying
later.
enjoy
either August
you have
S&W float
one-shot deal.
again!
RV-8 #82880 N998RV
Matt
George H. Inman
ghinman(at)mts.net
