Cooling issues, once again!
Goto page 1, 2, 3  Next
frans(at)privatepilots.nl
PostPosted: Sat Jun 05, 2010 2:36 am    Post subject: Cooling issues, once again! Reply with quote
Gentlemen,
Although my initial cooling issues have been improved upon, I'm not
satisfied at all with the cooling of my 914.
Now, with increasing ambient temperatures, I have to severely limit my
climb outs. Cruising is ok. During climb, both the water temperature and
oil temperature approach the red line, more or less at the same time.
Water temperature recovers faster than the oil temperature after I power
down. At this time I can barely make it to circuit height and then have
to level off, build more speed, and then limit my climb with 200 ft/min
until I'm in cooler air. The engine has now 32 hours on it, so it might
still improve somewhat further, but I don't expect miracles from that.
I had to do something.
First I made an additional exit in the cowling, under the turbo, hoping
to provide more airflow. Whether the airflow in the cowling improved I
don't know, but it had zero effect on the water and oil temperatures.
Temperatures inside the cowling seem to be ok anyway, no discoloured
spark plug indicator labels (still bright yellow), no melted tie-wraps, etc.
My conclusion was that the problem is not in cooling of the cowling, but
somewhere in the efficiency of the radiators.
So then I built a new radiator inlet, somewhat larger than previous one,
with a lip to avoid digesting the boundary layer and making sure the
inlet receives ram air, angled straight into the airflow, and with a
diffuser for which I copied a profile out of a famous book.
It was no improvement over my "free style" sleeker inlet and diffuser.
None. Very frustrating, as I ruined my nicely shaped and painted
original inlet for this.
I need to do something, but to avoid ruining again something in order to
solve this problem, I need to hear some experiences:
1) A shroud over the cylinders. I don't have it, but instead I have two
naca ducts in the upper cowling, curved down to release air aimed at the
cylinders.
Has anyone ever tried whether the Rotax shroud (or home made shroud)
makes any difference? Sure, it will cool the cylinders, but does it have
any effect over the water temperature and/or oil temperature? Or is this
again going to be a loss in time and effort?
2) In my setup the oil cooler receives exit air from the water cooler. I
know there is a "trick" mentioned in the build manual for hot climates
to lower the oil radiator 2 inches to receive cold air instead of warm
air, but I didn't opt for this as I don't consider our climate as
extremely warm, and in winter the oild could actually get too cold.
Has anyone tried both options, and did it make much difference? Also,
did it have any influence over the water temperature? Relocating the oil
radiator will be a large project, and I fear that after that I will
still have to limit my climb outs to avoid the water from boiling.
Yesterday on the airfield I took a closer look at the Rotax 914 equipped
Dimona, which is used by the glider club to tow all day long gliders,
with full power at 50 knots, in all ambient temperatures. They never
have cooling problems.
What I saw was shocking. The water radiator is fully exposed to the
airstream, no diffuser whatsoever, it is just part of the cowling, as if
someone took out some skin of the cowling and fitted the radiator in the
resulting hole. The oil radiator is mounted in an angle behind a naca
duct (I was taught that a naca duct does not provide ram air and
shouldn't be used for cooling a radiator?). Both radiators just dump the
warm air inside the cowling! It can't be easier than that.
Then, at the bottom, the Dimona has a cowl flap which just opens the
cowling to dump *all* air overboard. If it is closed, all radiators, as
well as all cowling ventilation, is blocked.
How can this system, which looks less sophisticated than our system,
while violating all rules and knowledge, work so well?
Anyway. At the moment I'm grounded, can't fly like this, and after
spending a week trying to improve things with zero effect, I'm out of
options and I'm inclined to leave the airplane in the hangar and find
another hobby. Sad
Seriously, what should I do?
Frans
lgds(at)post6.tele.dk
PostPosted: Sat Jun 05, 2010 3:26 am    Post subject: Cooling issues, once again! Reply with quote
Be 100% sure that no air are bleeding out through gaps around your air baffles! Just a little gab is enough to spoil your day. Regards Gert
OY-GDS / mono / 914 / 500 hours
Den 05/06/2010 kl. 12.28 skrev Frans Veldman:
[quote]--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
Gentlemen,
cylinders.
another hobby. Sad
Seriously, what should I - The Europa-List --> http://www.matroni &n -   &nbs --> http://www.matronics.com/co=================
PostPosted: Sat Jun 05, 2010 4:51 am    Post subject: Cooling issues, once again! Reply with quote
baffles!
I replaced the entire Europa duct, but it mates with the cowling at some
point of course. I didn't have the impression that it was very leaky,
but at the moment I'm waiting for PUR-foam to cure (one side taped off
of course) to see if there was indeed a leak. I'm hoping there was a
leak, and I saw some bugs piled up in one corner just before the
radiator, so that is a hopefull sign. Smile
Frans
kevann(at)gotsky.com
PostPosted: Sat Jun 05, 2010 5:30 am    Post subject: Cooling issues, once again! Reply with quote
I have the stock Europa cooling duct with the oil cooler lowered to the bottom of the cowling. As Gert suggests below, all gaps are sealed well, including the bottom of the oil cooler to the cowling and the sides of both coolers to the aluminum duct.
I flew last week to Death Valley with a friend in the right seat. When we departed furnace creek(L06) the OAT was about 90 F. The climb from 200' below sea level to 11,000' at 90 to 100 knots indicated showed oil temps up to 240 F and the Evans coolant 230. CHT is always within 10 deg. of the coolant.
I have been climbing most of the time at airspeeds around 100 knots and 100% (34"map) which yeilds a healthy climb rate. The temps inside the cowl have gotten high enough to deform the spark plug indicator labels. I wraped the exhaust pipes, but I'm not sure if that helped really because I don't have the cowl temps monitored.
The OAT should exceed 100F today. Whew!
Best of luck, Kevin
Mono intercooled 914 Airmaster prop
PostPosted: Sat Jun 05, 2010 6:09 am    Post subject: Cooling issues, once again! Reply with quote
Amazing!
Do you have the Rotax shroud fitted over the cylinders?
Has your engine had initial (< 50 hours) cooling issues?
Has your oil cooler been lowered from the beginning, or did you relocate
it later? If so, did it make some difference to the CHT's as well?
Frans
rlborger(at)mac.com
PostPosted: Sat Jun 05, 2010 6:58 am    Post subject: Cooling issues, once again! Reply with quote
Frans,
I flew last summer in temperatures in the high 90's to low 100's (35C-41C) with no signs of overheating.
I have the stock FWF 914 setup with the following changes:
1. The lowered oil cooler.
2. I have sealed the sides of the radiators to the aluminum duct with silicone rubber seal
3. I have sealed the bottom of the oil cooler to the cowl with a foam strip
4. I replaced all the factory supplied tape for the front of the duct with wide silicone rubber seal
5. I smoothed the inside lower lip of the cowl intake with blue foam and 2 lays of glass to reduce turbulence and smooth flow
I do not have the Rotax shroud over the cylinders but will consider it should cooling be inadequate this summer.
I hope this helps,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jun 5, 2010, at 5:28, Frans Veldman wrote:
Gentlemen,
Frans
PostPosted: Sat Jun 05, 2010 7:53 am    Post subject: Cooling issues, once again! Reply with quote
Ok, it seems the common solution here is to lower the oil cooler. As I
have fabricated my own duct, this is not possible in my setup. This
means I will probably have to relocate the oil cooler and give it a
dedicated inlet.
One question: if you lower the oil cooler, how are the two coolers
sealed against each other? Can air flow freely around the water cooler
to reach the oil cooler? This means that the air in front of the water
cooler will see an easier path and just forget about the water cooler?
Is there anyone with adequate cooling on warmer days with both radiators
behind each other, as the manual calls for? Or is this plainly
impossible to achieve?
Frans
paul.the.aviator(at)gmail
PostPosted: Sat Jun 05, 2010 8:44 am    Post subject: Cooling issues, once again! Reply with quote
Hi All,
I am curious to know if there are any examples of standard XS cooling set up's that do not have the oil radiator lowered that work fine.
Thanks,  Paul
rampil
PostPosted: Sat Jun 05, 2010 9:46 am    Post subject: Re: Cooling issues, once again! Reply with quote
while violating all rules and knowledge, work so well?<<<<<
The problem is basically, when it come to the Europa, what we think
we know is actually only supposition and rules of thumb.
The Diamond setup was actually engineered, money spent, measurements
made, and the design refined to pass muster. I have been listening
intently to cowl discussions here and elsewhere, and the best we
have is a bit of trial and error, some demonstrably good suggestions,
some not so worthy.
Let me pass on a bit of advice from Eric Tucker who suggested to me,
that before I tear into a cowl, I take a spare airspeed indicator and
run the pitot hose into the engine space. While flying, make
measurements at several locations to see where the actual high and
low pressure points are, and then basing a redesign on real data to
get the air moving in the right direction!
Another two good sources of solid information rather than heresay are:
Kent Paser's book Speed with Economy (available at MustangAero)
and the old NACA archives.
Ira N224XS
Jeff(at)rmmm.net
PostPosted: Sat Jun 05, 2010 9:52 am    Post subject: Cooling issues, once again! Reply with quote
Frans,
I have the 912 set up so I might not know what I'l talking about but...
I had the very same issues for the first 150 hours. Every time it got
hot I was in trouble with temps at their limit. I made the shroud for
over the cylinders. I lowered the oil radiator 2 inches behind the
water, I sealed everything, I made new inlets in the upper cowl, and
still didn't get it solved completely. I then finally lowered the
metal duct down an inch or so, so the bottom radiator reached the
lower cowl without the sealant and bam. My temps dropped 30 to 40
degrees. I believe two things helped in this. The radiators we're
getting more air but the big thing was by lowering the duct it opened
the bottom for escaping air. Not sure if this all applies to you but
if you have the duct up to high close to the muff all you need to do
is lower it. You'l be needing to ad a flap in colder days to get
things in the proper temp range.
By the way the shroud did even the cylinder temps out but it didn't do
much to cool the water or oil.
Jeff R. N128LJ Gold Rush
On Jun 5, 2010, at 5:28 AM, Frans Veldman wrote:
Gentlemen,
and
power
have
min
might
hoping
wraps, etc.
but
one,
order to
two
the
cylinders.
have
this
cooler. I
oil
equipped
as if
the
the
as
another hobby. Sad
Frans
g-iani(at)ntlworld.com
PostPosted: Sat Jun 05, 2010 10:00 am    Post subject: Cooling issues, once again! Reply with quote
Frans and all
My aircraft (G-IANI)is a 914 with no shroud and the standard cowl. The aircraft ran hot on UK “hot” days until I lowered the oil cooler. We also had the same with G-IRON.
Lowering the Oil radiator as far as possible and ensuring complete sealing all round fixed the problem. They both run cool in winter (oil temp 70 – 80c rather than the desirable 100c and this is the reason for the thermostat mod.
I have used a rubber strip attached to the top of the oil rad to seal the gap between it and the water rad. This stops the air taking the short cut. You can just see this seal (black rubber) in the attached picture.
I have more pictures and details if you want them.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
 Filesize:  105.13 KB
 Viewed:  18741 Time(s)
acrojim(at)cfl.rr.com
PostPosted: Sat Jun 05, 2010 10:02 am    Post subject: Cooling issues, once again! Reply with quote
Frans,I would suggest that you take a look at the bottom of the cowl, where all of the air escapes from inside the cowl..No cooling will take place unless the air inside the cowl can get out. You said you replaced the entire duct work...You may have restricted the exit area in some form or other. If you see anything that will restrict the flow of air to the outside, can it be moved? Can it be reduced in size? It is critical thatthe exit area does not restrict the flow of the exit air...
Jim Brown
Europa XS 914
> baffles!
Frans
rlborger(at)mac.com
Paul,
I don't see how it can. Simple thermodynamics is against it. Heat transfer is directly proportional to temperature difference. Both radiators are at about the same temperature. Once the air has been heated by the first radiator its ability to accept heat from the second has been greatly reduced if not eliminated.
And this is assuming that the area below the radiators has been sealed so that the air goes through the radiators and not under them, doing no good at all.
Check six,
Bob Borger
http://www.europaowners.org/N914XL
Europa XS, Short Wing, Intercooled Rotax 914
rlborger(at)mac.com (rlborger(at)mac.com)
Cel: 817-992-1117
On Jun 5, 2010, at 11:43 AM, Paul McAllister wrote:
Hi All,
Thanks, Paul
mikenjulie.parkin(at)btin
PostPosted: Sat Jun 05, 2010 10:39 am    Post subject: Cooling issues, once again! Reply with quote
Frans,
I have a standard XS 914 installation. In the early days I had a problem
with cooling until I lowered the oil cooler in accordance with the build
manual. Once the cooler was lowered I had no problems whatsoever until I
filled the system with Evans. That pushed the temperatures close to the
limit, so I threw the Evans away. Since then I have had no issues. True,
UK summer temperatures are not in the same league as our American friends...
I recall that the temperature in my yard in Phoenix, Az occasionally was
120+. However, UK temperatures are very similar to the Netherlands.
I refer to your email dated 2 Mar 2009, your theory and confidence was most
impressive. Your penultimate paragraph was quite damming. I quote.
>Of course, al this is theory. Because the cooling properties of the
>factory cowling are so bad, I believe that it would actually be
>difficult to make it worse. So chances are that my cooling at least
>gives some better cooling and aerodynamics.
Perhaps Ivan, Andy and Neville at Europa had a better clue than you give
them credit for.
If I was one of the boys, I might be tempted to send you a big piece of
'Humble Pie'.
PostPosted: Sat Jun 05, 2010 10:52 am    Post subject: Cooling issues, once again! Reply with quote
Ok, thanks everyone! The picture is much more clear to me now. It seems
that splitting up the oil and water radiator is the way to go.
About a month ago, the system was working quite ok. Amazing how little
OAT difference can spoil the setup.
When I saw the Europa radiator setup for the first time, I had some
doubts about it. But because the Europa lacks a thermostat, I figured
that the oil cooler behind the water radiator was on purpose, to prevent
the oil temps from dropping too low. The manual explicitely calls for
"hot climats" to use the "option" to lower the oil radiator. With
hindsight, I think this description is somewhat misleading.
As some have noticed, I trimmed down the cooling duct considerably,
added a diffuser, added a cowl flap, to optimize both aerodynamics and
cooling capacity. Although it seems my ship is indeed quite fast for a
tri-gear, the oil cooler is not going to work efficiently this way. Too
bad that I don't have room to lower the oil radiator, so I'm going to
have to relocate the oil cooler. I now appreciate the term "experimental
airplane". :-S
Some have mentioned that the exit area of the cowling might be a
problem. However, so far I have no indication that the exit area is the
bottleneck. In area it is bigger than the inlet, and I have no signs of
elevated cowling temperatures like discoloured spark plug labels. Also,
some experiments to open up more cowl space had zero effects on the
temperatures.
I'm glad to hear that the Rotax shroud isn't a necessary item.
Thanks everyone!
Frans
Brian Davies
PostPosted: Sat Jun 05, 2010 11:23 am    Post subject: Cooling issues, once again! Reply with quote
Yes, mine! but it is a 912S. I have always had low oil temps and have now fitted the oil thermostat so that they are not too low in winter.
Brian Davies
Kit 454, Trigear
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Paul McAllister
Sent: 05 June 2010 17:44
Subject: Re: Cooling issues, once again!
Hi All,
Thanks, Paul
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
manual.
Ok, this is in line with other experiences. Thanks for sharing this.
impressive.
I was waiting for this to pop up. Wink No problem at all, I'm still
behind it, I just feel somewhat mislead by the strong suggestion of the
manual that the oil cooler behind the water radiator is the standard
setup for normal climats, and I followed that guideline. Granted, I
should have known better.
Anyway, if I write something on this forum, it is "sharing knowledge"
and not a competitive attempt. I will as easily explain why I divert
from the manual some times, and as easily seek for help on this forum if
I experience problems. I don't really care about ego, so I find it
somewhat humorous if an attempt to receive some experiences from others
is answered by an answer like yours.
them credit for.
IF their original setup, with the non-lowered oil radiator as the
factory manual calls for, works better than my current setup. And that
remains to be seen...
At least it looks like my claim to have better aerodynamics might be
true, with a cooling system that performs, let's say, not worse than the
factory setup with the radiators in the "standard" configuration. Wink
Well, I will split up the oil and water radiator, as apparently everyone
has done, and then we can do the comparison again. Wink
'Humble Pie'.
If I was one of these boys, I would be tempted so as well, IF my work
was a masterpiece of enginering, well thought out, working in hot
climates AND cold climates, and with no excess drag, and with even
cylinder temperatures. However, it looks like the standard factory
setup, with the coolers in series, is not exactly the best solution for
everyone.
So, have some fun about me. It is not the first time people laugh about
work in progress. Finally, I might end up with an improvement over the
factory setup, in both aerodynamics and in cooling capacity. Goal 1
appears to have been achieved already. I consider solving problems as a
privilege of building the airplane yourself, and you can't have it right
the first time everyime.
Frans
RobHousman
PostPosted: Sat Jun 05, 2010 11:38 am    Post subject: Cooling issues, once again! Reply with quote
While it is true that “heat transfer is directly proportional to temperature difference” that does not tell the whole story. First, remember that the relevant temperature difference is the difference between the temperature of the fluid on the inside and the air on the outside, and even with pre-heated air the second radiator could have the same delta T as the first radiator. I’ll grant you that there is probably a difference, however.
Also relevant, and non-trivial, are the area of the heat transfer surface, the flow rate of the liquids inside the heat exchangers (radiators, in common aircraft and automotive parlance), the flow rate of the air outside these heat exchangers, the heat transfer coefficients for each of the fluids involved, the heat transfer coefficients of the materials from which the radiators are made, the effect of any scale or similar deposits on the heat transfer surfaces (both inside and outside), Reynolds numbers for the flowing fluids (a function of flow rates and fluid properties), and the physical properties the radiators and of the coolant and oil flowing within the heat exchangers.
Having said all of that, there is no doubt that “re-using” the cooling air will affect heat transfer within the radiator using pre-heated air, and this is undoubtedly why Europa recommend placing one below the other.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Robert Borger
Sent: Saturday, June 05, 2010 11:02 AM
Paul,
Check six,
Bob Borger
Cel: 817-992-1117
Hi All,
Thanks, Paul
PostPosted: Sat Jun 05, 2010 12:34 pm    Post subject: Cooling issues, once again! Reply with quote
Another reason might be that the oil cooler in the air exit path of the
water radiator is an obstacle that hinders the air flow in the water
radiator?
Looking closer to both radiators, It appears to me that the oil cooler
has closer spaced fins, thicker fluid canals, and an overall smaller
useful area.
It might be that this is the reason why lowering the oil radiator also
causes the water temperatures to drop.
Frans
grahamsingleton(at)btinte
PostPosted: Sat Jun 05, 2010 12:41 pm    Post subject: Cooling issues, once again! Reply with quote
You could be right there Frans. btw theory says that cowl inlet should be much smaller than rad area so that some pressure recovery can happen, also lips must be smooth.
Graham
Sent: Saturday, 5 June, 2010 21:27:33
useful area.
causes the water tem/Navigator?Europa-List" ="http://forums.matronics.com" target="_blank">http://forums.matronics. &nbsptronics.com/contribution" target="_blank">http://www.matronics.com/contri================
Page 1 of 3
