rparigoris
Posted: Thu Jun 03, 2010 4:38 pm Post subject: Wires going to CB question |
Reading "The Aeroelectric Connection" Chapter on Circuit Protection, stated is to not use the Circuit Breaker screws that mounts to bus to also connect inter-bus jumpers or main power feed lines. "These things should get their own 8-32 fasteners."
I have 2 question:
1) I have a mini e-bus on passenger headrest that will never see more than 15 amps. It consists of 3 P+B CBs. Can I feed this bus with ring terminal under the head of one of the CB screws that mounts to the bus?
2) I need to take off a wire from this e-bus that will immediately go to a 2 amp in line fuse to power my variometer, can I take power off e-bus through a ring terminal under the head of one of the CB screws that mounts to the bus?
This goes against what is stated in AC, but I am thinking perhaps it was stated considering there may be more amps than 10 or 1.
Bus bar is silver plated copper.
Thx.
Ron Parigoris
Posted: Thu Jun 03, 2010 7:24 pm Post subject: Wires going to CB question |
At 07:38 PM 6/3/2010, you wrote:
<rparigor(at)suffolk.lib.ny.us>
I have 2 question:
mounts to the bus?
The idea for a bus bar is to offer contiguous electrical connection
from some feeder to an array of tap-offs that feed breakers or
fuses using techniques that minimize single points of failure.
This design goal suggests that if you can stamp or otherwise
fabricate a bus from a single piece of metal, the design goal
is met. When the "bus" is two rows, then some means for inter
connection the rows must be devised. Certainly, strapping
between the rows with a similar piece of metal - each end
enjoying a SOLID connection (solder, steel fastener with
locking hardware, etc. then the design goal has been
faithfully observed.
Having said that, we can peek behind the breaker panel
on a contemporary A36 Bonanza and see this:
http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_1.jpg
http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_2.jpg
. . . here we observe specially fabricated inter-bus jumpers
crafted from some rather robust material fitted on each
end with equally robust flags that have been hard-soldered.
These particular assemblies attach with the non-locking, threaded
fasteners SHARED with the upstream side of a breaker. Hmmmm . . .
they've been doing this for decades . . . if it's good for an
A36 it's probably good for an RV7. But it DOES offer single
points of multiple failures due to loosening of non-secured
fasteners.
So here the design goals I cited above were not observed. At the
same time, out of many thousands of aircraft involved, we've
probably not heard about a situation (if any) where the
loosening of one non-locking screw affected several systems.
I don't know the 'chefs' who crafted this recipe for success
but the risks for adopting their philosophy is demonstrably low.
I cannot offer a powerful argument for observing the former
design goal over that used on the A36 except that it's not hard
to do and has a logical rationale for implementation based on
the same rationale that drove fabrication and assembly of the
terminal-strip bus discussed in an earlier posting this
evening.
It's your kitchen . . .
