slow flying MkIII's
mdnanwelch7(at)hotmail.co
PostPosted: Thu Jun 03, 2010 6:23 am    Post subject: slow flying MkIII's Reply with quote
Jason,
  Regarding your MkIII flying slower than other MkIIIs, I am sure you know it has an "attributable" cause.  By that I mean, there is a definite, definable, specific reason.....not
some nebulous unknown.
  For a comparison of one MkIII against another near identical MkIII, with virtually the same power input;
if someone else's MkIII flies faster than yours, then the only other possiblities are drag and propeller efficiency.
Your plane may have all kinds of unique differences than someone else's MkIII, and these will undoubtedly cause your plane to perform different (assuming the same power input)
  A couple of things NOT offered so far are your wing's incidences, compared to your horizontal stabilizers incidence.
  The greater the difference between your main wing's incidences and your tailfeathers incidences, the more you main wings will "plow" through the air. (meaning---serious drag!!!!)
  When I did quite a bit of MkIII incidence research last year, I found some significant disparities between some of the MkIII's wings' incidences.  Example;  one guy "reports" as much as 2.5 degrees difference between his MkIIIX and the other MkIIIXs' wings vs hor stabs.  That's a lot!!
  Obviously, if in fact he is correct about his 2.5 degree difference with the other's angles, then his plane will fly VERY different than theirs will (either faster or slower).
  BTW, when I say "drag", it can come in the form of MANY ways.  Weight differences will vary drag, wing incidences, quality of workmanship, etc.  All these things, and more, can affect drag.
  Dana was correct when he reported " to double your airspeed, it will take 8 times the power.  You can see why John H's experience makes such sense......from the power of a Rotax 582 to a Rotax 912ULS, not a lot of change in airspeed.  So, the next big question is;
How efficient is your propeller at converting that 100HP?  A "climb" prop will ALWAYS run out of pitch for higher airspeeds, compared to a "cruise prop!!  Maybe your solution is as simple as adjusting your prop's pitch to take a bigger bite at the air.  ???
  Have you used a digital level and read your airplane's angles compared to other MkIIIs, and the factory recommended settings?  (I can show you what I came up with, if you need me to.)
  There's not a lot of unexplainable reasons why your plane may not be as fast as other
MkIIIs.  (Actually, there aren't ANY unexplainable reasons)  Your answer(s) will be either
A)drag, or
B) how your propeller is adjusted to transfer it's power to the air.
  Am I forgetting anything?
  Just my thoughts......
Mike Welch
MkIII CX
PS.  I'm just back from my Alabama/Florida week-long vacation.   Sheesh!!!  Between the Kolblist and Aeroelectric---over 200 emails in a week!!!  Tough to catch up on!
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. [quote][b]
PostPosted: Thu Jun 03, 2010 7:42 am    Post subject: slow flying MkIII's Reply with quote
Mike:
How about the high thrust line pusher configuration of our Kolbs? especially the heavier models?
How does this affect Kolbs' performance?
How does this affect incidence of wing and horizontal stabilizer?
How does adjustment of flaps and ailerons affect pitch trim?
How's the best way to pitch a ground adjustable prop for optimum
climb and cruise?
PostPosted: Thu Jun 03, 2010 9:20 am    Post subject: slow flying MkIII's Reply with quote
Hi John,
I hope you're healing okay. Sorry to hear about your injuries.
It would be easier to make comments inside your response, so.......
Mike:
We're talking about one MkIII against all other MkIIIs, so a high pusher configuration isn't really in question (I would think).
A high thrust line would likely want to push the nose down, I'd guess. But still, with two Kolb MkIIIs, both with their engines in the same positions, a high thrust line most likely won't make one perform different from the other....if all other things were absolutley identical.
This would be one of those things I was referring to that would affect drag.
Of course, the adjustment of flaps and ailerons can create unneccessary
drag, making one MkIII fly slower than another.
climb and cruise?
By flight testing it. He could read it's present angle. Re-adjust it for a steeper pitch. Go try it out. Re-adjust, etc, etc. At some point, he's going to have to make a decision on the setting he liked the best. Some MkIII's may climb out like a rocket, but they give up some faster cruising speeds to do so. Possibly an in-flight adjustable pitch prop might help in this regard.
Speaking of props;
Back when I was buying my engine (GEO w/ Raven Redrive) he recommended the Ivo In-flight adjustable. Not having much experience, I went with his recommendation. Maybe it was a good idea. Maybe not. I haven't flown with it yet, so I don't know.
I have read lots of reports/opinions about other brands of props. Most people seem to recommend Warp Drive.
I have also heard that props in the "Less than 200 mph" range don't really need to be adjustable. Maybe so.
I suppose if I were shopping for a prop today, maybe I'd choose another brand. Too late, tho, I already have one. Not enough money to make the change.
John,
Were you possibly misunderstanding my response to Jason? Did you think I meant ALL MkIIIs were slow? If this is what you thought, you misunderstood me. I think MkIIIs (all models) fly just fine!!!! 75 mph to 80 mph cruise is pretty darn good in my book!!!!
I was simply making the observation that there are very few reasons why one virtually identical plane doesn't fly exactly like another.
Usually, these reasons are not too hard to figure out, either. Drag, or prop efficiency. Not too many reasons for two identical planes to not fly the same.
Hope you heal quickly!
Mike Welch
PostPosted: Thu Jun 03, 2010 10:12 am    Post subject: slow flying MkIII's Reply with quote
Mike/Folks:
When we build airplanes in our basements, we end up with a lot of different airplanes with the same model designation. Ain't no two alike. Too many variables.
MKIIIs hit a brick wall about 95 mph. At that point additional thrust is consumed by the power it requires to overcome the high thrust line. You can't change that unless you go tractor or reposotion thrust line to the center of mass. Thus, similar cruise and top speed by low to high powered engines.
Adjustment/tuning of flaps and ailerons has a dramatic affect on pitch. Nose down adverse pitch is considerable because of the high thrust line.
I wrote about a good method of pitching a ground adjustable prop for best climb and cruise recently. Wide open throttle (WOT), straight and level flight, just bump the red line for max continuous rpm. This produces optimum climb and cruise in a Kolb.
I am anxious to read your flight report of your inflight adjustable prop.
In fact, I am anxious to hear your flight reports. You will gain a much better understanding of Kolb aircraft after you actually fly one.
I understand your post.
Not all mkIII's are slow.
I was curious what your response to my questions would be.
There is a lot more to it than props and drag.
No two Kolbs are built identically.
Using my method of pitching the prop, you don't give up climb for cruise, or cruise for climb. m If you over pitch or under pitch, you will end up chasing your tail.
Interesting to note:
Using this method to pitch prop on two stroke powered Kolbs, a new two stroke out of the box with factory tuning and proper expansion chamber will fly with EGT and CHT in the green, throughout its performance band.
Us old farts that have been flying Kolbs for a while have not been sitting on our hands all these years. I was 44 years old when I built and flew my first Kolb aircraft. That 26 years and many experiments and test ago. We pretty much know what we can expect from our Kolbs.
Hi John,
Mike:
climb and cruise?
Speaking of props;
John,
Mike Welch
PostPosted: Thu Jun 03, 2010 11:23 am    Post subject: slow flying MkIII's Reply with quote
John,
.ExternalClass .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-family:Verdana;font-size:10pt;} Mike/Folks:
Yep!
Ah, but then we're not talking about Kolb MkIIIs, anymore.  No fair changing the subject.
All forms of drag.
I think Jason might benefit from this method.  It may give him that extra speed he's looking for.
Yeah, you and me both!!  Being just a builder lost it's luster long ago.
Understatement.
Good.  I hate to be misunderstood.
Obviously NOT!
Hard to be totally accurate via email.  No personal input.  Sometimes you can't get a clarification before you have to respond.
Nope, props and drag.  That's all.  All the particular things you mentioned
are to affect props and drag (when talking about two identical airplanes)
Since the subject is; ALL mKIIIs flying compared to Jason's MkIII, unless some goofball has changed his MkIII radically (Heads up, looking around), they should all fly the same, or very close to the same.  If one MkIII flies radically different, then the answer will be found in prop efficiency (which can be simply adjustment) or reducing drag.    And drag comes in the form of a million ways......workmanship, adjustments, engine fairings, incidences, parasitic drag, on and on.........drag.
Neither are women.  Men, however, are all the same.  Am I right, ladies?
Using my method of pitching the prop, you don't give up climb for cruise, or cruise for climb.  If you over pitch or under pitch, you will end up chasing your tail.  ( I think this is what Jason should check on)
I think what you are describing is "an optimum pitched prop".  I think Jason may not have his prop pitched this way.  That's what I was talking about.
Can't argue with experience....unless you're a fool.  Smile       Mike
Hi John,
Mike:
climb and cruise?
  Speaking of props;
  John,
Mike Welch
Jason Omelchuck
PostPosted: Thu Jun 03, 2010 12:02 pm    Post subject: Re: slow flying MkIII's Reply with quote
Hello John,
What I read you as saying is your engine never will see the 5800 Max RPM (max for 5 min) under normal conditions (only if you are descending). The max RPM you would ever see would be 5500 RPM and that would be at WOT in level flight.
Jason
[quote="John Hauck"]
John Bickham
PostPosted: Thu Jun 03, 2010 2:53 pm    Post subject: Re: slow flying MkIII's Reply with quote
Just to add to the little discussion on Mark IIIC speeds and their different speeds.
First thing that I wonder about is rear cage covering. Is it a reasonable assumption that the faster machines may have the fuselage covered ala Ms P'fer. Does this help reduce drag and provide cleaner are for the prop to bite on?
My personal opinion based on my experience we will never know what makes one Kolb model faster than another. To explain.... Some of you might know that I bent my Kolb headed to MV in 2004. Landed in short hayfield because of dumb pilot decision making.
Took the opportunity to make modifications that would make her a real XC machine. Increased fuel capacity from 14 gallons to 22 gallons. Made my own landing gear and put on the 8.50 x 6.0 tires. Trying to imitate success. The only other thing I did was make some new tube and fiberglass seats which ended up being lighter weight than my first attempt.
Eventually put all back together and much too my surprise, the plane flew more than 10 mph faster. Same engine, same prop/pitch setting. Mike B talked about a sweet spot at a certain rpm. Prior to the mods, my sweetspot was 4800 rpm and about 62 mph. After the rebuild, the sweetspot shifted to 5100 rpm and 75 mph. I can't keep up with dem 100 hp 912's but I'm close and don't have to use as much or as expensive premium gas.
Just one more change that has to do with the fabric covered fueslage. First build was one continuous piece. This caused fabric drumming which may have increased the vibration, drag, and dirty air to prop. Second covering after mods, I used John Williamson's method of individual pieces rolled up to next joint and start new section with overlap to next tube.
The only other possibility is that when I hit the ground hard, I knocked the plane "into" trim???? Lucky I didn't break a leg or hand or worse Twisted Evil !!!
Fly 'em. A few mph ain't nothing but about 5 minutes on a 150 mile XC leg!!!
Thanks too much,
John Bickham
Mark III-C w/ 912UL
St. Francisville, LA
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for.
PostPosted: Thu Jun 03, 2010 4:00 pm    Post subject: slow flying MkIII's Reply with quote
level flight.
Jason
Jason/Ya'll:
That is correct.
With ground adjustable prop I pitch for max continuous rpm which is 5,500
for both 912UL and 912ULS.
The 912UL and ULS can be operated continuously at WOT as long as it does not
exceed 5,500 rpm.
I am not concerned with max power for 5 minutes unless I have an in-flight
adjustable prop.
I have to settle for 95 hp instead of 100. Never know the difference.
Climb is exhilarating.
I never descend WOT, usually cruise power of 5,000, and normally do not
exceed 5,500.
slyck(at)frontiernet.net
PostPosted: Thu Jun 03, 2010 4:11 pm    Post subject: slow flying MkIII's Reply with quote
I think that aft covering makes some difference. We need some responses from fast Kolbs (MkIIIs) that manage to
do without. Personally, considering the kind of flying I do, a change would be a waste of effort.
BB, lots of pipes in the breeze.
The only other possibility is that when I hit the ground hard, I knocked the plane "into" trim???? Lucky I didn't break a leg or hand or worse [Twisted Evil] !!!
Thanks too much,
John Bickham
Mark III-C w/ 912UL
http://forums.matronics.com/viewtopic.php?p=299936#299936
Thom Riddle
PostPosted: Fri Jun 04, 2010 2:58 am    Post subject: Re: slow flying MkIII's Reply with quote
Speaking high thrust lines, wing incidence and HS incidence, I am wondering if the numbers on my SS are "correct". I will call Kolb and ask but thought maybe someone on the list might know what the design calls for on the SS. Attached is a drawing I borrowed from Jack Hart and edited the numbers to match my SS.
It seems to me that the difference between my wing incidence and HS incidence (7 degrees) is greater than it should be, but this is just a guess. It also seems to me that my thrust line angle is way too high (3.5 degrees pointed up relative to wing bottom, and 10.5 degrees above HS incidence).
Any thoughts from those who know would be appreciated.
 Filesize:  60.51 KB
 Viewed:  11240 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Fri Jun 04, 2010 6:04 am    Post subject: slow flying MkIII's Reply with quote
Thom:
Lot of variables in thrust line because of the design of the engine mount.
I insure I have the hardest Lord Mount to help reduce movement on the
mkIII.
I learned about engine excursion with my FS/447 that was equipped with
softer Lord Mounts during engine run up while tied down. The engine rolled
right and forward, loading up the right front Lord Mount.
By chance I discovered how much a problem this was at WOT in the FS. During
a test, at WOT, the FS would not exceed 75 MPH. I rolled off throttle until
I unloaded the engine, then very slowly came back in with power, very
slowly, The FS increased speed to 85 mph. I'm sure it was caused by
misalignment of thrust line. Nursing power back in kept the thrust line
more in line as power and speed increased.
My theory on mkIII thrust line is:
912 rotates opposite two strokes, loading left front mount.
At rest, 5/8" spacers raised the front of the engine bringing thrust line
parallel with the bottom of the wing. In flight, thrust brings the thrust
line back to where it was at rest. I tested this with a flight to Point
Barrow, Alaska, and back. Performance figures were the same as enginge
mounted in stock configuration on another flight to Point Barrow, Alaska,
and back.
Travis Brown, Kolb Aircraft, provides me with the hardest Lord Mount
available. In addition, I insert a 2" fender washer on top the two front
mounts. This prevents the thrust from depressing the front mounts more than
about 1/8" to 1/4".
Two major factors working against our mkIII's is high thrust line and the
way the prop wash hits the tail section.
The lower the engine is mounted on the airframe the faster the mkIII will
fly. My engine is absolutely as low as it can be without hitting the root
tube.
My mkIII and the other faster mkIII's have fully enclosed fuselages with the
rear of the fuselage faired and not cut off square or not covered at all.
So, remember when you are standing there looking at your engine sitting on
top of your Kolb at rest, it will not be in the same position when you are
flying.
Thom Riddle
PostPosted: Fri Jun 04, 2010 10:17 am    Post subject: Re: slow flying MkIII's Reply with quote
Thanks for your thoughts on Lord Mounts, John.
My mounts are very hard rubber and the engine does not appear to move much at all when tied down and run up. Unfortunately, the wet sump on the Jabiru is pretty deep which requires a fairly high mounting. My prop (only 64" diameter) clears the boom tube by at least 5-6" at rest.
My question for you (and/or others) is this. The static (at rest) thrust line of the my engine is pointing upwards 3.5 degrees relative to the bottom of the wing. Is this about right, assuming my mounts are plenty hard? Note that the axis of the motor mount bolts is not vertical like on the Rotax but parallel to the longitudinal axis of the airplane. However I can still raise one side/end vs the other because this mount bolts to the Kolb engine tube. Not sure this shows in the attached photo, but that is all I have right now and my camera keeps quitting on me. Guess it is time for a new one.
 Filesize:  392.71 KB
 Viewed:  11215 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Fri Jun 04, 2010 10:34 am    Post subject: slow flying MkIII's Reply with quote
Yes, as a guesstimate 3.5 deg sounds about right.
john h mkIII
by0ung(at)brigham.net
PostPosted: Sun Jun 06, 2010 7:34 am    Post subject: slow flying MkIII's Reply with quote
Thom Riddle
not sure about the sling shot..... the bottom of the mkIII wing has 9 deg positive incidence in flight. if I read your post correctly you would add 3.5 deg to that, assuming the SS has the same 9 deg in flight (plus or minus), adding the 3.5 would make the front of the engine pointing up at 12.5 deg in flight. guess I am going to have to measure my mike this week... guess in my mind I would think the engine should have less incidence than the bottom of the wing. making the prop more perpendicular to the line of travel.
or am I missing something?
Boyd Young
Thom Riddle
PostPosted: Sun Jun 06, 2010 7:48 am    Post subject: Re: slow flying MkIII's Reply with quote
Boyd,
That is my thought too. I would think that at cruise, the thrust line should be fairly closely aligned with the relative wind.
BTW, I measured the angles again yesterday and came up with a little different numbers but still seems the thrust line is pointing too far up. The reason for the difference in measurement was I used the prop hub this time instead of the top of the engine.
My Slingshot wing bottom chord has an incidence of 7.5 degrees relative to the boom tube and horizontal stabilizer (parallel to boom tube). The thrust line (static) is 9.5 degrees relative to the HS & boom tube, so the engine is point up only 2 degrees rather than 3.5 degrees. But it still seems to me that it should be more aligned with relative wind at cruise AOA.
If my SS flies at cruise with an AOA of 7.5 degrees (guess) then the thrust line (very hard mounts so not perceptible tilting under power) is not parallel to relative wind by about 9.5 degrees.
ON THE OTHER HAND...
Perhaps this is by design to help offset the effect of the high position of the thrust line. Still waiting to hear back from Travis on this question.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
