Fixing a bad hole...
rv10(at)colohan.com
PostPosted: Mon May 31, 2010 8:52 pm    Post subject: Fixing a bad hole... Reply with quote
I've reached the horizontal stabilizer in building my RV-10.  While drilling the 3/32" holes in the spar doublers for the forward spar, I mucked one of the holes up.
In particular, the drill appears to have slid about 3/32" sideways while drilling, mis-placing the hole by 3/32".  Perhaps better explained through pictures:
http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink
http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink
http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink
http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink
So I know how to fix a hole when you make it slightly too large -- you drill it out larger and put an "oops" rivet in it.  But what can you do to fix a hole which is misplaced?  Is there a good fix for this?  Drilling a hole large enough to cover this error would take a rivet larger than 1/8"...
(At worst, I can just replace the spar -- I have a spare, due to an earlier error that Van's made, and so I'd just need to order some new spar doublers.  But I'd like to first learn if I can fix this one.)
Also, while I have your ear -- I made this error while using a brand new Rigid Cobalt drill bit (like this one:  http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm).  The bit appears to be able to cut sideways just as well (or even better) than it can drill straight ahead in aluminum.  It also takes about 20-30 seconds per hole drilling at 4000rpm (assuming my air drill is making its rated speed) while applying moderate pressure.  Is this a known problem with this type of bit, or is my drilling technique off?  I've ordered some "aviation" 3/32" bits from Avery, but wanted to know if I should expect it to be easier to drill straight with those bits.
Thanks!
Chris [quote][b]
Dale Ensing
PostPosted: Tue Jun 01, 2010 4:04 am    Post subject: Fixing a bad hole... Reply with quote
If you are drilling holes for 3/32" rivets, shouldn't you be using a #40 drill and not a 3/32"?
the holes up.
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
martinaerodrome(at)gmail.
PostPosted: Tue Jun 01, 2010 4:52 am    Post subject: Fixing a bad hole... Reply with quote
Use pilot point drill bits available at any good hardware store.  Don't waste your time at Harbor Freight etc.
Dick Martin
RV8 N233M
the fast one
On Mon, May 31, 2010 at 11:51 PM, Chris Colohan <rv10(at)colohan.com (rv10(at)colohan.com)> wrote:
[quote]I've reached the horizontal stabilizer in building my RV-10.  While drilling the 3/32" holes in the spar doublers for the forward spar, I mucked one of the holes up.
Thanks!
Chris
t="_blank">http://www.matronics.com/Navigator?RV-List
ttp://forums.matronics.com
rv6(at)grandecom.net
PostPosted: Tue Jun 01, 2010 5:24 am    Post subject: Fixing a bad hole... Reply with quote
Quoting Richard Martin <martinaerodrome(at)gmail.com>
You might consider a # 8 screw and lock nut.
T Jones
RV9A
Dick Martin
RV8 N233M
the fast one
> pictures:
> Thanks!
> Chris
john_s_bright(at)yahoo.co
PostPosted: Tue Jun 01, 2010 6:43 am    Post subject: Fixing a bad hole... Reply with quote
It's only one hole of tens... not a structural issue... you could do your best with an oops rivet and move on. Is it a cosmetic issue with the skin? You don't show the skin... is the skin bungled-up also? You could fill around it on the exterior skin cosmetically with pro-seal when you mix it for the tanks.
I like the 135 degree split points. IMO cobalt or TiN or whatever does not matter to us with this aluminum. Split points have less tendency to walk than 118 degree non split points but they will still walk. All drills make triangular holes in thin sheet metal.
I use an electric drill that spins maybe 2,400 rpm and I go thru skin and doubler in 1 or 2 seconds. I don't know what's going on with 20-30 seconds but something is wrong.
John Bright
o:757-864-2305
c:757-812-1909
To: rv-list(at)matronics.com
Sent: Tue, June 1, 2010 12:51:12 AM
Subject: Fixing a bad hole...
Thanks!
Chris
dave.saylor.aircrafters(a
PostPosted: Tue Jun 01, 2010 9:41 am    Post subject: Fixing a bad hole... Reply with quote
You could countersink the mis-drilled hole and put a flush rivet in it, under the skin.  Then using the pre-drilled skin as a template, drill the correct hole in the spar, and continue on.  I'd think that one repair on the spar wouldn't have much if any effect on the overall strength.  If you're concerned about the strength of the spar cap you could put a doubler under the existing row of rivets that picked up 6-8 holes.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Jun 1, 2010 at 8:20 AM, Chris Colohan <rv10(at)colohan.com (rv10(at)colohan.com)> wrote:
[quote] This is a slightly unusual assembly in the RV-10.
The spar comes pre-drilled with undersized holes in the flange.  The doubler comes with no holes.
You clamp the doubler on the spar, and drill through the existing spar flange holes and through the doubler with a 3/32" drill.  When you later assemble the whole thing with the skin in place, you match drill everything (including the skin) with a #40 drill.
So for this hole I've messed up the spar flange and doubler, and now have a misplaced hole to go under my pre-drilled skin (which I have not touched yet).  I was hoping to find a solution which does not involve:  (a) drilling another hole right next to the first mistake, since that would weaken the spar flange, or (b) making my skin look ugly.  I fear this solution doesn't exist...
Chris
On Tue, Jun 1, 2010 at 4:58 AM, <densing(at)carolina.rr.com (densing(at)carolina.rr.com)> wrote:
> the holes up.
Kellym
PostPosted: Tue Jun 01, 2010 12:22 pm    Post subject: Fixing a bad hole... Reply with quote
Also, you need a drill with a good teasing trigger that you can start
very slow, and only after the drill bit has started, run the speed up
high. Chicago Pneumatics makes a good one that Avery sells for around
$125, and there are the Sioux drills for about double that.
John Bright
o:757-864-2305
c:757-812-1909
*To:* rv-list(at)matronics.com
*Sent:* Tue, June 1, 2010 12:51:12 AM
*Subject:* Fixing a bad hole...
larger than 1/8"...
Thanks!
Chris
Kelly McMullen
KCHD
HCRV6(at)comcast.net
Chris,
However you fix this oops, save yourself a lot of headaches in the future by ordering a dozen or so #40 and #30 (for AN4 rivets) drill bits from Avery or Cleveland Tool. Do not use fractional drill bits for aircraft rivets. A sharp #40 drill should take no more than about 5 seconds to go thru that flange.
Harry Crosby
RV-6 N16CX, 692 hours
Rick Galati
PostPosted: Tue Jun 01, 2010 1:30 pm    Post subject: Fixing a bad hole... Reply with quote
Chris,
I see at least two ways of addressing that particular problem:
First fix option: You could "pull" the hole over and clean it up although I suspect it may need to go up to .1875 to do that perfectly. Then after dimpling, the hole would require an AD6 rivet or more likely....a structural screw. The problem is you likely do not possess the proper tooling to clean up the hole and even if you did, any 3/16" fastener would stand out like a sore thumb among all those AD3 rivets. Still, here is a link to "builders tip" I once wrote that describes the technique of "pulling" or moving a hole over:
http://www.vansairforce.com/community/showthread.php?t=11769&highlight=move+hole+bushing
Second fix option: This fix is what I would be inclined to do, because in the end you can install a regular AD3 rivet in the bad hole as if it never existed. Using a pattern file or similar, clean up the bad hole in the spar so no sharp edges exist. Then fabricate an .032 doubler of a given length. You could install that doubler by simply picking up a number of existing holes in the spar OR you could fabricate it as shown in the second picture by riveting it in place using a total of four NAS1097 rivets through the spar and doubler. Then later, when the skin is clecoed into place, use the subject hole location on the match hole skin to drill through the doubler. The over-sized spar hole would be effectively ignored. Care must be taken to insure whatever dimpling you do to the spar is effective. Done properly, nobody but you will ever know.
Rick Galati
RV-6A
RV-8
 Filesize:  83.62 KB
 Viewed:  10726 Time(s)
rv10(at)colohan.com
PostPosted: Tue Jun 01, 2010 1:36 pm    Post subject: Fixing a bad hole... Reply with quote
I have a bunch of these numbered bits from Avery -- but the in this one place the instructions call for drilling to 3/32" when you assemble the spar and doublers, and then match drilling up to #40 when you have the skins in place.
I've now ordered some fractional aviation bits from Avery, and so when I redo this I'll have the right tools.
Chris
On Tue, Jun 1, 2010 at 1:15 PM, <HCRV6(at)comcast.net (HCRV6(at)comcast.net)> wrote:
[quote]Chris,
Harry Crosby
rv10(at)colohan.com
PostPosted: Tue Jun 01, 2010 1:40 pm    Post subject: Fixing a bad hole... Reply with quote
I have the Avery drill -- the issue here is not that I started the hole in the wrong place, but that once the hole started through one piece of aluminum the bit managed to expand the hole sideways into a giant oval instead of drilling through the next piece.  It acted more like a router than a drill.  Sad
After the messages on this list and off -- I've ordered new HS-1013 doublers from Van's, and will use this with my spare spar to redo the whole thing the right way.
Chris
On Tue, Jun 1, 2010 at 1:16 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote] --> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Also, you need a drill with a good teasing trigger that you can start very slow, and only after the drill bit has started, run the speed up high. Chicago Pneumatics makes a good one that Avery sells for around $125, and there are the Sioux drills for about double that.
John Bright
o:757-864-2305
c:757-812-1909
*From:* Chris Colohan <rv10(at)colohan.com (rv10(at)colohan.com)>
*To:* rv-list(at)matronics.com (rv-list(at)matronics.com)
Thanks!
Chris
get="_blank">http://www.matronics.com/Navigator?RV-List
http://forums.matronics.com
le, List Admin.
carl.froehlich(at)verizon
PostPosted: Tue Jun 01, 2010 4:09 pm    Post subject: Fixing a bad hole... Reply with quote
The way I approach these kind of problems:
<![if !supportLists]>1. <![endif]>If you can drill it out to 1/8”, then do so and use a 1/8” rivet. No one will ever see the one or two 1/8” rivets in the sea of 3/32” rivets.
<![if !supportLists]>2. <![endif]>If after drilling out the screw up the hole it too large, then just get a replacement part from Van’s. The parts are cheap – especially when you think about flying this plane for 20-30 years and every time you look at the tail you wonder if you should have replace the part or not.
Carl Froehlich
RV-8A (550 hrs)
RV-10 (systems install)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chris Colohan
Sent: Tuesday, June 01, 2010 5:29 PM
Subject: Re: Fixing a bad hole...
Chris
Chris,
Harry Crosby
Kellym
PostPosted: Tue Jun 01, 2010 7:42 pm    Post subject: Fixing a bad hole... Reply with quote
I agree with this approach. Done properly, there should be no strength
compromise. You can also slightly countersink the underside of the bad
hole, to give the shop head a better grip.
In fact, I know there are a number of RV 10 wings that have this sort of
repair where the plans call for one single lug nut plate in the middle
of a bunch of two lug nut plates. Before long you will learn how to
efficiently repair your mistakes, the plan mistakes, the QB facility
mistakes, etc. In fact, fixing mistakes is one of the better skills you
acquire as you move along.
There are some who say you should just pick a finger to drill through,
with a small bit, so it isn't a surprise when it happens. Since I had
already done that long ago working on the motorhome type of RV, I
figured I didn't need to repeat the experience. ;-p
6-8 holes.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
Chris
While drilling
mucked one of
> the holes up.
_blank">http://www.matronics.com/contribution *
Kelly McMullen
KCHD
Kellym
PostPosted: Tue Jun 01, 2010 7:47 pm    Post subject: Fixing a bad hole... Reply with quote
Personally, I have found that #41 drills make for a snugger fit dimpled
hole. I use either the drill bit for new holes, or #41 chucking reamer
to enlarge the pre-punched holes. The reamer both makes it unlikely you
will get a hole where it isn't supposed to be, and leaves a smoother
edge that needs less de-burring.
Most of my skins were probably pre-punched to #42, and won't accept
dimple die, but with #41 the dimple die fits perfectly.
On 6/1/2010 1:15 PM, HCRV6(at)comcast.net wrote:
[quote] Chris,
Harry Crosby
Kelly McMullen
KCHD
Kellym
PostPosted: Tue Jun 01, 2010 8:00 pm    Post subject: Fixing a bad hole... Reply with quote
Sounds like your drill bit was either bent, or not installed straight in
the drill. You shouldn't get that kind of wobble from a drill bit.
You can keep a few pieces of scrap to test a drill bit on before doing
critical parts, and to fine tune your rivet gun pressures before driving
any that will look bad if not driven right.
Don't feel bad. I know one or two people that misread the instructions
and misdrilled those doublers, needing to obtain new ones. When you get
into wings and fuselage you will forget all those minor speed bumps on
the tail.
Chris
double that.
the tanks.
John Bright
o:757-864-2305
c:757-812-1909
*From:* Chris Colohan <rv10(at)colohan.com <mailto:rv10(at)colohan.com>>
*To:* rv-list(at)matronics.com <mailto:rv-list(at)matronics.com>
Thanks!
Chris
le, List Admin.
Kelly McMullen
KCHD
pitts_pilot(at)bellsouth.
PostPosted: Wed Jun 02, 2010 4:43 am    Post subject: Fixing a bad hole... Reply with quote
Of all the rhetoric this thread has generated, I find the suggestion of
making the hole 'clean' to accept a rivet .... put one in, and then use
the skin as a guide to redrill the hole .... with a good bit. As Kelly
said in a previous post .... fixing (not replacing) an oops will become
a common skill.
Linn
in the drill. You shouldn't get that kind of wobble from a drill bit.
doing critical parts, and to fine tune your rivet gun pressures before
driving any that will look bad if not driven right.
get into wings and fuselage you will forget all those minor speed
bumps on the tail.
PostPosted: Wed Jun 02, 2010 8:35 pm    Post subject: Fixing a bad hole... Reply with quote
And to repeat myself, dump the fractional drill bits and get some decent #40 (or #41 doesn't really matter) and #30 aircraft split point bits from Avery or Cleveland.
Harry Crosby
rv10(at)colohan.com
PostPosted: Wed Jun 02, 2010 9:06 pm    Post subject: Fixing a bad hole... Reply with quote
I took your advice and ordered new bits from Avery Sunday night when I ordered the replacement parts.  Hopefully they arrive before next weekend...
Thanks!
Chris
On Wed, Jun 2, 2010 at 9:29 PM, <HCRV6(at)comcast.net (HCRV6(at)comcast.net)> wrote:
[quote] And to repeat myself, dump the fractional drill bits and get some decent #40 (or #41 doesn't really matter) and #30 aircraft split point bits from Avery or Cleveland.
Harry Crosby
