Hauck Ramblings On Kolb aircraft.
Goto page 1, 2  Next
PostPosted: Fri May 28, 2010 2:28 pm    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
Gang:
After 26 years of building, flying, experimenting, modifying, crashing,
rebuilding, my three Kolbs, and 4,500+ hours in my personal Kolbs (not
counting time in factory Kolbs and other Kolbs), I have discovered Kolb
aircraft are unique. They defy engineers and numbers. They do things that
are unexplainable, but they do everything well. They have no bad habits,
but some pilots who lack basic piloting skills, blame the Kolb for their
problems instead of themselves. There is no such thing as Kolb Quit, but
there are pilots that stall the Kolb several feet above the ground, blaming
hard landings on an easy to fly airplane.
I encourage kolbers to experiment and test, and I learn from their efforts,
good and bad.
Much of the experimenting that is being done today, is repetitious, but I
encourage folks to try and improve what we have.
Going from Airtrac 600x6 to 800x6 tires on my mkIII made no change in
performance.
Going from a Maule Tundra Tailwheel 8" pneumatic, 12 lbs, to a Maule Solid
6", 7 lbs, made little difference in CG, but on paper neither tailwheel
should fly. No change in performance. I made this change a month ago in
prep to fly to MV. Thought I would pick up a couple MPH. Negative.
My mkIII has been an 85 mph cruise airplane with 65, 80, and 95 hp engines.
The primary difference is take off and climb performance, which is extremely
important based on the places I fly. Cruise and max speeds are very
similiar.
The real beauty of my mkIII is its ability haul tremendous loads, to operate
out of extremely short strips at high altitudes, to handle violent winds and
weather, to forgive me when I push her to the limits of both of us.
Will she ever fly faster? Doubt it. So far have never been out run by any
other Kolb model except John Williamson's 912ULS Kolbra. He was good for
105 mph, Miss P'fer, 95 mph. His cruise was also 10 mph faster.
Can't wait to get back in the air and exercise my right to flight. Three
months and counting.
Ralph B
PostPosted: Sun May 30, 2010 7:42 pm    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Good post John.
I enjoy both my Kolbs.
Ralph B
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
JetPilot
PostPosted: Mon May 31, 2010 7:40 pm    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
I hope you get back in the air soon John. Your Kolb is indeed very fast, both mine and the other MK III here in Miami cruise at 70 MPH. It just feels really good there, I could do 75, but after that I just hit a wall and am burning so much more gas to and almost full power to hit 80. I am very happy with 70 MPH at less than 4 GPH and 4200 RPM cruise, it feels perfect. The other Kolb, Fat albert has an 80 HP 912, and cruises at almost the exact same speed as mine.
Kolb MK-III Xtra, 912-S
PostPosted: Tue Jun 01, 2010 4:55 am    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
mike b/gang:
Thanks to you and all the other Kolbers who have expressed your concern
about my recent unfortune.
Wonder what the difference is?
Right now I know four other MKIIIc's that fly like mine:
Gary Haley, 912ULS
John Bickham, 912UL
Bruce Chaisson, 912ULS
Steven Green, 912ULS
Jason Omelchuck
PostPosted: Tue Jun 01, 2010 10:36 am    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Hello all,
I would be very interested in how fast people are able to cruise in their Kolbs. State the model of Kolb, engine, RPM, airspeed and any other notes you may feel are revelant. I guess John has gone first, so I will go second.
MKIII, Yamaha Vector, 7000rpm, 70MPH. My engine does not have a published RPM so I cruise between 7000 and 7300RPM at 70mph to 75mph. If I fly faster than 75, my right door dimples in.
Jason
mike b/gang:
Gary Haley, 912ULS
John Bickham, 912UL
frank.goodnight(at)att.ne
PostPosted: Tue Jun 01, 2010 12:24 pm    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
Hi All,
Firestar2-- no cover on cage , no windscreen, no nose bowl. HKS700 engine Gross 750lbs -- 50 mph (at) 5000 rpm
about 2.8 gal per hr.
Frank Goodnight
Brownsville , TX
Sent: Tue, June 1, 2010 1:36:45 PM
Subject: Re: Hauck Ramblings On Kolb aircraft.
--> Kolb-List message posted by: "Jason Omelchuck" <jason(at)trek-tech.com (jason(at)trek-tech.com)>
Hello all,
Jason
> Mike
mike b/gang:
Gary Haley, 912ULS
John Bickham, 912UL
Ralph B
PostPosted: Tue Jun 01, 2010 2:33 pm    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Jason Omelchuck
Hello all,
Jason
The Kolbra cruises 80mph 5000 RPM 80hp 912
The Firestar cruises 60mph 5000 RPM 40hp 447
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
ces308
PostPosted: Tue Jun 01, 2010 3:24 pm    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Hello all.... M3X..
90 mph (at) 2900 rpm Jabiru A-2200 Mostly cruise (at) 80 (at) 2800...
chris ambrose
M3X ? Jabiru A-2200 85 hp 137.00hrs
N327CS
aoldman(at)xtra.co.nz
PostPosted: Tue Jun 01, 2010 11:52 pm    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
My MK111c is indicating 73mph at 6200rpm { calm conditions ,drops off fast
in a head wind }and about 68 at 5900 . Engine sounds happy at the higher rpm
and runs cooler .The engine is a 503 . The 503 will turn at 6600 WOT on
climb out. Have had just on 90mph down hill WOT , sorry can not remember
what the RPM was.
Downunder
MK111c 503
Thom Riddle
PostPosted: Wed Jun 02, 2010 2:23 am    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Slingshot with Jabiru 2200A 80hp engine.
The max rpm achievable in S&L flight with the current prop is 3168 though the redline is 3300 where the max hp of 80 is achieved. These numbers were with the big 800x6 tires and taken at about 1,500' density altitude.
Numbers are in attached image.
 Filesize:  140.4 KB
 Viewed:  18067 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
jbhart(at)onlyinternet.ne
PostPosted: Wed Jun 02, 2010 5:19 am    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
http://forums.matronics.com//files/n64086_numbers_230.jpg is a good example
of how far you can travel by slowing up. Drag increases with the square of
the velocity. With this performance and if one is not flying into a head
wind, one could get almost ten miles per gallon further by slowing up.
Jack B. Hart FF004
Winchester, IN
by0ung(at)brigham.net
PostPosted: Wed Jun 02, 2010 6:02 am    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
Jack B. Hart FF004
Winchester, IN
Do not archive.
I checked out your spread sheet. And I extended your graph to include 100
mph. I did this by determining the hp difference in the previous two 5 mph
jumps. There is an old statement that says,,, to double the speed
requires 4 times the hp. Seems that your chart is very close to this
statement. The one thing I had never done was check the mpg at different
power settings. Thank you for your effort.
Boyd Young
Thom Riddle
PostPosted: Wed Jun 02, 2010 6:47 am    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Nobody asked so if you are not interested in more detail about the data in my table, now is the time to move on to next post. However, I suspect one or two might be interested in the extra detail, so here it is.
FYI regarding my spreadsheet table data.
The TAS and Engine RPM were taken from actual testing, multiple times. The TAS being the average of GPS groundspeeds straight upwind and downwind. All of this was done at about 1,500' density altitude.
The HP being developed(absorbed by the prop) and the fuel burn rate (GPH) was from the Prop Selector program assuming a fixed fuel consumption rate per horsepower hour, .42 lb/hp/hr quoted by Jabiru. As it turns out, the effective pitch of my prop 64x31 is closer to 39" according to the Prop Selector.
The MPG was a simple division of MPH by GPH.
If you look carefully at the data, you may notice a wrinkle in the MPG numbers between 65 mph and 75 mph, wherein the 70 mph airspeed yields a slightly better MPG than either side of this number. Either my numbers were off a bit during the testing or this happens to be the best speed for my Slinghsot that is a compromise between time-to-destination and fuel burn/mile. I suspect it is the later since these numbers are averages of multiple tests on different days.
At higher density altitudes one can expect higher TAS for a given engine power output but it takes more throttle opening and higher RPM (fixed pitch prop) to get the same power output. I flew an hour plus taxi and warmup time this morning and climbed to 8,000' DA and measured a TAS of 84.5 mph at the same power setting as I see 80 mph at 1,500' DA. The rpm to achieve the same power at the higher DA I calculated to be about 2850 instead of 2712 at 1,500' DA. To maintain same power setting for a full hour, I did the climb at the same constant power setting gradually increasing rpm at a rate of about 25 rpm per 1,000' of increase in DA. After landing and refilling. I calculated my new fuel burn rate at this power setting to be about 3.5 gph. So, at altitude, I can expect about 24 mpg at about 84 mph.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dana
PostPosted: Wed Jun 02, 2010 8:49 am    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
requires 4 times the hp...
Actually, to double the speed (all other things being equal) it takes 8 times the power to double the speed. It's not quite equal, of course, and thus not quite 8X as at higher speeds the AOA and thus the induced drag will be less.
-Dana
Shaw's principle:
Build a machine that a fool can use, and only a fool will want to use it. [quote][b]
Jason Omelchuck
PostPosted: Wed Jun 02, 2010 11:18 am    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Hello All,
These are the kind of numbers that just confound me. I am running almost 100 hp at my 70mph cruise and here is someone flying 73mph using a little less than 50hp. What can cause that much of a disparity? This has always fascinated me.
Jason
MKIII
Portland, OR
what the RPM was.
Downunder
MK111c 503
HShack(at)aol.com
PostPosted: Wed Jun 02, 2010 11:23 am    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
FS II, "C" box 3.47:1, 3 blade 68" Kiev prop, 503DCDI, 65mph (at) 5500 rpm
In a message dated 6/1/2010 2:37:12 P.M. Eastern Daylight Time, jason(at)trek-tech.com writes:
--> Kolb-List message posted by: "Jason Omelchuck" <jason(at)trek-tech.com>
Hello all,
Jason
> Mike
mike b/gang:
Gary Haley, 912ULS
John Bickham, 912UL
http://forums.matronics.com/viewtopic.php?p=299600#299600===============================================
_-= the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
Fran Losey
PostPosted: Wed Jun 02, 2010 11:32 am    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
I am not an expert at all here, but look at the profile of the engines you are comparing...sure looks like drag to me, all other factors being equal of course.
Fran Losey
N62FL (reserved)
loseyf@comcast.net
Thom Riddle
PostPosted: Wed Jun 02, 2010 12:09 pm    Post subject: Re: Hauck Ramblings On Kolb aircraft. Reply with quote
Another variable, sometimes a pretty big one, is the accuracy of the airspeed indicator and location of pitot and static source. I don't know how many of the quoted numbers are TAS vs IAS. In most of the experimental airplanes I've owned, and even the SLSA I owned, the ASIs are notoriously inaccurate. That is why I take the little extra trouble to find the wind direction and makes runs directly upwind and then down wind to get the average GPS groundspeed, which is TAS.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Wed Jun 02, 2010 12:41 pm    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
equal of course.
Fran L
Fran/Gang:
My mkIII has been powered by 65, 80 and 95 hp engines.
Top speed has always been right at 95 mph.
Cruise speeds:
65 hp - 80 mph 5,800 rpm 582
80 hp - 85 mph 5,000 rpm 912UL
95 hp - 88 mph 5,000 rpm 912ULS
Kolbs are unique airplanes. The performance of a Kolb is the direct result
of how it is built, how tight the fabric is shrunk, and how well it is
finished. These are just a few of the contributing factors. There are
others. Fine tuning stuff means a lot. The prop is the only connection
between the engine and the air. Fine tuning a prop is critical, all 3
blades the same pitch.
Pitch it WOT, straight and level flight, so it will just barely bump the max
continuous rpm red line. Works for my airplanes and my boats. In fact,
that is where I got the technique from 26 years ago, from selecting boat
props.
Top speed of my US and FS were both 85 mph, 35 and 40 hp respectively, using
the same Winter venturi type asi that requires no static source, the monster
that screws up asi calibration.
Let me go back to fabric a second. Kolb wing bottoms are flat when they are
not flying. In the air they are concave, the amount dependent on how tight
the fabric is. Most builders stop shrinking before the fabric starts
pulling tubes. I shrink to 350F, bend tubes, and my fabric is tight as a
snare drum. Same shrinking philosophy on all three my airplanes. All good
performers. Could be I have flatter wing bottoms than most.
Again, my airplanes, my thoughts. I'll put my mkIII up against anyone
else's. I like competition.
Always said my mkIII was pretty much an 85 mph airplane no matter what I did
to it. No matter how much hp I put on it, it would still be an 85 mph
airplane.
I don't tune for economy. I tune for performance and reliability. Been
able to back that up with actual successful flights over the years.
lcottrell
PostPosted: Wed Jun 02, 2010 12:47 pm    Post subject: Hauck Ramblings On Kolb aircraft. Reply with quote
FS II two blade warp, HKS 64 MPH (at)5300, heavy aircraft.
Larry
Goto page 1, 2  Next
Page 1 of 2
