Cowl/engine interference?
rv10rob(at)gmail.com
PostPosted: Sun May 23, 2010 8:44 pm    Post subject: Cowl/engine interference? Reply with quote
Just did the cowl fitting this weekend, and it looks like I have an interference issue with the mixture arm (Silver Hawk FI system) and cowl.  Anyone else have this problem?  I have only about 1/4" clearance, which doesn't seem like enough.  I've heard of interference issues with the FAB, but not cowl.
I also have a problem with the fuel line for the #2 cylinder being only 1/8-1/4" from the top cowl--will be calling Aero Sport about that tomorrow.
-Rob
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
dave.saylor.aircrafters(a
PostPosted: Mon May 24, 2010 10:48 am    Post subject: Cowl/engine interference? Reply with quote
Rob,
I remember lowering the spider for the same reason.  I think I just turned the bracket over and trimmed as necessary.  Lots of room now.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sun, May 23, 2010 at 9:42 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
-Rob
Rob Kochman
tp://forums.matronics.com
 Filesize:  119.52 KB
 Viewed:  1751 Time(s)
PostPosted: Mon May 24, 2010 1:38 pm    Post subject: Cowl/engine interference? Reply with quote
Thanks, Dave... the spider is fine; it's the "loop up" right before the line goes into the #2 cylinder that's the problem.  I figure the line can probably be adjusted/moved, but want to get Aero Sport's take on it, so I don't break anything.
Man, your oil door sure is nice Smile
-Rob
On Mon, May 24, 2010 at 11:45 AM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)> wrote:
Rob,
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
-Rob
Rob Kochman
Rob Kochman
