William Halverson
Posted: Sun May 23, 2010 9:34 am Post subject: FSDO changing operating limitations on pre-moratorium a |
Does the FAA intend to eliminate the experimental catagory altogether and replace it with type certificates for _all_ aircraft? Isn't that the implication of this:
"Those aircraft, except for purpose changes, will not be affected until the FAA works with the public to determine the best strategy to certificate all experimental exhibition and/or air racing aircraft in accordance with the new policy."
Posted: Sun May 23, 2010 10:33 am Post subject: FSDO changing operating limitations on pre-moratorium a |
Eliminating the Experimental category is highly unlikely. However, changing the purpose such as Exhibition or Amateur Built or Air Racing into some other grouping I guess could happen. God only knows how or what the FAA is thinking.
Dennis
N13472(at)aol.com Guest
Posted: Sun May 23, 2010 10:37 am Post subject: FSDO changing operating limitations on pre-moratorium a |
And he is thinking how in the Hell did I create those fools!
Tom Elliott
CJ-6A NX63727
702-595-2680
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Sunday, May 23, 2010 11:34 AM
To: yak-list(at)matronics.com
Subject: Re: FSDO changing operating limitations on pre-moratorium aircra
Dennis
radiopicture
Posted: Sun May 23, 2010 11:09 am Post subject: FSDO changing operating limitations on pre-moratorium a |
I have to say... Knock on wood... our FSDO (Rochester-23) is nothing but helpful with EE stuff... always seems to try to find ways to make it work. I guess we're lucky.
On May 23, 2010, at 2:46 PM, A. Dennis Savarese wrote:
[quote]Well said Tom!
Dennis
[quote]---
Pete Fowler
Posted: Mon May 24, 2010 6:57 am Post subject: Re: FSDO changing operating limitations on pre-moratorium |
So "armed" with the actual order, I called my guy at the FSDO and politely pointed out paragraph e and he's re-rewriting the ops limits with the original language but adding the arrival/departure routes for my local airport. Um, I'm not sure that's 100% correct either. Those routes are given to experimental aircraft in the area but it's a new operating limitation that seems like it's still covered by paragraph "e" where they can't change at all.
William Halverson
Posted: Wed May 26, 2010 6:01 am Post subject: FSDO changing operating limitations on pre-moratorium a |
The other interpretation of your happy story is there is a huge inconsistency in the training FSDO staff receive .... almost sounds like the differences between judges in the legal system - same laws, different interpretations.
Posted: Wed May 26, 2010 7:59 am Post subject: FSDO changing operating limitations on pre-moratorium a |
Yes, but from what I am learning... That is against the law, and you
have recourse. It's not an easy task, but one I am starting to learn
right now.
Mark
