dlm46007(at)cox.net Guest
Posted: Mon May 17, 2010 11:12 am Post subject: GRT probes |
Changed the EGT probe on #2 today. This is the second time to replace #2 EGT probe. Note the black shrink wrap near the connectors. These are the cheaper probes from GRT. Note that I did not say inexpensive.; the price from GRT is about $10 less than their "higher quality" probe. I did not know this when I received and installed my EIS 6000. They are not inexpensive because in 278 hours I have had four failures using these probes. Each time a failure occurs, the aircraft must be uncowled and a part obtained from GRT. Each failure cost about 2 hours of my labor and acquisition and AOG freight charges to remedy. If you use GRT probes at least insist on the EGT probes with the white shrink wrap near the connectors; they are the "higher quality" probes.
37.18 KB |
5820 Time(s) |
scottmschmidt(at)yahoo.co Guest
Posted: Mon May 17, 2010 12:37 pm Post subject: GRT probes |
I have now replaced all six probes after 650 hours of flying.
If you have not flown I would return everyone of them and get the higher quality probe that GRT offers. So far, no problems with them.
-Scott Schmidt
On May 17, 2010, at 1:09 PM, "DLM" <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote] Changed the EGT probe on #2 today. This is the second time to replace #2 EGT probe. Note the black shrink wrap near the connectors. These are the cheaper probes from GRT. Note that I did not say inexpensive.; the price from GRT is about $10 less than their "higher quality" probe. I did not know this when I received and installed my EIS 6000. They are not inexpensive because in 278 hours I have had four failures using these probes. Each time a failure occurs, the aircraft must be uncowled and a part obtained from GRT. Each failure cost about 2 hours of my labor and acquisition and AOG freight charges to remedy. If you use GRT probes at least insist on the EGT probes with the white shrink wrap near the connectors; they are the "higher quality" probes.
<IMG_0732.JPG>
Tim Olson
Posted: Mon May 17, 2010 1:03 pm Post subject: GRT probes |
I've been following this with interest because I've been
flying 625 hours now with only one probe failure on
the same probes, in fact the black labeled ones. In
fact, the failure I had was due to the crimped end.
I've removed them twice or so, when I removed the exhaust,
and reinstalled. I'm not sure why mine have been
reliable, but they have been.
Tim Olson - RV-10 N104CD
Scott Schmidt wrote:
| Quote: | I have now replaced all six probes after 650 hours of flying.
-Scott Schmidt
> <IMG_0732.JPG>
jdriggs49(at)msn.com Guest
Posted: Mon May 17, 2010 1:08 pm Post subject: GRT probes |
Just how expensive are the better ones?
Date: Mon, 17 May 2010 13:35:28 -0700
Subject: Re: GRT probes
-Scott Schmidt
| Quote: | Changed the EGT probe on #2 today. This is the second time to replace #2 EGT probe. Note the black shrink wrap near the connectors. These are the cheaper probes from GRT. Note that I did not say inexpensive.; the price from GRT is about $10 less than their "higher quality" probe. I did not know this when I received and installed my EIS 6000. They are not inexpensive because in 278 hours I have had four failures using these probes. Each time a failure occurs, the aircraft must be uncowled and a part obtained from GRT. Each failure cost about 2 hours of my labor and acquisition and AOG freight charges to remedy. If you use GRT probes at least insist on the EGT probes with the white shrink wrap near the connectors; they are the "higher quality" probes.
<IMG_0732.JPG>
http://www.matronics.com/Navigatwww.matronics.com/contribution">http://www.matronics.com/contribution | Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. [quote][b]
rleffler
Posted: Mon May 17, 2010 2:43 pm Post subject: GRT probes |
Scott,
How do you determine which ones are the higher quality?
I only see reference to a standard set of probes on their site.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Monday, May 17, 2010 4:35 PM
-Scott Schmidt
_________________ Bob Leffler
N410BL - Phase I
Ron.McGann(at)ausawd.com Guest
Posted: Mon May 17, 2010 2:52 pm Post subject: GRT probes |
I have not checked the archives over at VAF on this topic, but it might be worthwhile starting a thread over there. There are a bucket load of RVs using the GRT system and their probes. I have found GRT great to deal with, and I’m sure they will take appropriate action if there is any hint of negative press.
Cheers
Ron
VH-XRM, flying in Oz
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
Sent: Tuesday, 18 May 2010 5:10 AM
Subject: GRT probes
Posted: Mon May 17, 2010 3:22 pm Post subject: GRT probes |
$10 more per probe
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Monday, May 17, 2010 2:08 PM
Subject: RE: GRT probes
-Scott Schmidt
<IMG_0732.JPG>
Sandy indicated that there were two different quality probes; she indicated that the standard (black wrap) probes work for most. Perhaps they got a bad batch. She said that the white wrap are available for about $10 more per probe. I have also researched GEM, Alcor and EI and may buy a replacement set from EI. My Glastar had all EI engine instruments and in 530 hours I never had a EGT or any of their probes fail. On my C177RG I had a GEM603 and had one or maybe two EGT probe failures over at least 15 years and 2000+ hours.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Monday, May 17, 2010 3:44 PM
Scott,
-Scott Schmidt
Posted: Mon May 17, 2010 5:02 pm Post subject: GRT probes |
Bob, Sandy just mentioned that they offered a higher temp option when I called the first time. And $10
I am not sure why I have had probe problems Tim and you have not. I do have ceramic coated exhaust that may store more heat inside the system. I also located my probes as close as the plans discussed to the cylinders (I think that was 2.5").
If I did it again I would probably locate them further down the exhaust, maybe that would make the difference. The new probes appear to fix the problem as I have not had one issue with them.
I also have some skin friction heat caused by the speed of my plane that increases the heat of the exhaust. That is most likely the problem
Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Mon, May 17, 2010 4:43:50 PM
Scott,
-Scott Schmidt
Tim Olson
Posted: Mon May 17, 2010 5:13 pm Post subject: GRT probes |
I think mine are 2" or so. When mine do go bad I'll just get 6 new ones and the good ones then. But for now I'm a happy camper.
I think you're right about the skin friction heat....that's the hot tunnel reason too. Have you noticed your wing leading edges glow slightly orange at night too?
On May 17, 2010, at 8:00 PM, Scott Schmidt <scottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)> wrote:
[quote]Bob, Sandy just mentioned that they offered a higher temp option when I called the first time. And $10
Scott Schmidtscottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
From: Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)>
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Scott,
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
-Scott Schmidt
