Bussmann fuse blocks terminal tool
rv8iator
PostPosted: Mon May 17, 2010 5:14 am    Post subject: Bussmann fuse blocks terminal tool Reply with quote
Ron,
There should be a PDF attached to this message. Sorry for the delay.
Chris Stone
Hi Chris
"I can send you a sketch. Very easy to make from a piece of
~.030-.040 thick steel."
If you don't mind, please send a
sketch.
Thx.
Ron Parigoris
BussmanTermTool.pdf
 Filename:  BussmanTermTool.pdf
 Filesize:  181.28 KB
 Downloaded:  872 Time(s)
C. Stone (RV8iator)
PostPosted: Mon May 17, 2010 7:58 am    Post subject: Bussmann fuse blocks terminal tool Reply with quote
At 08:06 AM 5/17/2010, you wrote:
Ron,
Chris Stone
Chris, I'd like to archive your sketch on the
website. Can you give me a list of the Bussmann
fuse blocks to which this tool applies?
rckol
PostPosted: Mon May 17, 2010 12:58 pm    Post subject: Re: Bussmann fuse blocks terminal tool Reply with quote
>Very easy to make from a piece of ~.030-.040 thick steel.
Chris,
This means the dimension of 0.40 on the drawing should be 0.04?
rck
rv8iator
PostPosted: Tue May 18, 2010 5:11 am    Post subject: Bussmann fuse blocks terminal tool Reply with quote
Here are the Bussman fuse blocks that the terminal removal tool will work with:
BUSSMANN BLOCK 15712-14-06-21A
20 position rear terminal split buss ATC fuse block
BUSSMAN BLOCK
24 position rear terminal triple split buss ATC fuse block
..chris
>Chris Stone
C. Stone (RV8iator)
jschroeder(at)perigee.net
PostPosted: Tue May 18, 2010 9:16 am    Post subject: Bussmann fuse blocks terminal tool Reply with quote
Chris -
In this series of Bussmann fuse blocks, there are a lot of variations of
size and configuration. This is a modular line of blocks. We have two
20/8's installed in our Lancair ES. They are really great items. Each
comes with the extraction tool. I have the drawings from the company and
can plot them in a .pdf file if anyone is interested. Perhaps, if Bob
doesn't already have them, I could send them to him for posting.
John Schroeder
On Tue, 18 May 2010 09:08:55 -0400, Chris Stone <rv8iator(at)earthlink.net>
work with:
BUSSMAN BLOCK
...chris
>> Chris Stone
> Bob . . .
rckol
PostPosted: Tue May 18, 2010 9:48 am    Post subject: Re: Bussmann fuse blocks terminal tool Reply with quote
This is the Bussman 15710 Series ATC Fuse Block, which includes the 15711, 15712 and 15713 (single, dual and triple bus versions).
The tool is for the Delphi Pack-Conn III terminals that are inserted into the fuse block. The tool is probably more specific to the terminals than the fuse block.
rck
PostPosted: Tue May 18, 2010 10:51 am    Post subject: Bussmann fuse blocks terminal tool Reply with quote
I might but I'm away from the main data base computer.
If you would be so kind to send what you have, I'll
make sure it either is or will be part of the data
archives on the website.
