frans(at)privatepilots.nl Guest
Posted: Wed May 12, 2010 12:08 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
On 04/12/2010 08:06 PM, Peter Zutrauen wrote:
| Quote: | I'm perplexed - all the photos I've ever looked at of Europas in cruise,
the trim tab is *up* (as others have noted), thus the flying elevator is
by definition providing *lift* to the tail.... a contradiction to my
teachings.
Let's add some more to the confusion...
Especially for those who claim never having seen an Europa with the anti
servo tab NOT in the up position, here are some pictures we took when
flying our PH-DIY in formation with the PH-JAI from Tim Weert.
As you can see on the attached pictures, the PH-DIY has the anti servo
tab perfectly in line with the rest of the tail plane (as it should be,
because it is an anti servo tab, who's task it is to drive the tailplane
until it is line with the trim tab).
Frans
30.85 KB |
15110 Time(s) |
24.53 KB |
15110 Time(s) |
16.92 KB |
15110 Time(s) |
peterz(at)zutrasoft.com Guest
Posted: Wed May 12, 2010 3:05 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Thanks Frans!
*Very* interesting.
just a note - my original statement below is wrong - as an upward trim tab results in a downward force on the tail, not lift as I had originally (incorrectly) thought.
questions:
- were you in stead-state constant-altitude cruise?
- where was your trim set at?
- was your stick force = 0?
- what was your cruise speed?
- what was your weight and balance (with fuel at that point in time)?
As the tailplane is a symmetrical airfoil, my confused mind asserts that in cruise (since the horizontal stab by definition must be providing a downward force) your tailplane must have been at a negative angle of attack, and since the combination anti-servo/trim tab was in a neutral position then I would have expected a steady stick force would have needed to be applied.... or a far aft CG condition would have been needed?
Many thanks!
Pete
A239
On Wed, May 12, 2010 at 4:05 AM, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
> teachings.
Frans
Posted: Wed May 12, 2010 4:56 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
On 05/12/2010 01:03 PM, Peter Zutrauen wrote:
| Quote: | As the tailplane is a symmetrical airfoil, my confused mind asserts
This is an *anti servo trim tab*, if it is not in line with the
tailplane, it puts a force on the tailplane so that the tailplane
rotates until it is in line with the anti servo trim tab again.
You can easily see what I mean by exercising the trim in whatever
position, and then carefully with your hands on the anti servo tab, try
to push it in line with the tailplane again. You will see that the
tailplane rotates during this process, and that you will always end up
with the anti servo tab in line with the tailplane.
This is true for *any* speed, *any* CG, etc, except when the pilot
exercises some force on the stick. Any force on the stick gets into the
equation and disturbes this balance.
If you trim for a specific speed, all you do is put the stick in a
specific position, and then with the trim button, line up the anti servo
tab with the tailplane, to keep the tailplane at its new position. You
will always end up with the anti servo tab in the same relative position
of the tailplane.
The real confusion is that there are people flying around with the anti
servo tab not in line with the tailplane. This means they are either
pulling or pushing slightly on the stick, or that the tailplane is not
balanced out properly.
About the latter: I disconnected everything from the tailplane when
balancing it out. If you leave the stick connected, you won't get a
proper balance and the anti servo tab will not find its equilibrium in
Next time we do this, I will vary the speed, trim for each speed, and
make a picture again. I would be really surprised if at any speed the
anti servo tab will not remain in its same relative position to the
tailplane. (Of course at every speed, the whole stack of tailplane plus
anti servo tab will rotate to a specific position... but with the anti
servo tab always in line with the tailplane. This is what you do if you
trim: lining the anti servo tab up with the tailplane in its new position).
Now, for your questions (although they don't matter):
| Quote: | - were you in stead-state constant-altitude cruise?
Yep. (We were in close formation so we wouldn't dare to fly anything
than a very stabilized attitude).
| Quote: | - where was your trim set at?
At 1/3 from the nose down limit.
| Quote: | - was your stick force = 0?
Of course 0.
| Quote: | - what was your cruise speed?
About 110 Knots.
| Quote: | - what was your weight and balance (with fuel at that point in time)?
Two adults, about 20Kg of bagage, and about 40 liters of fuel.
Frans
Posted: Wed May 12, 2010 5:24 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Hi Frans,
I understand your thesis (thanks again! .
Your thesis assumes that the tailplane is aerodynamically balanced wrt to the torque-tube position, and the only aerodynamic component which is stabilizing it and keeping it from flutter is the anti-servo tab.
I question this, as the fulcrum is ahead of the center of the tailplane. Maybe my skepticism is unwarranted? Is the fulcrum in the center of the tailplane aerodynamically? Without the anti-servo tab, would the tailplane flutter by design? I doubt this is the case, as (I believe) the flettner strips were added to eliminate the 'dead zone' of the anti-servo tab (bringing it out of the boundary layer) to eliminate a trim-hunting issue, not flutter (someone with some historical knowledge please do chime in!).
I would expect/hope that the tailplane would remain aerodynamically stable without the anti-servo tab, and that the tab is there only to provide for progressive stick forces, and trim.
The "still curious",
Pete
On Wed, May 12, 2010 at 8:54 AM, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
[quote] --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
of the tailplane.
Of course 0.
About 110 Knots.
Frans
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
le, List Admin.
Posted: Wed May 12, 2010 5:53 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
On 05/12/2010 03:22 PM, Peter Zutrauen wrote:
| Quote: | Your thesis assumes that the tailplane is aerodynamically balanced wrt
Stabilizing, but not necessarily keeping it from flutter. I think that
the mass balance weight is to keep it from flutter, just as with the
ailerons (that don't need to have a trim tab for that either).
| Quote: | I would expect/hope that the tailplane would remain aerodynamically
This is how it works I believe. At least is seems so on the PH-DIY.
Frans
budyerly(at)msn.com Guest
Posted: Wed May 12, 2010 6:45 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Good analysis Frans,
If the tail plane is perfectly balanced and friction in the system nil, the trim tab is centered.
A too heavy counter weight is offset by the trailing edge of the tab up. A difference in flettner strips can cause the same.
Flutter is dependent on the center of mass and the aerodynamic center. A horizontal control surface, mechanically balanced, with a symmetrical airfoil surface with the aero center co-located with the center of mass tends to stay neutrally stable. Camber angle and or trim tabs change that of course.
When the center of mass is behind the the center of pressure, the trailing edge goes down due to gravity, aerodynamic forces then try to lift the trailing edge and in some cases overshoot the center line, so gravity and the aero forces push the TE down, then it overshoots again and flutter occurs. This is especially a concern of a cambered aileron not mass balanced.
I don't have time to go into the drawings, but a symmetrical airfoil contributes no moment to its normal force at low angles. That is, if it is perfectly balanced at its aerodynamic center, it will stay at its angle of attack unless acted on mechanically and requires no force (beyond mechanical friction in the mechanism) to move it. It will, by previous statement, also apply no counter force when moved (so no pilot feel). This is why we have the anti servo tab, to create feedback to the pilot. It also cleverly applies trim.
If the flettner strips are not perfect, and or the mass balance is slightly off, your trim tab will show the effect of that. The asymmetric flettner strips of course act as a flap and become not an anti-servo tab, but a servo tab which drives the trim tab, which drives the tail.
As for the unbalanced anti-servo tab. The tab itself does not contribute to flutter if it is fixed. If the tab is loose, the tail plane bushings or trim bushings are missing, loose, damaged or not installed, flutter will occur. This is why, I am such a zealot about stabilators, loose pins, and bearings. I would even prefer to try to mechanically balance the trim tab for the guy who mistakenly fails to hook up the trim tab pins to the trim bar.
Hope that doesn't add to the confusion Pete.
Bud Yerly
Tech Support
Posted: Wed May 12, 2010 7:03 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Pete
You are right about the flettner strips, they bite through the boundary layer and stop trim hunting hunting. The mass balance is there to balance the weight of the elevator.
Graham
Sent: Wednesday, 12 May, 2010 14:22:36
Subject: Re: Re: Effects of Flaps and Ailerons on Pitch Trim
Hi Frans,
Pete
of the tailplane.
Of course 0.
About 110 Knots.
Frans
le, List Admin.
http://www.matronics.com/Navigator?Europa-Listhttp://=======================
Posted: Wed May 12, 2010 7:54 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Thanks to both Frans & Bud for the detailed explanations!
Coo!l .. it's all so clear to me now
My build goal with then to have a perfectly flettner'd tab to emulate Frans's beautiful workmanship.
Cheers & thanks again!
Pete
A239
On Wed, May 12, 2010 at 10:35 AM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote] Good analysis Frans,
Bud Yerly
Tech Support
raimo.toivio(at)rwm.fi Guest
Posted: Wed May 12, 2010 7:56 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
| Quote: | >
Frans, take it again:
Balancing is nothing to do with that.
Balancing is to prevent possible flutter.
Only case when the trim tabs and the stabilator
are in line is then, when they are in their
neutral position.
That is if the plane is correctly build as per
manual.
In that case only the plane is in its cleanest
condition.
You are able to achieve that with a certain
combination of weight, speed, CofG etc but that is
a special case.
What faster we fly that more we get lift by wings.
That is why we have to push more or trim nose down
= trim tabs move upp when flying faster.
The stabilators´ trailing edges move then down.
They cannot be in-lined any more.
Overall, tailplanes /stabilators are neutralized
only when CofG = CofL (w zero stick forces).
If you have to declect tailplanes (and wanna
neutralize stick forces) you have to trim trim
tabs to other direction.
The aerodynamical forces /deflected trim tab are
then equal with the aerodynamical forces
/deflected tailplanes.
They are balancing then each others by
aerodynamically.
They have to be un-lined normally, more or less!
If not I am a Donald Duck!
That is why we usually and almost always see them
(trimtabs) in deflected position only.
I am sure you will confirm that when you get take
more photos.
In your photo you were flying 110 knots, w/o stick
forces, trim tabs and tailplanes in line:
congratulations, your plane is very economical
with that speed because obviously tailplanes are
in their neutral position and the plane is most
streamlined.
Otherwise - your neutral is not exactly neutral.
I assume your fuelflowcomputer will confirm that.
If you wanna fly slower or faster (with same load
and conditions) I am sure your tailplanes and trim
tabs are not any more in line.
The stick forces in Europa are quite light around
100 knots. Also the necessary movements to keep
level flight are small.
I would like to say: almost invisible when looking
photos!
Look at attached photo: I was flying around 120
knots with one Dynamic WT9.
My trim tabs are slightly deflected upwards - so
the stabilators have to be deflected downwards a
little bit.
If flying faster - they have to be deflected even
more of course.
The stabilators are very powerful - that is why
they are near their neutral position almost
always.
That is why also the trim tabs are *almost*
in-line fith stabilators.
Notice - just almost. If you have trimmed, they
are not exactly in-lined any more.
Concorde did this by pumping fuel into fin or out
from there. The stabilators could be so almost
always in their neutral position and the plane was
very clean.
With Europa, we could have let is say 10 kilos of
fuel inside the fin...
That was my thought only. No confusion at all.
Just aerodynamic.
I am sure I will get a fast speed reply
Raimo
Terveisin, Raimo Toivio
Europa XS Mono OH-XRT #417
37500 Lempäälä
FINLAND
p +358-3-3753 777
f +358-3-3753 100
toivio(at)fly.to
www.rwm.fi
2.39 MB |
15110 Time(s) |
Posted: Wed May 12, 2010 11:44 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
On 05/12/2010 05:17 PM, Donald Duck wrote:
| Quote: | What faster we fly that more we get lift by wings.
That is why we have to push more or trim nose down = trim tabs move upp
when flying faster.
YES! And the story doesn't end here.
Now, before we go any further, print this out, and take it with you to
the hangar.
Are you there? Fine.
1) Put the trim in the middle, and line up the tailplane and anti servo
tab by rotating the tailplane. If done properly, the tailplane is in
about its "neutral" position when it lines up with the anti servo tab.
2) Now, trim the nose down with your trim button. Anti servo tabs moves
up (assuming you wired everything correctly).
3) Let's play aerodynamics. Your hand is the airstream. The anti servo
trim "sticks out" in the airstream. Push with your hand on the anti
servo tab to imitate the aerodynamic forces.
4) Now LOOK! The anti servo tab goes down. Due to some ingenious
mechanical linking the trailing edge of the tailplane also moves down
(this is why you trimmed the nose down after all).
But most important: The anti servo tab moves faster down than the
tailplane. While pushing the anti servo tab downward, it will at some
moment be in line with the tailplane. Stop when you reach that moment.
This is your newly trimmed out position!
5) Now stare at it for a while, and consider what you just did. Try it
the other way around.
6) Start wondering why the anti servo tab would remain sticking out in
the airstream by itself while nobody is keeping it there. Also try
moving the trailing edge of the tailplane down without the anti servo
tab moving twice as fast downwards as well. It can't be done!
7) Congratulations! You just discovered that an anti servo tab is not a
regular trim tab! A regular trim tab is held in a fixed position and has
no choice. An anti servo tab can move, seek the most convenient
position, and as a consequence take the tailplane with it.
| Quote: | They have to be un-lined normally, more or less!
Quack.
| Quote: | That is why we usually and almost always see them (trimtabs) in
I am sure you will confirm that when you get take more photos.
If the opportunity exists, I will show it to you so you can see it with
your own eyes.
Frans
Posted: Thu May 13, 2010 1:25 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
On 05/12/2010 09:25 PM, I wrote:
| Quote: | Now, before we go any further, print this out, and take it with you to
the hangar.
Someone pointed out to me that he found my post "condescending". I had
to look up what this word means, but it wasn't a good thing. Now I'm
very worried that more people considered my post with similar feelings.
As my previous attempts to explain how I think the anti servo tab works
failed, I thought that a "look and feel" experience would make clear
what I mean. The idea that someone would try this out and imagining the
light bulb going on, together with the comment that "I'm Donald Duck if
it works that way" from the previous poster, was to me an invitation to
put some humor into the description.
I should have known. The balance between a humoristic description or a
condescending description is very marginal, too marginal for a non
native English writer like me. And on top of that is humor culture bound
(On a Dutch forum this post would have provoked a few ROFL smileys and
nobody would have taken offence, as we tend to be a little less formal
and polite than some other cultures).
So, I want to apologize to anyone who felt offended by my post, or
considered it "condescending". It really was not meant that way.
Frans
paul.the.aviator(at)gmail Guest
Posted: Thu May 13, 2010 4:18 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Frans,
I certainly didn't perceive that from your descriptions. Your English grammar is impeccable, particularly so given that it is your second language. Perhaps the individual who took offense could give that some consideration. I wonder how many languages he speaks ?
Paul
kevann(at)gotsky.com Guest
Posted: Thu May 13, 2010 4:47 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Paul, Your English grammar ain't bad (for an Aussie).
This yank pretty much got the sense of humor, and even better, I think I gained a better understanding of how our tailplanes work.
I looked at in flight photos of N211KA and at about 120knots the tabs indeed are even with the TP.
Thanks Franz,
Kevin
[quote] [b]
Posted: Thu May 13, 2010 5:13 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
On Thu, May 13, 2010 at 5:24 AM, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
"As my previous attempts to explain how I think the anti servo tab works
what I mean."
The confusion around this topic (thus your "failure" may be (at least it was in my case ) that one has to accept the fact that the design's torque tube placement results in a (symmetrical airfoil) tailplane is *aerodynamically balanced* for Frans' functional description to make sense. ie- no matter what the steady-state angle of incidence is of the tailplane, there are no resultant stick forces which need to be zero'd out by a portruding trim-tab ( which is the anti-servo tab in this case).
This was a very hard sell for myself. I had always assumed that that the tailplane's torque-tube location was slightly forward of the aerodynamic balance point, to make sure that the tailplane would always aerodynamically "trail" and thus be inherently stable (since it is mass-balanced). My rational was that if the design was perfectly aerodynamically balanced about the torquetube, and a builder had somehow managed to move the fulcrum slightly rearward of the aerodynamic balance point (build tolerances?), then the tailplane would be inherently unstable and that would be a disaster waiting to happen (in that case, once the tailplane is moved slightly producing an AOA ><0, positive feedback would quickly take hold and slam it to the stop).
So, if one were to go down the same **incorrect** thought path as myself (the trailing tailplane idea), then indeed the anti-servo tab would need to remain deflected out in the airflow to keep any AOA other than zero (and also performing the function of a flap? .. this visualization still makes my head hurt).
So, since we are dealing with an "approaching perfect" design (an aerodynamically balanced tailplane), Frans' assertion of the anti-servo tab always nulling itself out is correct (boundary layer effects being ignored/taken care of by the flettner strips), regardless of airspeed, COG, airplane AOA etc.
I'm still curious how close to perfectly aerodynamically balanced the tailplane design is. Don Dykins sure was a clever fellow.
Pete
A239
Posted: Thu May 13, 2010 6:04 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
On 05/13/2010 03:12 PM, Peter Zutrauen wrote:
| Quote: | The confusion around this topic (thus your "failure" may be (/at
least it was in my case/ ) that one has to accept the fact that the
tab in this case).
Ah, OK, now I see your point.
I thought that this aerodynamically balance was the major "selling
point" of the tailplane, and hence common knownledge amongst builders. I
recall having read somewhere that the whole purpose of the mass balance
arm is to cancel out the weight offset, which is a *result* of having
the torque tube in the aerodynamic center, rather than in the weight center.
I have to admit that it took me a while too before I grabbed the
concept. The whole arrangement with the anti servo tabs which double
duty as trim tabs at the same time is indeed a genious concept. If the
anti servo tabs are always in line with the tailplane, there is never a
drag penalty, regardless of trim setting. This is just one of the things
that make the Europa a relatively fast airplane.
Then you can maybe understand that I found it rather shocking to read
that "all Europa's are flying with the trim tabs deflecting upwards"...
as this would defeat the whole purpose of the ingenious anti servo tab
and all flying tailplane. I was prepared to find a way to fix this
problem once I would reach the flying stage... until I discovered to my
delight that the PH-DIY doesn't suffer from this problem at all.
I'm still curious however why some Europa's suffer this problem.
| Quote: | I'm still curious how close to perfectly aerodynamically balanced the
Was Don Dykins responsible for the tailplane too? He was indeed a clever
fellow.
Frans
loboloda(at)execulink.com Guest
Posted: Thu May 13, 2010 12:28 pm Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Kevin,
I seem to remember being reprimanded by Paul for calling him an Aussie, although it was more or less the right part of the world.
Dave
On 13-May-10, at 8:46 AM, Kevin Klinefelter wrote:
[quote] Paul, Your English grammar ain't bad (for an Aussie).
Thanks Franz,
Kevin
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
| [b]
Posted: Thu May 13, 2010 1:06 pm Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Heck no... I only get bent out of shape for being mistaken for a Brit.... )
On Thu, May 13, 2010 at 3:38 PM, david miller <loboloda(at)execulink.com (loboloda(at)execulink.com)> wrote:
[quote]Kevin,
Dave
| Quote: | Paul, Your English grammar ain't bad (for an Aussie).
Thanks Franz,
Kevin
rparigoris
Posted: Thu May 13, 2010 1:32 pm Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Hi Paul"I only get bent out of shape for being mistaken for a Brit...."That's good to know in case I thought you were from NZ!Ron Parigoris Do Not archive [quote][b]
Posted: Fri May 14, 2010 2:40 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Don was responsible for all the flying surfaces.
I wonder if some Europas are not correctly mass balanced, it's not easy if there is any stiffness in the pitch control (which I have seen too often)
Graham
To: europa-list
Was Don Dykins responsible for the tailplane too? Heics.com/Navigator?Europa-List" target="_blank">http://www.matronics.com/N= - MATRONICS WEB FORUMS= -->
Posted: Fri May 14, 2010 9:23 am Post subject: Effects of Flaps and Ailerons on Pitch Trim |
Frans
and all of you:
I woke upp last night and got a light like a
lightning to my poor salesman brains.
That was well before your message below.
I have not visited my Europa and that is not
necessary because of this question.
You - Frans - are absolutely right!
My mistake:
I thought Europa´s tailplanes are like any other
ordinary elevators.
Because it´s natur to be all flying I understood
it is very light to operate but I did not
understand the real meaning of "aerodynamically
balanced".
I have always thought as follows: fore of the
torque tube there is about 1/3 of tailplanes and
behind there are 2/3 of tailplanes.
That is why I have assumed there are aerodynamical
forces but only let is say 2/3 - 1/3 = 1/3 when
compared to "normal" solution like Cessna´s
elevator.
Finally now I understand the name of the game:
without the antiservo function pitch would be
totally w/o forces in the stick!
Awful!
When trimming that means we are in fact in-lining
tailplanes with trimtabs to a certain desired
position!
I got some messages which were supporting my idea
and for example Mr X from Z wrote
"Now lets increase our speed to say 140 kts in
straight and level flight
without trimming . . . . . you and I both know
that we will require a
forward pressure on the stick which of course is a
pain so we need to trim
the tailplane so that aerodynamic forces are
substitued for our mussle
power. Now if Frans is correct, the trim tab will
once again be aligned
with the trailing edge of the tailplane so what
the hell is providing the
necessary force to hold the tailplane in the new
position? The tab simply
MUST be displaced to provide the necessary force
to my way of thinking."
That was exactly what I thought also.
And answer is: there is NO necessary need for any
force to hold the tailplane in the new position
because it is happy with ANY position.
That is why they (tailplanes and trim tabs) are
always in-lined when trimmed properly.
When trimming - you are in fact cleaning the
entire system!!!
The most genious part: what is keeping it there in
the desired position?
If the tailplanes try to move upp or down, trim
tabs move automatically even more to same
direction and that is why the are fixed just that
position where pilot has trimmed them.
And they stay here until new trimming or pilot
force via stick.
That is why I feel a bit or more frightened also:
without antiservo function there would be not att
all any idea what is the position of the
tailplanes!!!
No stick forces at all!!!
Before flight I have always checked my tabs but
from this point I will do it very carefully!!!
Without them or that function I assume Europa will
be a flying coffin.
Until now I am happy I did that mod (mandatory in
England) which enhanced trim tabs´s pins years
ago!!!
I remember I almost cancelled because I was
tempted to imagine those trim tabs are nice but
not totally necessary for safety!!!
One interesting point also: obviously all the
tailplanes which have been built perfectly, are
perfectly also aerodynamically balanced.
Like Frans´s Europa´s tailplanes.
Then and only then the trim tabs are always lined
with tailplanes when properly trimmed!!!
My Europa and many other Europa´s trim tabs are
(when watching photos) slightly deflected when
cruising and the plane is trimmed.
That means those tailplanes are not perfectly
built = they are not perfectly aerodynamically
balanced.
Obviously it is hard to produce perfect shaped
tailplanes when making foam tailplanes like mine
but next generation tailplanes without foam
structure are maybe "automatically" perfect.
Frans, thanks for patience.
Frans, thanks for educating me and some other
persons on the globe.
Frans, thanks for you because now I understand a
bit more my plane and respect it much more.
I did not feel at all
"Someone pointed out to me that he found my post
"condescending". "
They say some Dutch people are a bit arrogant but
you - Frans - are not. Just brilliant. I am
pround we are in the same list and fly same plane.
OK. I am a Donald Duck. Kwaak kwaak kwaa.
But I am a happy duck. That is because
- my nephews are talent.
- I have a nice career in a fat factory.
- my uncle (Scrooge) have some nice jets, bush
planes, DC-3 and many others and I am able to fly
them all, also IFR in Alaska through snow storms.
- my uncle is the richiest duck in the world and
some day I will be his heir.
- my girlfriend Iines Duck is very atractive.
- my daughters love Donald D.
Frans - next time I will consider a bit more
before I think you are wrong.
You are wrong probably very seldom, I assume.
Would be nice to meet you in Texel next autumn.
I give you some extra present: have you earlier
seen a Duck on the wing behind a running star
engine?
Raimo (cheekbones totally red) aka DD
37500 Lempäälä
p +358-3-3753 777
f +358-3-3753 100
toivio(at)fly.to
www.rwm.fi
Sent: Wednesday, May 12, 2010 10:25 PM
To: <europa-list(at)matronics.com>
<frans(at)privatepilots.nl>
> wings.
> when flying faster.
the hangar.
the tailplane is in
to some ingenious
all).
it there. Also try
can't be done!
most convenient
tailplane with it.
> less!
Quack.
> them (trimtabs) in
> take more photos.
your own eyes.
Frans
| Quote: | Web Forums!
| Quote: | List Admin.
1.06 MB |
15051 Time(s) |
